Dead Gibabyte mobo!!!
  • kgavionics
    • Apr 2017
    • 152
    Hi guys
    I bought a Ga-p55-us3l from ebay and i have a weird problem as far as i can tell.
    When i plug the atx24 pins connector along with the 12V 4 pins atx connector, the motherboard doesn't show any sign of life( phase led light off ) cpu and gpu fans are off and of course no post or whatsoever.
    When i disconnect the atx12v connector ,the cpu fan starts to turn and the CPU phase lights come on.
    I have a good electronics background, but i've never tried to fix a mobo before!!
    I want to do some troubleshooting, but i don't have any schematic and i don't know where to start from!
    can someone help me please!!!
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Dead Gibabyte mobo!!!
    as this connector is for added CPU power, check this line for short
    • piernov
      • Jan 2016
      • 4439
      • France
      Shorted MOSFET on CPU VCore VRM. Measure exact resistance between +12V and ground inside this P4 CPU power connector (+12V is the pins that connect to yellow wire, ground is the pins that connect to black wire), with the power supply cable actually disconnected.
      • kgavionics
        • Apr 2017
        • 152
        Thank you guys for your inputs
        I have a short between the 12V rail and ground inside the connector!
        i have found some shorted source and drain on some Mosfet's ( K4212)
        I guess this Mobo is not worth fixing!!!
        I only want what could went wrong!!could be a bad Power supply unit, because i have tried this board with a cheap Power supply and since then i ended up having this problem and two defective CPU's?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          it's just mosfet/s, replace check caps and it will be good to go
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            yes, this type of repairs last long
            Im Back... sort of...
            • kgavionics
              • Apr 2017
              • 152
              i'll check if i can find some good deal on these Mosfet's on ebay or aliexpress!!!
              thank you guys for your inputs
              best regards
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                mosfets is mosfets. u can keep it from another mobo or gpu.
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  I don't have the same point of view there… CPU VCore MOSFETs are quite sensitive in my experience. Only replacing the shorted one with random MOSFET from Aliexpress always resulted in the board dying again.
                  For piece of mind I replace all the high-side (or low-side) MOSFETs with ones from the same batch, avoiding Chinese eBay seller or Aliexpress. I also replace the PWM controller for the MOSFET that died, or if everything is integrated into the CPU buck controller itself I replace it as well.
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    im not replacing for random from aliexpress. im mostly using used genuine from used mobo and mostly with higher walues
                    • corrize
                      Where to find a very small fpc connector 0.3mm between 2 pins ?
                      by corrize
                      Hello, I search this connector (oxydated).
                      It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                      I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                      I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                      Do you know how to find this connector please ? What is the exact name for find it ?
                      08-06-2024, 05:25 PM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • araxnido
                      Programming KBC IT8987VG ASUS TUF FX506L RT809F+PEB
                      by araxnido
                      Dear friends, I want to share my experience repairing an ASUS TUF FX506L gaming laptop motherboard: DABKXDMB8E0_F_BKXD. Boardview and schematic are available, as well as the BIOS and ITE ROM.
                      When the customer brought in this laptop, it was initially dead; it showed no signs of booting for any reason. After hours of measurements, checking each stage, MOSFET, and seeing if there was a short circuit in any capacitor, I discovered a strange 0.7V leakage voltage on the 3V_S5 rail, particularly on the PL9 coil, with the board not powered on. There were 3V_LDO and 5V_LDO voltages, which...
                      06-10-2025, 09:26 PM
                    • Saturn49
                      Barely perceptible flicker on Pixelbook
                      by Saturn49
                      TL;DR: Fixed a board by replacing the display connector and traces for the backlight. Now backlight sorta flickers.
                      Side Note: This is mostly an exercise in stretching my troubleshooting and micro-soldering abilities - Pixelbooks aren't worth much, though I do have a replacement on order because my wife still uses it pretty often.
                      Background: Coffee was spilled onto the display connector of a Google Pixelbook which (of course) managed to short out the display backlight. This burned the connector on the main board and the cable. In fact, it burned two pads for the connector...
                      12-02-2023, 05:28 PM
                    • michhak
                      Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
                      by michhak
                      Hi guys,
                      i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
                      It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
                      11-17-2021, 05:45 AM
