Two questions about repairing Antec PSU
  • jpyerry
    • 94
    I have an Antec TruePower 450 Watt PSU that I am trying to repair, and I have two questions about it.
    First, it has an NTC thermistor that is SCK 2R512 that is cracked and I would like to replace it. I pulled the data sheet on it and discovered that it is 2.5Ω with a current rating of 12A and a whole bunch of other datapoints that I don't recall off the top of my mind. In doing a search for a matching NTC thermistor on mouser and digikey, I was unable to find an exact match. The closest I found was an EPCOS B57364S259M, which matches that 2.5Ω spec, but only rates at 11A and none of the other constants match. Would this part be an appropriate replacement for the SCK 2R512? Further, what are the important specifications in choosing an NTC thermistor, so that I know what to look for in the future?
    My second question is one that is much more academic. This power supply and my PC Power and Cooling Silencer that I have taken apart both have what appear to be wire wound resistors that are mounted to one of the large heatsinks inside the PSU. I couldn't help but notice that this resistor was not present in any of the no name PSUs that I used to see cross my workbench back when I was a PC repair tech back in the days when PSUs came free with the case. So, I am just curious what is the function of this resistor, and why does it seem to only be present in higher end power supplies?
    Thanks,
    Justin
  • Toasty
    • Jul 2007
    • 4171
    Re: Two questions about repairing Antec PSU
    This will work:
    Ametherm: SL22 2R515
    DigiKey: 570-1047-ND
    http://www.digikey.com/product-detai...1047-ND/749887
    Resistors - either loads for outputs or current limiters in the Source of MOSFETs.
    T
    veritas odium parit
    • jpyerry
      • 94
      Thank you, very helpful!
      • nmbb
        Can not find Model/Value of Thermistor.
        by nmbb
        Machine: Autoclave.
        Brand/Model: SANYO MLS-3780
        Manual: (Sorry search option not working on this PDF)
        Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
        06-02-2022, 05:55 PM
      • Use2bavolvo
        Magic chef oven - thermistor ref voltage issue
        by Use2bavolvo
        I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
        Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
        01-19-2023, 01:32 AM
      • Quantum IC
        Sony KDL-40BX450 LCD. Thermistor gets too hot 10 seconds after turning on the TV
        by Quantum IC
        Hello every one,
        This TV came to me with the problem that it was totally dead.
        The problem was the two MOSFETs and a fuse resistor in the power supply.
        The original MOSFETs were KF7N50F and I repalced them with SLF65R700S2.
        The original fuse resistor was 0.1 Ohm 1/2W. I didn't find a similar fuse resistor and I replaced it with 0.1 Ohm 5W ceramic resistor.
        When I plug the TV the ST-BY LED turns on, when I press the power button on the TV, the ST-BY LED turns off and the TV doesn't turn on until the second time I press the power button is when the TV turns on,...
        01-14-2022, 12:06 AM
      • fab13
        Thermistor exploded in two when turning on ps4 fat
        by fab13
        Hi there,
        I have a fat PS4 with the fuse (5a) of the power supply which blows with each power on and there was a loud snap in the power supply and again the same problem after replacing the fuse.
        I did not find a short circuit
        The component that broke in two is an SCK 084 thermistor (See photo)
        and measured at 11 ohm
        So far I haven't received a thermistor.
        Do you think that if I replace the thermistor and the fuse it should go away, because I have the impression that there is a strong current demand as soon as you press...
        11-05-2022, 06:29 PM
      • studdy05
        Bricked HP Probook 450 G7 Bios questions
        by studdy05
        Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
        Ive got...
        07-08-2025, 09:24 PM
