Hi, I got this Woofer,Name TBT, which damaged its Radio module, then was added a Bluetooth module from the market(history from client). Then recently was brought to me with very low sound and heating problem. I changed subwoofer Speaker which had impedance of 1.2 instead of 4ohms rms and the bass ic KA2206B. Sound is back but buzzing and hissing sound present even when muted. How can I get rid of it?
Adding Bluetooth module to Woofer buzzing noise
by stvhopHello, This is my first post so please forgive me if I miss out some vital info.
I have a problem with my HP1955L monitor from 2005.
The first thing to say is that it is still basically working, ie the picture is fine.
However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
11-07-2020, 07:13 AM -
by LEECH666Good day ladies and gentleman!
I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
I think the PSU buzzing comes from one of the coils near the bridge rectifier but... -
by AlexVGHi,
I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
(This board does not respond, only the LEDs light up in a circle.
The liquid damage is catastrophic and restoration is impractical).
(I bought this board to get the WiFi module and camera).
The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
If... -
by tony359Hi all,
2. Even with the fan running outside of the case, there is still some noise which is clearly going back to the processor via power line....2 Photos -
by MegaZACSurprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
There's some logic behind it. As soon as I select an input I get only left...-
04-23-2025, 10:09 PM -
- Loading...
