Sensata SSI-12HF10N Power Inverter - Cooked :(
  • crashp3
    • Mar 2011
    • 81
    Hey Guys:
    First off, my apologies if I put this in the wrong subforum. I know this is generally for AC to DC (PC) power supplies. If it should be moved, please advise!
    I am currently working with a Sensata SSI-12HF10N ((datasheet) DC to AC power inverter.
    This inverter is rated for 1000w continuous power, with a maximum of 1100 and 2000 max surge rating.
    In any event, my buddy decided it would be smart to hook up a home vacuum cleaner to it versus using a true outlet that was 10 feet away. Immediately, the unit shut down and emitted a lovely burnt electronic smell.
    Tore the unit apart (pictures below) and found several blown components. To replace, these units are roughly 500$ from my supplier (yuck!) and am curious of the feasibility of repairing this.
    Most blown components appear to be minor and inexpensive, but my greater concern is if some other components could have been damaged and/or pose a safety risk while attached to the vehicle.
    I appreciate your expert advice and please let me know if more pictures would assist!
    Image Description
    Main1 - Overhead shot of main board
    main2 - side view of damaged/burnt components
    main3 - closer view of damaged/burnt components
    main4 - even closer view
    main5 - random components not close to damage - bad? or normal?
    daughterboard - There is a daughterboard that attaches to the main board (controls LED status light, fan speed, etc.), component damage
    daughertooard2 - closer view
    Thanks again!
  • cheapie
    null
    • Jul 2010
    • 849
    Re: Sensata SSI-12HF10N Power Inverter - Cooked
    Try and see if you can read the numbers off of the burnt parts (or the good ones next to them) in main3. They're probably all the same.
    P.S.: I think this is the right subforum. It IS a power supply, after all.
    • DJduck
      • Dec 2012
      • 229
      • Estonia
      You might want to check some other parts too before replacing them. If anything else is shorted or burnt out then the chances are that one you replace the transitors/fets they will blow out again.
      Also, make sure you replace all the resistors that have burn marks
      I can put text here?!
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Looks like the MOSFETs for the step up transformer have gone pop. I'd replace them with some better ones too next time.
        Be sure to check the mosfet gate resistors (they look to be 10 ohms), and the mosfet drivers (not sure where they are). They are likely damaged.
        Those diodes on the two small heatsinks look to have popped too. I'd replace them with some bigger heavy-duty diodes, not cheap DO-201 plastic ones (just like the diodes that have blown).
        Can you provide a picture of the back of the control board? (the daughterboard)
        Muh-soggy-knee
        • crashp3
          • Mar 2011
          • 81
          Alright, did some research earlier today and here's what I came up with.
          The blown MOSFETs are IXSYS Trench2 Power MOSFETs (IXTA110N055T2 - datasheet) and there are two different MOSFET gate resistors, I'll refer to it as front row (farthest from heatsink R30, R29, etc.) they are 10ohm resistors, back row (R38, 37, etc.) are 10Kohm resistors.
          The small black thing on the daughterboard that appears burned is an NEC PS2561-1 photocoupler (datasheet).
          Unfortunately, the back of the control board has some type of paint/substance protecting the leads... here is a pic, any recommendations on removing this crap? Didn't appear to willing to peel back with my fingernail.
          I'd appreciate any recommendations on better components to replace the MOSFETs with -- I'm not good at finding suitable replacements, just googling the numbers and ordering on digikey
          Thanks in advance for the help thus far!
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Ughh! Looks to be lots of stuff on the backside there. Under the silicone-lookalike stuff, that is.
            You could try just replacing the 10 ohm resistors, those diodes, and the mosfets, but if it still doesn't work then I don't know what else to say. It's a gamble.
            Muh-soggy-knee
            • crashp3
              • Mar 2011
              • 81
              Yes, a ton of stuff! In looking at it further, the control board (when mounted to the mainboard) is close to the MOSFETs that blew, and coincidentally the black daughterboard component faces exactly right next to the blown MOSFETS.
              I am hoping that the component isn't bad (I'll replace that and the corresponding cap) but just got blackened when all the MOSFETs blew being its in very close proximity to that area. I see no other indications of damage to the daughterboard.
              • x_orange90_x
                by x_orange90_x
                01-29-2025, 09:24 PM
              • Gentian
                APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                by Gentian
                I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                03-06-2023, 07:07 AM
              • valvashon
                Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                by valvashon
                For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                01-04-2024, 01:44 PM
              • eccerr0r
                A modified sine wave inverter + a grid tie inverter?
                by eccerr0r
                If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                Next thing is trying to charge the batteries using solar power, but that's another issue ...
                08-31-2023, 09:14 PM
              • caseyjay_48
                Sony KDL-46BX450 Inverter Troubleshoot Logic
                by caseyjay_48
                I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                09-23-2022, 08:08 PM
