What could cause this PSU to output 12.5V on the 12V?
  • c_hegge
    • Sep 2009
    • 5219
    Re: What could cause this PSU to output 12.5V on the 12V?
    That's odd. The Jilin Sino datasheet (their real manufacturer, going by the logo in post 51) says 12A for the D304X
    • Wester547
      • Nov 2011
      • 1269
      • USA.
      #62
      ^ Whoops, my bad... I noticed the datasheet says 3DD304X, though, whereas the one I URLed just says D304X.... sort of confusing to see conflicting data but you're right since it's the manufacture of the switchers in the PSU in question.
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Originally posted by momaka
        105 = 1 uF. The 1.0 signifies it's a 1uF as well. So they are the same. K means 10% tolerance.
        As Th3_uN1Qu3 mentioned, the snubber is a large resistor and a ceramic (or sometimes polypropylene) cap in series with that resistor. From the picture you provided above, that would be large 47 Ohm resistor and that ceramic cap behind it (C4). Check me on that, though. They should be in series and together connected across the primary side of the main transformer.
        May also want to transplant the snubber diodes that are across the BJTs from the donor PSU if they are of a bigger current rating and have at least the same or higher voltage rating.
        Awesome thank you for the info, I thought that was the bleed resistor, stupid me the snubber diodes would be on the other side of the heatsink?
        Originally posted by c_hegge
        No, unless the 13009s are TO-3P or TO-247 while the D304Xs are TO-220. Both of them are rated for 12A, so assuming they are the same size, neither will handle more than the other.
        They are BJT ST 13009's, I got a few of them off of Digikey. Like mentioned I should probably just upgrade the secondary silicon and transformer. Excited to try the new transformer tomorrow!
        • c_hegge
          • Sep 2009
          • 5219
          Yeah, they are all BJTs. I meant their physical size. I can see from post 51 that the 304Xs are TO-220 size (the smaller size). Are the 13009s the same size (TO-220)? or are they physically bigger (TO-247/TO-3P)
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Oh gotcha, they're the same size
            • c_hegge
              • Sep 2009
              • 5219
              I wouldn't worry about replacing them, then.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Finally got some time for this, before I plug it in with the new transformer what are the chances it could explode into a fiery wake?
                  master hoarder
                  • May 2008
                  • 12176
                  #68
                  If it's not the right transformer - high.
                  Put a light 60W bulb in series with the live AC line going to the PSU. If anything is wrong, you'll get fully lit bulb and no explosions. If you do that, though, don't put more than a fan or two for a load on the PSU because the bulb will start dropping too much voltage for the PSU to keep up.
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    It wouldn't just pop the fuse? That's cool, how would I do that? I've never done that before
                      master hoarder
                      • May 2008
                      • 12176
                      #70
                      Get a 40W to 100W incandescent light bulb and some wire. See attached diagram for wiring (all MS Paint style ).
                      NOTE: BE EXTREMELY CAREFUL AROUND THE BULB WHEN IT'S PLUGGED IN!
                      No, because the light bulb is in series with the PSU. So if any component in the PSU tries to pull too much current due to a fault, the impedance of the PSU will become much lower relative to the bulb's impedance. This will make the light bulb glow. It pretty much works like a simple series resistor voltage divider.
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Wow thank you for the awesome diagram!! can I use any old wire? And I meant if it didn't like the transformer the fuse wouldn't just blow?
                          master hoarder
                          • May 2008
                          • 12176
                          #72
                          Nope, fuse won't blow. With a 40 to 100W bulb, the bulb will pull about 0.33 to 0.83A of current. The fuse is rated much higher than that so it will never blow. However, the overloaded components could still overheat and die, so if the light bulb becomes fully lit and stays lit for more than a few seconds, unplug the PSU immediately.
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            Okay, thank you for the info
                            • mariushm
                              • May 2011
                              • 3799
                              #74
                              Also use some decent wire, not network cable or IDE wires... something at least the size of the 12v cables in the power supply.
                              If you don't have a socket to put the lightbulb in, use a lot of electrician's tape to insulate any metal you could touch.
                              Smartest thing would probably be to put the lightbulb in a ceramic mug or something similar.
                              • 999999999
                                • Sep 2006
                                • 774
                                Or just build it safer using a standard electrical box, pigtailed bulb socket, grounded AC socket, extension cord with a strain relief where it enters the box, and solid core 14 ga. wire with wire nuts as needed.
                                Electrical taping AC mains wires to a light bulb seems a little sketchy.
                                • mariushm
                                  • May 2011
                                  • 3799
                                  #76
                                  That's not what I meant. I meant solder the wires onto the bulb, then insulate everything using tape.
                                  But I agree using sockets and taking safety measures is a very good thing.
                                    You make a little box for it like this if you plan to work on alot of electronics.
                                    http://s807.photobucket.com/user/bud...82195675176907
                                    • mariushm
                                      • May 2011
                                      • 3799
                                      #78
                                      Here's what I bought a couple of months ago, but i never got around to build a box for.
                                      It's a socket that converts the regular house bulb to the upper diameter socket (which are usually for 250-400w bulbs).. but the basic idea is that the top is plastic so no (or minimal risk of electric shock) and I can screw the wires to the socket.
                                      Just have to make a box and cut a circle on the top to put the plastic circle through and add a double switch to the panel to turn off the power and it's done.
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        Thanks for all the knowledge on how to do this safely, I will try this when I get some more free time at work
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8716
                                          Just as a word of warning and maybe for the comical effect:
                                          Don't use a CFL or LED light bulb for doing this
                                          There's another thing these black body radiators are good at
                                          • FrancescoV
                                            Onkyo HT-R390 no sound output, video output ok
                                            by FrancescoV
                                            Good morning everyone,
                                            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                            The firmware reported is the following:
                                            M:1.00/11107BLP
                                            D:?.??/????????
                                            O:1.00/11107AL
                                            The DSP firmware given the question marks seems corrupt.
                                            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                            05-11-2025, 02:59 AM
                                            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                            I bought this from an eBay seller but unfortunately they only had one
                                            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                            I bought three of from them to also make battery packs with this output power limit in mind
                                            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                            04-23-2025, 05:50 AM
                                            Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                            by momaka
                                            Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                            So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                            09-19-2021, 08:44 PM
                                          • CoppellTVRepair
                                            Troubleshooting PFC with SPC1012T not raising output
                                            by CoppellTVRepair
                                            It has been a long while since I posted here to ask anything....hope you can help.
                                            I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
                                            I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
                                            03-09-2025, 10:38 PM
                                          • flibidy
                                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                            by flibidy
                                            I have here a Magnum IA.100 which belongs to my parents.
                                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                            What Ive done........
                                            01-01-2025, 01:26 PM
