Can I trust the voltage readouts on my motherboard?
  • Terrh
    • Dec 2012
    • 15
    Trying to figure out a stability issue with my computer. HWmonitor offers a nice voltage readout, and I noticed my +12V can drop pretty significantly under load. Here's a screenshot after running a stress test (gpu and CPU):
    Power supply is a "new model" TR2-600. 80+ bronze, should be more than enough. My kill-a-watt says the computer never draws more than 315 watts from the wall.
    So is that +12V too low? Or can I even trust these numbers?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Can I trust the voltage readouts on my motherboard?
    Software monitoring is useless. A multimeter is always the best option If it was dropping to 11V then your computer would freeze or restart.
    • Terrh
      • Dec 2012
      • 15
      it is freezing, and I'm trying to figure out why.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        What power supply you using?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Ummm... you had the answer to that if you'd bothered to read the whole post.
          A working TV? How boring!
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
          • kamil1986
            Dell Latitude E5530 (LA-7902P REV:1) Does not display picture
            by kamil1986
            Hello everyone.
            Laptop Dell Latitude E5530
            Płyta: LA-7902P REV:1
            KBC: MEC5055-LZY
            Procesor: intel i3
            The laptop turns on but does not display the picture, after pressing the power button fan does not spin, the motherboard is stuck at 600mA current consumption the CPU and PCH chip gets warm. When I press again power button the fan start to spin but after a couple of seconds the motherboard turns off itself and current consumption drops to 12mA. The motherboard correctly displays fault codes because if I turn on the motherboard without RAM...
            03-19-2022, 11:28 AM
          • glovecaps
            by glovecaps
            11-25-2024, 04:23 PM
          • Docus
            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
            by Docus
            Hi everyone 😀,
            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
            1. I already own the exact same model, but its plastic chassis is badly damaged.
            06-10-2025, 04:24 PM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
