SLOT-A cleaning
  • parttimebill
    • Aug 2006
    • 15
    SLOT-A cleaning
    I pulled a slot-a (A0750MPR24B) out of a 'working' GA-71XE to blow the crud out of the heat sink... and now it won't power on... did I miss something stupid???
    regards, billl
  • Rainbow
    • Aug 2005
    • 1372
    Re: SLOT-A cleaning
    Have you pushed it hardly enough so that it's fully seated in the slot? It can be hard on some boards.
    • parttimebill
      • Aug 2006
      • 15
      Re: SLOT-A cleaning
      I think so, but I'll re-seat and try again...thanks I was afraid I had missed some interlock or something ;-) billl
      • rumi409
        LG OLED C1 Pixel Cleaning Made Picture Worse
        by rumi409
        ​​​​​​ Hi,
        I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
        11-15-2024, 01:09 AM
      • howardc64
        Macbook Dust-Gate Preventive Cleaning
        by howardc64
        Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
        Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
        https://www.ifixit.com/Guide/MacBook...leaning/177920
        10-09-2024, 10:10 AM
      • claws77
        lenovo flex 5 14ITL05 laptop keyboard cleaning
        by claws77
        are there any resources that talk about cleaning keyboards thoroughly, by that i mean removing keycaps and cleaning.
        i am worried about breaking those keycaps or the plastic retainer clip.
        08-12-2024, 07:46 PM
      • loopster
        Need help cleaning ME region on Zbook 17 G1 bios dump
        by loopster
        Hello guys,
        could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
        Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
        I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
        Error 10: Failed to open with processed commands.
        Unable to open file: C:\Users\Elitebook...
        06-16-2024, 09:57 AM
      • Lykos
        Acer Predator Helios 300 PH17-54-75K8 no POST after cleaning/repaste
        by Lykos
        I had an Acer Predator Helios 300 PH317-54-75K8 (MB 6050A3087503-MB-A01(A1)) brought by a client for internal cleaning due to overheat.
        Easy laptop, simple proccess, I have done it hundreds of times (literally), didn't even need to remove the motherboard. Just disconnected the battery, the fans, carefully removed the heatsink not to stress CPU and GPU, cleaned, repasted and put back together.
        After I assembed it, to my ultimate surprise, the laptop didn't POST. Keyboard backlight lights up, screen does a momentary flash, and then nothing.
        It did a sound on POST when...
        05-25-2025, 02:53 PM
