Job lot PSU no.3: SolyTech SL-8500BTX
  • Khron
    • Sep 2006
    • 1350
    • Finland
    This one had a post-it on it saying "Dead". Visual inspection through the rear grille - fuse blown to smithereens This, disregarding the fact the silkscreen only specs the platform up to 400w (despite it being marketed as a 500w unit)
    After removing the board from the casing, first step was removing the fuse (see picture no.1), and soldering in a pair of those metallic fuse holders. Popped in a 6.3A fuse, and hooked up the whole thing through a bulb-tester. No flash, no nothing; measured the 5Vsb, meter said 1.8v
    Moment of revelation - with the passive PFC coil removed, there was only a 1.8u film cap in series, supplying AC to the rectifier bridge Soldered in a jumper. Result = 5Vsb = 5.063v, but bulb is lit quite strongly, and flashes at some frequency (~50Hz-ish or so). Voltage across the pair of main caps is around 250v DC, which is on the worryingly low side (should be around 320v or so).
    Platform data:
    PWM = 2008Z
    Passive PFC
    2x 80mm fans
    Caps = YC
    5Vsb = two-transistor (PN2222A / 2N60)
    Switchers = 2x TOP3 13009's (half-bridge)
    Quite a "vintage-design", still has silkscreening for -5v
    Without having removed the primary silicon, nothing measures shorted (switchers or 5Vsb fet).
    I should mention i've already replaced the 10u "critical"(?) cap on the 5Vsb primary, the two filter caps for it on the secondary, and a 47u (filter for the base drive transformer supply) and a 10u (PWM supply filter).
    Any thoughts?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Job lot PSU no.3: SolyTech SL-8500BTX
    Same "flashy" behaviour even with all three primary transistors out...
    Yep, primary silicon (on the extracted heatsink) checks out just fine.
    Culprit: one shorted diode in the 6A 600v bridge (1,6mV drop, as opposed to ~550mV for the other three healthy ones)
    Popped another PBU605 (6A 600v) bridge in, normal "single flash" upon plug-in
    Primary silicon/heatsink back in, no lit bulb, 5Vsb = 5,063v
    Plugged in a fan, shorted green to ground, et voila, it lives once again 5.17v, 3.335v, 12.325 (with only a fan loading the 12v).
    Recap coming up Some Panasonic FK's on the 12v, and i'll see what i can scrounge up for the 5v & 3.3v rails :P:
    • everell
      • Jan 2009
      • 1514
      Your psu is similar to my Solytech SL-8460 BTX. To compare the two check out this thread:
      https://www.badcaps.net/forum/showthread.php?t=11416
      Toward the end of the thread I made a drawing of that 2008 chip.
      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Thing doesn't look bad except for the trashy YC caps. I'd recap it! Nicely sleeved cables too. Did you solder those Sanyo caps onto it?
        • Khron
          • Sep 2006
          • 1350
          • Finland
          Yep, slapped that pair of Sanyos on the 5Vsb, a couple of Panny FK's on the 12v, and a pair of Ruby MBZ's on the inputs of the 3.3v and 5v pi-filters, and another pair of Sanyos on the outputs. I know, i know, MBZ's might be a bit too low-ESR, but i didn't have anything else low-ESR at 2200u in 10mm cans (and i figured going down to 1500u wouldn't have been too good, for the pi filter inputs)...
          Slipped in a Panny FR to replace the -12v cap, although i skipped a few of the tiniest caps (3x 0.1u near the 2008Z, the pair of 2.2u in the bases of the main switchers, and one or two more i couldn't see the value of, in the middle of the PCB)
          • everell
            • Jan 2009
            • 1514
            Possibly of interest, the 2008Z chip is an extension of the 2003/2005 chip series in the older L&C power supplies. I have a Raptor brand 400 watt psu which is a L&C OEM, model number LC-B400ATX, circuit board marked X2005B, ATX ver 1.2. Interesting thing is that the silkscreen printing on the component side indicates that the pwm chip can be either a 16 pin or a 20 pin chip. The Raptor has the 16 pin 2005 chip installed.
            I did some experimenting on my LC8460BTX and removed the 2008Z chip and installed a 2003 chip. It worked. So it appears that the 2003 and 2005 chips are interchangeable, and the 2003/2005 can be installed where a 2008Z was.
            The extra 4 pins on the 2008Z are for overcurrent protection for two 12 volt rails, the 5 volt rail, and the negative rails. So putting a 2003/2005 chip in its place removes the overcurrent protection for the power supply. Bet they charged lots of extra $ for that feature!
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              Just to chime in as me and the OP had a chat on YM during the recap - i measured a good YC 2200uF 16v cap and it came in at ~19mOhms, same for a 2200uF 10v. So Rubycon MBZ isn't too low ESR, especially since i did my measurements at room temperature, and ESR decreases with temperature rise.
              Before you ask... Yes i do have an ESR meter which goes that low. As a matter of fact, it's got 0.1mohm resolution. I made it myself, i talked about it a while back. Still haven't gotten around to a redesign and a case, it's still finicky. It requires wifi coax for the probes. The 4 cables have to be run next to each other, only separated at the tips as otherwise it won't show 0 with the probes shorted due to electrical induction. But it works.
              A working TV? How boring!
