Trying to choose a replacement zener diode
  • Beowulf
    • Dec 2012
    • 175
    I'm troubleshooting the power board on this TV, with some help here and there, and I found this zener diode that is shorted, among other things.
    The P/N is 1ZB36 BL, here is the datasheet: http://www.mediafire.com/view/?iyadi5csc4k9dfd
    Since I can't find the same one to order it I'm trying pick a close match from digikey.
    Would this one be ok despite the difference in reverse current ratings?
    http://www.digikey.com/product-detai...PCT-ND/3104322
    Thanks!
  • Blargh523
    • Dec 2012
    • 46
    Re: Trying to choose a replacement zener diode
    Lower reverse current should be okay.
    • Beowulf
      • Dec 2012
      • 175
      Thank you!
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Isn't it the other way around? That is, if the replacement zener diode is rated for a higher reverse current, it should be better (assuming all other parameters such as voltage and wattage ratings are the same or very similar).
          The spec is for Leakage current:
          It is the leakage current before the apply voltage reach the Vz voltage point of the Zener Diode.
          http://www.reuk.co.uk/What-is-a-Zener-Diode.htm
          The 36V Zener (1N4753A) that he wants to use has
          Current Leakage of 5µA @ 27.4V
          The original has leakage of 10uA @28.8V
          • Blargh523
            • Dec 2012
            • 46
            Yeah, I should have specified reverse leakage, not just "reverse current".
            • bufferb
              • Jan 2016
              • 10
              • canada
              TV LC320ME Emerson # 610 0n board diode 1ZB36 .WERE DO I BUY IT,
              OR A MATCH,REPLY TANK'S
              • unimatrix93
                TV backlight zener diode
                by unimatrix93
                Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                The led strips has 9 6V leds.
                02-10-2025, 12:13 PM
                NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                by sam_sam_sam
                I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                I bought this from an eBay seller but unfortunately they only had one
                I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                I bought three of from them to also make battery packs with this output power limit in mind
                I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                04-23-2025, 05:50 AM
              • nev1001
                What zener diode might fix the sound on Maestro Mayhem gaming chair?
                by nev1001
                Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                I think an issue could be a zener diode (or capacitor) which has shorted out.
                The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                04-17-2025, 05:09 PM
              • Vincenzo2
                Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                by Vincenzo2
                My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                I put some pictures here to show that it is labeled "M7"....
                09-07-2023, 07:43 PM
              • chth96
                Is there any Diode Replacement for MPG06J?
                by chth96
                is there any replacement for MPG06J diode?
                https://www.vishay.com/docs/88682/mpg06.pdf
                It is very hard to find this MPG06J diode in my place.
                I think that replacement should have the same ratings with MPG06J, But it is impossible for me to hunt down replacement for MPG06J diode.
                Any reply would be appreciated.
                03-01-2024, 07:07 AM
