I get free psu's all the time. When you guys get a free psu or whatever, and you open it up and find, say, Jamicon, OST, Teapo. Do you guys recap them even if the power supply is working fine and all the caps look good? Or do you wait for some to die?
How often do you guys do a preventative recap?
Re: How often do you guys do a preventative recap?
When I bought a new PSU for my PC, whitin three weeks, it had new caps. I bought a new Acer monitor about one year ago, first thing after removing the packeing, was to re-cap it. I didn't even plug it in first. -
that's hilarious
in the acer, were they CapXon?
Same here, be it monitor, PS, MB, TV, or any electronic device."pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!
It depends.. I have several decent psus, all of them fully recapped and fan-modded when needed. Now, I also have 3 true-400Watt psus with badcaps that I am going to recap only when/if I need them and some 200-250-300watt that are not worth a recap with Japanese capacitors. Those if they have bulging caps they get used Chinese/Taiwanese caps as a replacement
Good logicIt depends.. I have several decent psus, all of them fully recapped and fan-modded when needed. Now, I also have 3 true-400Watt psus with badcaps that I am going to recap only when/if I need them and some 200-250-300watt that are not worth a recap with Japanese capacitors. Those if they have bulging caps they get used Chinese/Taiwanese caps as a replacement
Although I have a recapped Allied running 24/7...I guess kind of a waste of good caps but it seems to be doing well and has a Globe Fan
Well, me too! I have recapped that Premier DR-8400BTX, even though it would never do more than 250Watt continuous.
At least I used Teapo at 3.3V and 5V
Dang, nice improvements to that PSUWell, me too! I have recapped that Premier DR-8400BTX, even though it would never do more than 250Watt continuous.
what's it powering?
It used to power a Pentium D 2.66 (dynamic overclocking up to 3.2GHZ), 1.5GB DDR2 Geforce 7600GT, TV Card, Sata HDD, DVD-Rom and DVD-RW, until I got for free a lot of Jou Jye psus 460 and 400W, that I recapped and repaired. Now I use it for testing motherboards.Comment
I preemptively recap almost everything I get. Sometimes I use stuff for a year or so if its brand new, but anything used gets re-capped before I use it (unless it has good caps to start with). Even teapoo go straight in the fire (or maybe to my bench PSU with the + and - reversed).I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
I will recap any thing new that has a switching power supply
If I want to keep it a long time
..... and........
IF this item has know BAD BRAND caps
....... or............
I have never heard of the brand before
Then all of the caps will be replaced
Case in point I just bought a new switching power supply today and two of these brands I have never seen before ALL the caps in this power supply will get replacedLast edited by sam_sam_sam; 09-15-2012, 03:11 PM.Comment
Dang, nice, and it's been powering that for quite a while?
Sounds like a good idea cause bad caps could fail in 6 months or even 2 years. Unfortunately last week when I was recapping a Bestec ATX-300-12Z, most of the caps I had were too big to fit on the secondary. It had OST and Jamicon, so I replaced all the Jamicon's and left the OST. They used Jamicon for the 12V filtering so I'm hoping it lasts a while
I noticed some strange behaviour when running intensive 3D games or benchmarks. That went away when I replaced it with Joy Jye 460W psu.
I blame that on the fake input caps that were yc 330uF 200V but their real capacitance was 220uF...
I don't know. From my experience Jamicon are definitely better than most of the known bad caps. I would put Jamicon on par with OST, Ltec and who knows maybe Teapo.Last edited by goodpsusearch; 09-17-2012, 04:38 PM.Comment
Jamicon would probably last in low-stress and low-heat situations - they're still going strong on all my Sound Blaster cards. But that's the best you'd do with them, I think.
I've always wondered why small capacitors with inferior aluminum seem to be more prone to failure in PSUs than on motherboards. I've heard some say they're less likely to fail on motherboards because they don't take as much ripple but I always thought they were subject to a much larger surge current on motherboards then in power supplies... but then power supplies get hotter and have arguably less room to dissipate heat so maybe that's worse?Comment
If it works well, I let it be. I don't buy new stuff so I don't do preventative recaps on that. As for old stuff - if I think I will be using it for a while and the caps are really really crappy (i.e. CapXon or Rulycon) or if there is even 1 bulged cap, I will recap most or all of the caps in that device.
Also, like goodpsusearch, I have a bunch of cheapo power supplies that aren't really worth recapping with Japanese capacitors, so I put used-but-not-bulged caps in them. It's good enough for testing.
Also have this L&C PSU which I partially recapped with Japanese caps:
https://www.badcaps.net/forum/showpo...&postcount=490
Originally, I was going to replace all of the secondary caps inside with Japanese ones, but then I got lazy and figured it wasn't worth it. Seems very stable and my old Pentium 3 PC is happy with it. 5V rail is dead on 5.00 to 5.01V, as is the 5VSB.Comment
by momakaHere’s another motherboard that needed a full recap: an ASUS P5GC-MX.
This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
So here is what the motherboard looked like with its original caps:
CPU VRM area up close…... -
by momakaI've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
This one was actually suggested to me by ChaosLegionnaire.... -
by FoetussHi all
Hope this is in the correct place.
I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
Could use some double checking to see if I'm not doing something stupid
Pictures of the boards are attached.
What I will be replacing with what : (planned)
Soltek Golden ::
4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...2 Photos-
by zmeutulhey guys I need a bios for 6-77-NP50PNJY-D02B-3C.With the current one, the laptop does not start. I am also attaching the original bios. Thank you!...
Channel: BIOS Requests ONLY!
Got 4 CCFL 16/10 monitors for free.
The resolution is almost Full HD (1680x1050)
VGA Input only is a bummer though.
Uses cheap TN panel with terrible viewing angles.
Even though this is not 17" 5:4 screen, still has very low resell value here. Can be found for 15-20 euros.
All the 4 monitors were not working and needed psu recap. Used mix of mediocre / junk caps to recap them, then donated 3 of them to friends/relatives and kept 1 for myself. Also like to install extra caps on empty spaces to help them last longer.
- Loading...
