Replacing CapXon's, wondering what lower version of UCC is equivalent
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    I'm recapping an FSP power supply which had 7 CapXon caps (6 were bulging) since this is a really small PSU, the UCC KY caps I have are too big to fit. For the 1000uf 16V CapXon caps, I have 680uf 16V UCC KY caps that are the EXACT same dimensions as the 1000uf 16V CapXon's. Since CapXon are terrible, do you think the 680uf 16V caps would be as good if not better at filtering?
  • mariushm
    • May 2011
    • 3799
    Re: Replacing CapXon's, wondering what lower version of UCC is equivalent
    Get the series code from the capacitors, read the specs from the Capxon datasheet and compare with UCC datasheets...
    What else there is to say? Without a series code, it's too little information.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Alright, sorry. They're KF series. The ripple is much lower on the KY
      • mariushm
        • May 2011
        • 3799
        Capxon KF 1000uF 16v : 10x20 , 1350 mA , 0.065 ohm
        The closest would be LXZ series: 1000uF , 1220 mA , 0.052 ohm ( page 136)
        I think you'll be fine with KY though... it's not too low esr.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Thanks mariushm
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            After being recapped, it's getting much better readings on the voltages. the 12 dropped from 12.3 to 12, the 3.3 went from 3.4 to 3.3, and the 5 went from 5.3 to 5.1
            • Reintar
              Dell Inspiron 15 7567 (LA-D993P) - No power after replacing blown inductor and shorted mosfet advice needed
              by Reintar
              First of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
              One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...
              08-30-2024, 06:13 AM
            • Noodneek
              Replacing all the caps on the BenQ SW2700pt's power board didn't help...
              by Noodneek
              My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
              I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
              08-30-2024, 12:52 PM
            • LENOVO-A880
              Need help to buy replacement for toasted diodes
              by LENOVO-A880
              Hi! I hope someone can help me out cause I'm looking into replacing one of the barrier diode that is faulty on my VDO odometer circuitboard due to short circuit lately. The part has marking on its body which reads "SJ" on the upper row while "39" on the lower.
              Close-up photos included for the part and the numbers but the problem i can't find this part for sale anywhere. Oh! I don't even know if this part has any datasheet available for free online. So I wonder does anybody know any suitable replacement ot something equivalent to it?
              Thanks ahe...
              06-14-2023, 10:30 PM
            • competition
              Replacing capacitors in Evga PSU
              by competition
              I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
              11-14-2025, 11:12 AM
            • ary89
              Richtek RT6575DGQW Equivalent
              by ary89
              i need to know equivalent and pin to pin similiarities for RT6575D, i have Asus ROG GL503 from 2017 won't charge and power on, 19v present, put the charger on and with thermal camera, that ic getting hot
              11-12-2025, 09:44 PM
