Antec 350 Recap Epic Fail
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    #41
    Re: Antec 350 Recap Epic Fail
    Those Nichicons look fake.
    A working TV? How boring!
    • Behemot
      • 4845
      • CZ
      #42
      Having polychromatic image would definitelly help judging. In this can size, ultra-low ESR caps are on most motherboards.
      Can you share color images with series marks and vent of those Nichicon caps?
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        They might be.
        It appears that the color/ink of the label is silver, although I have a hunch that that is b/c the camera's flash was used.
        The curled wrapper at the top (the vent end) looks strange.
        Replacing with a smaller cap might be fine. Two reasons it might not be fine: 1 - smaller cap has higher esr. 2 - less surface area to dissipate heat. I think that it would be VERY rare for this to be a problem, so I say go ahead and do it
        Muh-soggy-knee
        • nickBcap
          • Jan 2012
          • 114
          • New Zealand
          #44
          Series: VZ(M), 105C, H0812, 8mm DIA x 12mm H.
          Will post a color photo soon when I can.
          • nickBcap
            • Jan 2012
            • 114
            • New Zealand
            #45
            Here is the capacitors in color this time. The black and white photo may have not shown their true colors.
            • Behemot
              • 4845
              • CZ
              #46
              Font and text seems genuine on the Nichicon, what shape does its vent (the top part) has?
              • Heihachi_73
                • 713
                Actually, the font on that "Nichicon" cap looks like it's in Arial, specifically the numeral 1 in "H 0812". Most Nichicon caps I've seen use Univers, which is slightly more square/narrow than Arial. Also, the "VZ( M)", why the odd-looking space?
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Good catch on the odd spacing.
                  These MIGHT be fake ... but they are pretty good looking fakes xD
                  Muh-soggy-knee
                  • nickBcap
                    • Jan 2012
                    • 114
                    • New Zealand
                    #49
                    The vent looks very much like any other vent I see on most capacitors I have seen.
                    Uploaded with *************
                    QUOTE: Actually, the font on that "Nichicon" cap looks like it's in Arial, specifically the numeral 1 in "H 0812". Most Nichicon caps I've seen use Univers, which is slightly more square/narrow than Arial. Also, the "VZ( M)", why the odd-looking space?
                    Looking closely at the two number 1's they appear to be the same. The photo may be deceiving the eye for the angle it is shot at.
                    Something interesting now that Fake has come into the topic, the outer of the capacitor has a twist in it and only on both side of it. It runs from the bottom of the 1 in the 105 up through the 0 and 5 and the o nd 0. Also on the top the cover is raised for about 2mm over the vent on the edge. Pointing to a low quality product.
                    I think these are new and dont think they have been removed from another product, the wires are clean with a few tiny patches or corrosion or rust, dark grey spots which I have seen on cap wire bought as second hand capacitors.
                    Last edited by nickBcap; 12-16-2012, 12:57 AM. Reason: adding information/ adding photos
                    • Shocker
                      Banned
                      • Dec 2011
                      • 635
                      #50
                      You mean a "cross"-shape???
                      If so, that's the correct vent for Nichicon.
                      EDIT: That doesn't really matter, because VZ series is not low ESR.
                      • Behemot
                        • 4845
                        • CZ
                        #51
                        Yeah, VZ is general purpose.
                        • Sus256
                          HISENSE 65E7KQ PRO - no boot
                          by Sus256
                          Hi all!
                          HISENSE 65E7KQ PRO
                          RSAG7.820.13512 - chassis
                          MT9618BAATAB - cpu
                          RSAG7.820.12059 - power
                          HD650Y3U77 - panel
                          KLM8G1GETF - emmc
                          The TV does not turn on, the standby indicator is on. All voltages are present.
                          Emms is dead. Not readable, not detected.
                          Replaced emmc.
                          But with another dump there is no launch
                          Terminal log
                          UART
                          AC_ON
                          RPMB key is not yet programmed
                          HASH1_VERSION=0x00000000 64bit
                          E-B
                          FDE enabled
                          layout pattern onebin by SAR7,0...
                          06-01-2025, 02:11 AM
                        • harp
                          Metod for removing glued heatsink from fragile component
                          by harp
                          I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                          06-23-2025, 02:01 PM
                        • Ven
                          Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                          by Ven
                          I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                          The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                          I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                          If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                          07-08-2024, 09:32 AM
                        • piernov
                          Core 2 "gaming" build with SLI
                          by piernov
                          My turn to post a build I guess, wasted way too much time on this one…
                          First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
                          Everything done with random parts I had lying around.
                          Specs :
                          • CPU: Core 2 Quad Q9450
                          • RAM: 2x2GB KHX6400D2K2
                          • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
                          • MB: P5N-E SLI
                          • PSU: Antec Basiq Power 550 Plus
                          • HDD: Hitachi Ultrastar A7K2000 1TB
                          • ODDs: DVD ROM, DVD RW
                          • Case: not sure
                          Cooling:
                          • 92mm rear fan
                          • 120mm front fan
                          • Additional heatsink on southbridge
                          05-20-2023, 11:38 AM
                        • harp
                          can fanless heatsink replace poor original on RX26PG2
                          by harp
                          I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                          06-25-2025, 10:56 AM
