Re: Need tips in fixing APC 1500VA UPS having buzzing noise
Some units do that, but they're cheaping it out constantly, waddaya expect.
Sorry to bump an old thread but I have bought a new APC 1500 BX1500M and it came today.
It buzzed on the battery power mode, and not just a soft buzz.
It also had a horrible transition time from AC mains to battery backup.
My old XS1000 from around 2011 does not buzz on battery power and the transition time is fast, almost not noticeable with a light bulb going.
I boxed it up and returned it within 4 hours of having it.
I suspect a stage of the inverter is open, a bad mosfet and it still runs but its not happy.
Regardless, from my hands on findings on non pro apc backups is buzzing is not good and return it if you can right away.
a slight hum on charge is normal after a outage but its only there if you listen closely. the buzz I heard today is like when you turn your washer on but you forget the water.Leave a comment:
So, you have changed the caps and you have changed the batteries, and it still remains, correct?
Just a wild tip, are all the power connections (cables, joints etc. from batteries to board/transformers) OK? Because dying batteries increase their internal resistance, and if there is some transitional resistance somewhere, maybe it has the same results.Leave a comment:
Attached is a clip of the sound that comes from the 22uF, 150V bipolar yellow capacitor when charging the batteries/online.
At 45s into the recording, I turn off the line power - notice how the noise goes away completely when it's running off batteries in the 1000VA (the one which was running when I recorded the noise). It returns/increases when I connect a heavy load to the UPS output.
I am sure you will agree this is very different from the gentle hum of a transformer?
If this is a characteristic sound of APC UPS when the batteries are dying, I would like to know if there's a battery I can buy, from say Walmart or Home Depot etc just to see if a new battery makes the noise go away.Attached FilesLeave a comment:
Do APC UPS emit buzzing noise when their batteries are dying
I replaced both the caps around the area and the noise remains.
Since the noise comes when the batteries are charging or when I make them discharge - could it be something because of the batteries themselves?
I saw these posts on the internet that suggest that could be a possibility:
The whine is usually caused by the charge circuit trying to push the charge to the damaged cells in the battery.
They screech like that when the battery in them needs to be replaced
It would be interesting to find out if APC UPS emit buzzing noise when their batteries are dying.
I hope APC UPS users can pitch in sharing if the heard buzzing noise from their UPS when their batteries are dying.Leave a comment:
Did you replace the (orange) poly cap next to it? They are wired in parallel. The poly cap should be around 2uF in value. Together you get ~22uF.
TLeave a comment:
Noise remains - perhaps a bit louder than before
Replacing the 20uF cap did not help - the noise remains, as I noted above.
I really like this unit and would hate to trash it, if it has become unsafe.
Any ideas if the unit is still good to power my Computer and Audio Receiver?
(these babies cost me $2k+ and I found it fit to put this APC workhorse to cover their back.)
I still wonder - why the noise? noise comes from the cap when the batteries are charging or when I make them discharge - could it be something because of the batteries themselves (but what?)Leave a comment:
I remove surge parts from all my strips. They do what they say which is the opposite of what you want. You want them to stop lightning. What they do is offer lightning more paths to damage your equipment.
Lately I've been removing the power switches too. By accident is the only way they get turned off. I like almost hospital grade plugs for next to nothing.Leave a comment:
http://antiqueradio.org/dimbulb.htmLeave a comment:
The original cap that is making the noise (and the one I intend to replace) is SIEMENS EPCOS 20uF 150V Capacitor.
Given that, these seem to fit the bill just fine: http://www.bgmicro.com/24uf220vac.aspx
It's the age that worries me.
Sealed caps like these are generally fine for a long time on the shelf. I would apply voltage slowly to make sure it is stable. A lamp in series with the power line. Or, try just feeding the cap through a lamp externally by itself, before installation. That would be a safer way, in case it decides to go *bang*!
If the lamp goes bright and stays that way, the cap is shorted.Leave a comment:
The title says 220vac, you're looking for 250vac. The capacitance is fine.
It's -only- a 12% difference in voltage, and for a trial to see if the noise stops, it's worth it. I would not leave it in place permanently.
Caution is advised.
TLeave a comment:
1. However, these are 12 years old (made in October 1998) - should it be good to go or it's too old to be of use?
2. I am assuming Metallized Polyester Film, specified Metallized Mylar should be better quality being a brand name and not a generic Polyester cap, or is Mylar and Polyester used pretty much interchangeablyLeave a comment:
I was afraid something like this might be up, but read on (I don't want to put in $50 in parts + a weekend of my time behind a lost cause)
Try a paper towel roll as a "stethoscope" to pinpoint the noise. Try moving components with a wood or plastic tool to see if they're just resonating from the switching circuit. It's why PSUs have that glue/caulk around coils and caps.
They make noise when making power. Nature of the beast.
Surely this confirms the source of the noise once for all?
Correct. Surge protectors on INPUT to UPS, not on output.
