I'm recapping an FSP power supply which had 7 CapXon caps (6 were bulging) since this is a really small PSU, the UCC KY caps I have are too big to fit. For the 1000uf 16V CapXon caps, I have 680uf 16V UCC KY caps that are the EXACT same dimensions as the 1000uf 16V CapXon's. Since CapXon are terrible, do you think the 680uf 16V caps would be as good if not better at filtering?
Replacing CapXon's, wondering what lower version of UCC is equivalent
Re: Replacing CapXon's, wondering what lower version of UCC is equivalent
Get the series code from the capacitors, read the specs from the Capxon datasheet and compare with UCC datasheets...
What else there is to say? Without a series code, it's too little information. -
Capxon KF 1000uF 16v : 10x20 , 1350 mA , 0.065 ohm
The closest would be LXZ series: 1000uF , 1220 mA , 0.052 ohm ( page 136)
I think you'll be fine with KY though... it's not too low esr.Comment
by ReintarFirst of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...08-30-2024, 06:13 AM -
by NoodneekMy 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...-
by LENOVO-A880Hi! I hope someone can help me out cause I'm looking into replacing one of the barrier diode that is faulty on my VDO odometer circuitboard due to short circuit lately. The part has marking on its body which reads "SJ" on the upper row while "39" on the lower.
Close-up photos included for the part and the numbers but the problem i can't find this part for sale anywhere. Oh! I don't even know if this part has any datasheet available for free online. So I wonder does anybody know any suitable replacement ot something equivalent to it?
Thanks ahe... -
by m1ch43lzmHi, i have this RadioShack IR thermometer Cat. No 22-170 which takes 2xAAA batteriss, I've tried with NiMH AAA rechargeables but it complains about low voltage, it flashes an "empty" battery and doesn't measure anything, even with freshly charged 2xAAA NiMH, so i have to "borrow" the batteries from my multimeter when i want to use it
I'm thinking abour replacing the 2xAAA batteries with a small LiPo battery that fits inside that space, but the voltage would be too high (4.2v)
I'm open to suggestions on whether i should use an LDO or another type of voltage... -
by ktmmotocrossHello.
I was replacing ALC660 on asus x58c two times but still no sound with new chip, but works with original with bad sound. Nex time i replace audio ic in hp 840 g5 and again not work with new chip.
So is there something special needed when replacing audio ic? - Loading...
