Have an Antec 450W "SmartPower" that is dead
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Computer was brought in that wasn't powering up, saw the Stupid Power sitting in there and knew why When plugged in all it gives is a high pitch whine, and when unplugged slowly fades quieter until it's silent. Does this mean that the 5VSB is working? It has an Asia-X cap on the 5VSB and the rest of the caps consist of Teapo, Koshin, Fuhjyyu, the primaries also being Fuhjyyu I dusted it out and removed some glue in it, I'll upload some pics
  • c_hegge
    • Sep 2009
    • 5219
    Re: Have an Antec 450W "SmartPower" that is dead
    The whine usually means that the 5vsb is running, but with excess ripple. Give it a complete re-cap (including all of the really small caps) and it should be fine.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Awesome, so you just think that since they're all terrible brand caps that some of them failed without bulging? Should I replace the input caps too?
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        The small caps fail without bulging. They just dry. The big primary caps can also dry without bulging. If you own an esr meter test every cap!
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Okay, I'll replace what I can with the caps that I have now and see if it works, and order some in the meantime and recap the entire thing later. Makes sense, where can I get a good ESR tester for a decent price?
          • larrymoencurly
            • Oct 2004
            • 960
            I had 3 Antec SmartPowers in a row fail from bad caps in the 5Vsb, and all the others I had showed bulging Koshin, Teapo, and Fuhjyyu in that circuit. Only the Asia-X caps looked and measured OK.
            • LDSisHere
              • May 2012
              • 727
              • U.S.A.
              The SmartPower I am working on was making the same type noise when power was applied. Before proceeding you may want to check the 5VSB voltage level to see how high it is getting. If it is getting too high it will have damaged other components that will have to be replaced. I am currently chasing down the bad ones in mine that were damaged by over-voltage.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                I guess I'll just recap the 5VSB to start and see if that does anything. And if any of you guys know, what is the combined 12V output on these PSU's? Here are some pics for those who want to see
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  32Ampere (I just added up the 2 rails )
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Isn't it usually lower though by at least a few Amps since it has 2 rails?
                    • Wester547
                      • Nov 2011
                      • 1268
                      • USA.
                      It depends on what the rectifiers on that rail are capable of (along with the choice of capacitors and their specs), but if it's one 15A and one 17A rail it probably means that combined it's something like 22A (or 264W), though I could be wrong.
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        A brand like Antec would state such limitations on the label. By not doing that you can assume that the total 12V amperage is the sum of the 2 rails.
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Okay cool, I guess it's worth the recap then
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Decided to test the 5VSB and it gives out 0.00V...so pretty sure sign it's the caps?
                            • s_henya
                              Antec VP-600P and NE550M dead
                              by s_henya
                              Got in these 2 nice PSUs, both died after power surge.
                              Both seems to be suffering from the same fault.
                              Blown main fuse
                              Shorted N mosfet 550v
                              VP-600P: 5R280CE short between GDS
                              NE550M: MDF18N50 short between GDS
                              In terns of board layout these seems pretty identical.
                              From past knowledge, once gate get shorted, most likely the for the driver to go bad as well.
                              I never tried to salvage blown fuse PSU with shorted Mosfet due to that.
                              Is it worth to try and replace the mosfets? is there a chance that the...
                              12-03-2024, 10:00 PM
                            • Rgyver2
                              Antec EA-430D 5VSB issue
                              by Rgyver2
                              I have an Antec ea-430d that will not turn on due to a problem with the 5VSB circuit. the TNY278PN has a burn "drain" pin (pin 4) and the two diodes (D901 and ZD901) near it look burnt with black on the board. (they were covered in that white goop which i removed).
                              The TNY278PN needs replaced and likely the 2 diodes as well. I found the TNY278PN, but need to know what to order to replace diode D901 and the zener diode ZD901.
                              From reading other posts, it seems wise to also replace the large 450V 270uf cap.
                              The diode info and any other advice of what else to...
                              04-18-2021, 12:00 AM
                            • double_DD
                              How can I be sure that my EC chip is dead?
                              by double_DD
                              As the title suggests, how can I be sure that my EC chip is really dead?
                              I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                              Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                              03-12-2025, 07:47 AM
                              A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                              by momaka
                              More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                              And a shot of the label:...
                              01-26-2022, 03:26 AM
                            • прямо
                              Viper22A 5VSB circuit
                              by прямо
                              So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                              In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                              01-13-2024, 07:05 PM