Having them on output side can also present a load/short to the UPS which it tries to compensate for by boosting output. A vicious circle.
I think the unit is fine and just gone a little noisy. You could replace them and the problem will remain. Because the noise is load variable, I would be scoping the output for spikes or looking further back in the circuit.
T
PS: I'm now seasick from watching that video....
Some folks have -NO- camera skills...Last edited by Toasty; 07-29-2012, 11:35 AM.Leave a comment:
Toasty, quite an insightful post
Noise may very well be from another component. Usually, by time these caps start buzzing, it's too late. I've never seen one fail. The orange drop caps nearby (also MPF) I see fail when high spikes on the line occur. Telltale is a change in color or a crack/burn in the casing.
Also, a user on this forum did a video of him repairing a similar unit : youtube.com/watch?v=mpUzHO3MGCI
This has a similar layout as mine and would give you an idea what the board is laid out like
So the noise could be from either:
1. The EPCOS cap itself
2. The chicklet caps around the EPCOS
3. Another component that is making these caps noisy (This is what I am most afraid of - that even after replacing these caps, the noise remains, as the root cause is somewhere else to begin with)
Otherwise, the UPS could likely create spikes itself in the output, which can take out MOVs downstream?Leave a comment:
Please attach pics to posts. Links to external site disappear or become broken, and the info provided by you is lost.
That being said, Epcos B32232 sheet attached. Metallized Polyester Film.
SUA1000VA is not a 1500VA UPS...? 1000va = ~670 watts / 1500va = ~980 watts
Yes, it's used for "smoothing" the output when in "running" mode.
Be nice to see a pic of the whole area. I'm assuming the pic in #3 is your unit.
Could also be noise from another device on the line this is connected to. Cheapo Chinese fluorescent ballasts radiate that and can be feeding it onto the line. Try moving it to another circuit.
You have enough "noisemakers" nearby to probably discount these as failures. I see 6 relays and several coils/chokes nearby. That entire bank of rectifiers/FETs can also be noisy at times.
DigiKey & Mouser carry some of this Epcos line, but not enough. $20 sounds about right going by their other caps in the line. That is a big mother.
T
PS: Make sure any output side power strips are -NOT- surge protected. They -say- sine wave, but spikes do occur and will quickly take out the MOVs, especially if lightly loaded.
.Attached FilesLast edited by Toasty; 07-29-2012, 10:03 AM.Leave a comment:
I know - that's because EPCOS makes them no more. See the model number on the picture I attached. Even if they did, their MOQ is 4k pieces.
In all probability, the capacitors I am going to buy are going to be generic ones with no data sheet. That's why I asked the questions in my first post to begin with and would very much like your feedback on them.Leave a comment:
I do not see 20uf rating on that spec sheet. It is a general purpose Metal Polyester film, page 6 is the one you need to look for in other cap spec.Leave a comment:
budm, according to my newbie knowledge, these UPS are designed such that it reuses the big input transformer for output too via cleverly designed relay network.
This is the datasheet of the cap: https://cdn.badcaps-static.com/pdfs/...d64d1d13ba.pdf
Unfortunately, I can't buy it a piece from the manufacturer and everyone else is charging $15+ for something inferior, and my bet seems to be to buy it from an online catalog store OR get those fan starter caps like these: http://i.stack.imgur.com/FZBrg.jpg
I have no idea what the specs for those fan starter caps could be.Leave a comment:
This UPS looks like it uses high frequency power supply inverter that is modulated with 60Hz then the high frequency gets filters out for L/C circiuts.
Basically it is AC to DC to high frequency AC modulated by 60 Hz then high frequency get filtered out to get AC since wave output. You can tell if that is the circuits being if it does not have really big transformer inside for the AC out put.
You should try to look up the spec of the original cap to see if it is non-inductive type, high pulse type, low ESR type. just match the new cap spec with the old cap spec.Leave a comment:
by stvhopHello, This is my first post so please forgive me if I miss out some vital info.
I have a problem with my HP1955L monitor from 2005.
The first thing to say is that it is still basically working, ie the picture is fine.
However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
11-07-2020, 07:13 AM -
Hi, I got this Woofer,Name TBT, which damaged its Radio module, then was added a Bluetooth module from the market(history from client). Then recently was brought to me with very low sound and heating problem. I changed subwoofer Speaker which had impedance of 1.2 instead of 4ohms rms and the bass ic KA2206B. Sound is back but buzzing and hissing sound present even when muted. How can I get rid of it?
03-06-2024, 02:35 PM -
by tony359Hi all,
2. Even with the fan running outside of the case, there is still some noise which is clearly going back to the processor via power line....2 Photos -
by MegaZACSurprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
There's some logic behind it. As soon as I select an input I get only left...-
04-23-2025, 10:09 PM -
by courtcircuitHello
I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
Removed each of tyhe boards
02-08-2025, 08:22 AM -
- Loading...
