Gigabit Managed Switch dead
  • jabz
    • Dec 2012
    • 9
    • NZ
    Hi I have 3 Alloy Managed Gigabit Switches. 1 day one of them failed, I saw all the lights off, I tried another power plug and still not powering up.
    I would like to try an repair it, at first I though maybe its a fuse.
    But I couldn't see an easily replaceable one on the board, it appears the power board is separate. Can these PSU board be purchased from somewhere?
    Whats the best way to conclude it is a PSU/Fuse issue? I see a fuse on the PSU next to the power socket, it looks pretty covered up. I have removed the PCB and PSU and can see no evidence of marks/leaks or anything.
    I have a multimeter where should I put the points to check things are alive?
    I have pasted the pics below.
    Mainboard + PSU
    PSU
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Gigabit Managed Switch dead
    You fuse is at the right of the plug (picture no2) covered with heat-shrink material.
    • jabz
      • Dec 2012
      • 9
      • NZ
      I've checked the fuse and it appears to be ok. I then checked for DC voltage on the outputs and got nothing, so it appears something on the PSU is dead.
      Can someone help me find a source for this PSU online? The manufacturer and specs are here
      http://pgb-tech.com/products_info.ph...83&pclass_sn=7
      But I cant find a source to purchase it from.
      Or an equivalent that has the same specs with the IEC power connector onboard and with the 4 Pin power connector that connects to the gigabit switch mainboard.
      I am in NZ with 220V - 240V mains.
      thanks
      • rogfanther
        • Jul 2006
        • 458
        • Brazil
        You could try changing that small cap, between the transformer and the transistor, and also those from the secondary.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          I second that.
          Also, can we get a pic of the bottom of the PSU board? (Want to know if that board has a control IC or not)
          Muh-soggy-knee
          • rogfanther
            • Jul 2006
            • 458
            • Brazil
            ben7, I wondered about it also. Could that transistor ( if it isn´t a TL431 ) near the corner of the transformer be part of the switching control circuit , like in a cheap walwart ?
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              If your talking about the little to-92 device, then, yes, there is a 99% chance that it is a TL431.
              Most SMPS primary-side control chips are SMD.
              Muh-soggy-knee
                If worst comes to worst, it is only a 5V 3A power supply, you may be easily find wallwart 5V 3A switching power supply and just wire its output to feed this unit.
                I second that small start up cap by the heat sink also, or heat up the board with hair dryer to see if it wcome back on. by the way what happen if you disconnect its out put to the main baord and see if it will out out 5v isnce you may have shorted circuits on the main board that causes it to stay in shutdown mode.
                • jabz
                  • Dec 2012
                  • 9
                  • NZ
                  I'll take the pics to show you. I think I'd rather replace this PSU with a drop in replacement if one can be sourced easily enough, than attempt to replace components.
                  I tested the PSU output while it was disconnected from the mainboard, no 5V.
                  • PeteS in CA
                    • Aug 2005
                    • 3586
                    • USA, Unsure of Planet
                    Other than what is probably a ferrite rod inductor for high frequency noise suppression, I don't see an O/P inductor. My guess is that it's a self-oscillating discontinuous flyback - no PWM IC. Checking solder joints would be a good idea.
                    PeteS in CA
                    • jabz
                      • Dec 2012
                      • 9
                      • NZ
                      Here is a pic of the back and sides.
                      Still looking where to get a drop in replacement.
                        Can you read the P/N on that SMPS IC (the one with 8 pins on the bottom side of the board)? It can be as simple as that small cap by the heat sink that you will need to try out since it does not look like you are going to be able to buy on that will fit the chassis.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Personally, I don't think drop-in replacements are a good idea, especially if these PSUs like to fail a lot. If you do get an identical drop-in replacement, chances of it to develop the same problem are high.
                          If a power supply is designed well but fails due to shoddy caps, I rather rebuild it and know that it will last rather than replace with identical PSU that will eventually fail too.
                          • jabz
                            • Dec 2012
                            • 9
                            • NZ
                            Hi seeing as I couldn't find the same drop in replacement or an alternative easily that will fit, I am going to power the switch via a 5V 4amp wall wart I have, its a Class 1 power supply.
                            Specifically this one here
                            Once I rewire the output to the power connector on the switch mainboard. Do I need to worry about earthing the chassis?
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              If the chassis was originally earthed, then yes you should have it earthed.
                              Muh-soggy-knee
                              • jabz
                                • Dec 2012
                                • 9
                                • NZ
                                Yes it was the original open frame PSU in the above pics, that earth wire is a soldered connection to a pad that the chassis screw goes through.
                                So since I am using a standalone class 1 DC adapter, I will run a wire from the chassis screw to the DC adapter 3 PIN Mains connector and solder to the earth pin.
                                  Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                  This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                  09-06-2024, 05:30 AM
                                • Kingpin!
                                  3COM OfficeConnect Gigabit Switch 16
                                  by Kingpin!
                                  3COM OfficeConnect Gigabit Switch 16 (3C1671600)
                                  The switch has served me for 10+ years (was new when I bought it). It's a nice switch with connections on the back which makes for quite a clean desk. Reason for taking it apart was that the cooling fan was noisy so I expected it to be dirty/dusty inside and the need to order a new fan. What I found was that it was very dirty/dusty and some electrolytic capacitors which needs attention. There are 3 capacitors which needs to be replaced but the ESR on some of the other ones might be bad as well so I think I'll replace them all. Original...
                                  09-17-2023, 04:58 AM
                                • madan1
                                  Cisco catalyst 2960c POE
                                  by madan1
                                  Hello everyone.
                                  Got a catalyst 2960 from the usual scrapyard - ebay.
                                  It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
                                  Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
                                  Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
                                  The switch fails to boot due to the following POST error:...
                                  12-19-2024, 09:34 AM
                                • CapLeaker
                                  Shelly plus 1 dead, does not switch
                                  by CapLeaker
                                  Anyone got any Shelly remote devices around here?
                                  I’ve got a few of these and they were all working fine for about a year. Today I noticed that one of them that controls a single light switch isn’t working at all. I mean it’s so dead, even the light switch doesn’t control the relay. No clicking, no anything whatsoever. Unfortunately it’s in the basement in a dark room and trying to get it out is going to be interesting. Maybe there is some carnage in there, who knows. It was hooked up to power mains.
                                  The other exact same one is in the same room,...
                                  10-05-2023, 04:42 PM
                                • dellxps15
                                  macbook a1707 15 inch trackpad dead. blown fuse identification
                                  by dellxps15
                                  hi all, got this macbook with dead trackpad. after some investigation i found that fuse is bwlown. it's marked with a K on it. anyone kjnow it's value ? it is a 0402 package.
                                  another problem is: i tried another trackpad that was working fine, but the feedback sensor was not. all volts are present, but the click mechanism isnt .
                                  04-30-2024, 10:48 AM
