Re: Need tips in fixing APC 1500VA UPS having buzzing noise
UPS is a true sine wave inverter; model number being SUA1000VA. I never use step sine wave types :-)
The noise seems to be from the EPCOS cap, but also could be from the chicklet brown cap to its left: http://i.stack.imgur.com/6v3u5.png
Is this UPS a true sine wave inverter or step sine wave type? Do you have full model number?Leave a comment:
I have a year 2005, APC UPS and one of the caps - an SIEMENS EPCOS 20uF 150V Capacitor - started making a buzzing noise.
This seems to be a AC, non-polarized capacitor and most local stores have it priced at ~$15 + tax!
They look like this: http://i.stack.imgur.com/CTGU5.gif
I found caps of similar rating (20uF 250V) that are $3 each: http://www.bgmicro.com/24uf220vac.aspx
Do these look like a good replacement? Please let me know if there is something better suited (but perhaps more expensive) parts.
I also had a few questions:
0. Could I also replace these caps with these ones: http://i.stack.imgur.com/FZBrg.jpg
1. Is the buzzing because of the capacitor is bad or that a different component could be failing and having a secondary, audible effect on the capacitor?
2. Should not both these caps be interchangeable?
3. What could be the function of this SIEMENS EPCOS 20uF 150V Capacitor?
To act as part of a LC filter that puts out the sine wave?
4. Should I also change the MOVs on this thing and recap parts of it "just to be on the safe side"?
5. If replacing the MOVs is recommended, what surge rating/part number am I looking for?
Any tips/hints to kepping this nice UPS running would be greatly appreciated
This post also has some relevant information: http://electronics.stackexchange.com...-buzzing-noiseLast edited by vsmGuy; 07-28-2012, 08:09 PM.Tags: None
by stvhopHello, This is my first post so please forgive me if I miss out some vital info.
I have a problem with my HP1955L monitor from 2005.
The first thing to say is that it is still basically working, ie the picture is fine.
However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
11-07-2020, 07:13 AM -
Hi, I got this Woofer,Name TBT, which damaged its Radio module, then was added a Bluetooth module from the market(history from client). Then recently was brought to me with very low sound and heating problem. I changed subwoofer Speaker which had impedance of 1.2 instead of 4ohms rms and the bass ic KA2206B. Sound is back but buzzing and hissing sound present even when muted. How can I get rid of it?
03-06-2024, 02:35 PM -
by tony359Hi all,
2. Even with the fan running outside of the case, there is still some noise which is clearly going back to the processor via power line....2 Photos -
by MegaZACSurprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
There's some logic behind it. As soon as I select an input I get only left...-
04-23-2025, 10:09 PM -
by courtcircuitHello
I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
Removed each of tyhe boards
02-08-2025, 08:22 AM -
- Loading...
