I got this power supply out of a parts system that didn't work. The PSU was the reason the computer wouldn't start. With the unit out of the system, I get 5vsb power but shorting the green and black leads on the 24-pin connector does nothing. The unit uses a mix of Teapo, Jamicon, and OST capacitors, none of which are bulging. The unit uses a DM311 chip for 5vsb, no two-transistor design in this one! This would be a decent power supply if it worked. It originally came in a Acer Veriton system. The original motherboard from the computer worked just fine. Really clean inside too!
FSP FSP300-60THA(1) will not start...
Cube Computer Company - Fulfilling Dreams... One Computer at a Time.
Link to CubeComputerChannel on YouTube:
http://www.youtube.com/user/CubeComputerChannelTags: None -
Re: FSP FSP300-60THA(1) will not start...
Where do you see the DM311? I've found them in 350PN, but I could not find one in the 300THN.
My suggestion would be to do a total re-cap. -
The DM311 is located between the 5vsb transformer and primary heat sink, like on all FSPs with DM311 5vsb circuitsI love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
Yes, I've found it on other models. I have two models here though, 300THN-B204, and Z350-08ATA, they don't have the DM311. Only chip I can see in that vicinity is the optoisolator.Comment
I have this exact same power supply that I got as part of a non working system.
Same problem, I have 5V standby, but no other voltages when jumpering green to black. On mine, it had an obvious bad cap. The cap at C13 is a Capxon 3300uF 16V was clearly bloated. I changed it out, but still no go. I'm not too motivated to change out the rest of the caps right now. I would rather troubleshoot by measuring voltages than doing a blind recap.
I also find troubleshooting ATXpower supplies difficult because getting my multimeter probes in certain areas is impossible given the tight fit, the vertical daughtercards and lack of documentation on some of those custom chips.
The original owner took out the DRAM, hard drive, but left in an Intel Quad Q6600. So thanks to the power supply failing, I got a Quad core system so I can't complain.
PS. I think you are the same guy that does
If yes, great job on your channel. I watch your videos. I learned quite a bit from your channel.
--- end sig file ---Comment
Yes, I run CubeComputerChannel, and I'm glad to hear that you've learned some things from my videos! For those curious about the DM311 chip, I have a picture of it posted in my attachments on this thread.Cube Computer Company - Fulfilling Dreams... One Computer at a Time.
http://www.youtube.com/user/CubeComputerChannelComment
I fixed mine. See
https://www.badcaps.net/forum/showthread.php?p=262730
for details.
PM/email sent to you as well in case you are not subscribed to your thread.--- begin sig file ---
We repaired one of these today, the fan had stopped and a few output caps had bulged but replacing those didn't help so my tech re-capped the entire supply, still no joy. Then I started wandering around the board with my ohm meter and found one of the main transistors E13009 was leaky. Not shorted enough to blow a fuse or anything just leaky enough that it wouldn't run. I asked my tech if he checked them and he said he had with his (digital) meter and not seen anything funny. My old Simpson 260 analogue meter found the problem yet again.
Lesson of the day: don't overlook your main power semis just because your fuse wasn't blown.
Sub-lesson: An analogue meter can be much better at seeing leaky semis than a digital one.
JayArrComment
I'd replace the caps anyway - it's 8 years old and has the same mix of questionable brands as my old (and parted out) FSP200-60ATV.
The three OST caps (two RLG 4.7uF and an RGP 10uF) I pulled from my FSP were all between 3 and 5Ω despite looking fine on the outside, and at least four Teapo caps were bulged (SEK 220uF, 1000uF and 2200uF, and one SC 3300uF).Comment
OST are strange. I have seen twice now in Powerman PSU's with 100% OST where the fan failed and about half of the little caps dried out and failed, and only a few of the filtering caps failed... (Only 50% of the failed ones bulging)
I agree though, every cap in any FSP PSU should be replaced
by ngmlI am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
This indicates an error in the communication between the outdoor and the indoor unit.
The outdoor unit is fine, so the problem is the indoor PCB.
The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
Does anybody have the schematics of this board,...2 Photos02-01-2025, 12:55 PM -
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by DrDosI have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...1 Photo
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... -
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... - Loading...
