Why does the +12v cap always seem to die first?
  • Maxxarcade
    • Jul 2006
    • 973
    I've had a handfull of power supplies apart the last couple weeks, and almost all of them had a bulging cap on the +12V and no where else. Does this one go bad because of the type of load (hard drives and CDROMS etc)? One was a cheap generic supply, and the other a Sparkle 250W.
  • japlytic
    • Oct 2005
    • 2086
    Re: Why does the +12v cap always seem to die first?
    On P4 mainboards, there is an ATX12V connector, and the board uses a couple of amps of the 12V rail for the DC/DC converters for the CPU.
    • linuxguru
      • Apr 2005
      • 1564
      Yup, the ripple current on +12v is fairly high on P4 boards because that's used as the input (through the 4-pin ATX12v connector) to the VRM for supplying the high-current Vcore rail.
      The +12v caps on the same PSU, connected to (say) an Athlon board without the 4-pin +12v connector, would probably have lasted longer - but the tradeoff would have been higher load on the +5v rail, which was usually used as the input to the Vcore VRM on Athlon boards. The +5v caps would have probably failed quicker instead.
      • gonzo0815
        • Feb 2006
        • 1600
        Most older PSu`s are desinged to cope with high currents at low voltages. Thus the 12v line was usually not considered to be under any seriouse load. And as usuall, as Intel and then AMD board vendors altered this, the psu vendors won`t do a complete ne desing. Adding a few wirres more and a p4 conector ins`t that expensive. Thus i think those failures are from an not well suited ripple current rating of the caps they used.
        • Maxxarcade
          • Jul 2006
          • 973
          The thing is, none of these were used on ATX12V boards, only older 20 pin boards (PC Chips M810 v.5.0 and v.7.0a).
          • gonzo0815
            • Feb 2006
            • 1600
            May be the caps where very undersized & mediocre too. The 12v line had been very long the highest allowable rippl & noise in ATX specs. This means, that it was not the line an vendor would have had put mutch attention on it. The most attention from a desing perspective was on the lower voltage line, thus they skimped out on the 12v line. I have seen many psu`s with as low as may be 470uF to 1000uF on single cap without Phi filter. It needs probalby not mutch imagination, that this is even for a low load, may be 2 to 4 A for HDD &dvd isn`t suffizient. MAy be the input capazitors on a VRM unit would lessend the strain a bit from the psu`s ones.
            • Ibod
              Corsair cx600 psu & ASRock B450Pro4 mobo wont start
              by Ibod
              HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
              With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
              Not sure where to go from here ?
              Is the PSU at fault or is the mobo causing the problem
              Look forward to any help :-)
              If I plug the 24...
              02-08-2023, 11:00 AM
            • Jonny_Doe
              Broken R7 260x - Voltages on board
              by Jonny_Doe
              Hi everyone.
              I got a broken MSI R7 260X for $10, seller said there was a surge and afterward graphics and network stopped working.
              The power supply goes into protection if inserting the 6pin ATX12V into the graphics card.
              So i figured, well, yeah, some mos broke in the VRM, should be easy fix.
              Indeed, a Hiside mos was shorted and i replaced it.
              The Vcore was generated by 2 switcher groups (hiside + loside MOS and an inductor in each group) powered from 12V PCIE and another 2 from 6pin 12V ATX. The broken mos was on the 12V ATX...
              02-10-2022, 09:12 AM
            • erdos
              Help with GeForce 6600gt AGP Card not receiving enough power
              by erdos
              hey guys,
              I have an old homebuild PC with MSI K8N Neo Platinum 754 NVIDIA nForce3 250Gb ATX AMD Motherboard and Evga geforce 6600gt agp Card.
              whenever I booted into windows7, an onscreen message pops out - warning that nvidia card is not receiving enough power and is at reduced performance level. When I opened the case, the GPU fan on the nvidia card is not spinning. after a while, the card becomes extremely hot when touched. I have a new Cosair RMS 750Watts PSU for the pc - replaced an old TruePower 380Watt ATX12V Power Supply, and the extra molex connector on the...
              04-05-2023, 08:04 AM
            • CWEastwood
              Antec Smart Power SL300S capacitor replacement.
              by CWEastwood
              I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
              The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
              I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
              Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
              03-25-2023, 12:18 PM
            • kgavionics
              Dead Gibabyte mobo!!!
              by kgavionics
              Hi guys
              I bought a Ga-p55-us3l from ebay and i have a weird problem as far as i can tell.
              When i plug the atx24 pins connector along with the 12V 4 pins atx connector, the motherboard doesn't show any sign of life( phase led light off ) cpu and gpu fans are off and of course no post or whatsoever.
              When i disconnect the atx12v connector ,the cpu fan starts to turn and the CPU phase lights come on.
              I have a good electronics background, but i've never tried to fix a mobo before!!
              I want to do some troubleshooting, but i don't have any schematic and i don't know...
              01-27-2019, 03:16 PM
