Generic AT-2005B PSU
  • pdavid
    • Jan 2011
    • 279
    • Hungary
    I recieved this psu with vented JEE caps and some snapped wires. I powered it up and laughed at the 3.3V rail which was 3.6 high!
    It doesn't look that lame so maybe it's worth fixin, I thought. The label claims 400W max output... right.
    Replaced the bad caps along with the tiny 330uF primaries and a thin jumperwire to a coil in the transient filtering. I just used parts what was laying around in the table.
    The rest looked okay. 13009 transistors on the primary, mbr3045 and mbr2040 for 5 and 3.3V Two F1620c for 12V! What a rare generous setup :p
    Powered it up and the 3V rail was still sky high. Adjusted the regulation which helped a little but as soon as I attached some load it climbed back to like 3.5V damn! It doesn't matter if I cut the 3.3 sense wire or play around with the tl431 in the 3V stabilization. Is there a way to solve this somehow?
    At least I can learn something and save it for parts.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Generic AT-2005B PSU
    That's a half decent design there. Will actually do 400W with that transformer and 13009 primaries.
    Interesting bit with the 3.3v rail there. The most that 3.3 sense does is INCREASE the voltage, so there's something else wrong. First try replacing the 431, they fail in weird ways.
    A working TV? How boring!
    • c_hegge
      • Sep 2009
      • 5219
      I tested an identical PSU and it exploded at 400W.
      • Wester547
        • Nov 2011
        • 1268
        • USA.
        I thought you needed 820uF/200V primaries to do 400W continuously (or 680uF, without PFC and/or a passive PFC), and it looks like the 330uF's were replaced with 470uF's. 400W max can be achieved with 470uF/560uF (200V) primaries with a good enough transformer (unless you can at a line voltage of 230V)?
          master hoarder
          • May 2008
          • 12164
          • Bulgaria
          Looks like a Sun Pro (judging by the "TB" marks on the transformers). generally, I really dislike their PSUs, but this one doesn't seem too bad.
          From what I can see in the pictures, the 3.3V rail on this PSU uses a saturation coil, not a MOSFET in a linear setup with a 431 shunt (if it was, you wouldn't see that toroid next to the middle transformer).
          The only thing I can think of is to put a bigger minimum load on the 3.3V rail. Try a 33 Ohm 1W resistor. If not, try 25 Ohm 1W resistor. If that still doesn't work, take out that coil next to the middle transformer and add a few more turns on it.
          • pdavid
            • Jan 2011
            • 279
            • Hungary
            Thanks everyone!
            I'll see about the tl431 and the coil. If it works out then I'll put some decent caps there plus 680uF primaries. Too bad I won't be able to fit 820 caps, since the ones I can get are too tall and sort of block the fan.
            • pdavid
              • Jan 2011
              • 279
              • Hungary
              Replacing the shunt regulator fixed it! I just noticed that it was running kind of hot too. I think Yageo sy caps are good enough for this thing. I'm going to test the unit... hopefully it won't blow up.
              • c_hegge
                • Sep 2009
                • 5219
                This PSU is indeed a "high end" Sun Pro. I wouldn't trust it with more than 350W.
                • dmill89
                  • Dec 2011
                  • 2534
                  Yep, It is virtually identical to the TM-350 I rebuilt and upgraded a while ago in basic design, with the exception of the overhead 120mm fan, different heatsinks (to accommodate the fan), some input filtering components moved from the AC receptacle to the main PCB (also to accommodate the 120mm fan), and slightly beefier components due to its "50w" higher rating (although neither will do its rated wattage without a few upgrades).
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Yah. It looks identical to the older 420W Thermal Master, even down to the heatsink shape and 120mm fan, although the newer thermal masters are Deer/Solytech built.
                    • pdavid
                      • Jan 2011
                      • 279
                      • Hungary
                      I have sort of tested the psu with a 3Ghz p4 platform and a couple of hdds, fans for a few days. It worked and wasn't hot. Consumption was 1.1A max according to a cheap tester.
                      Maybe I'll make a virtual load. There is a sale at a local diy shop. I can buy 20-50-100W heatsinked resistors real cheap. Salvage the other stuff like switches and connectors and put it in a box.
                        master hoarder
                        • May 2008
                        • 12164
                        • Bulgaria
                        I guess I better take note of that.
                        • pdavid
                          • Jan 2011
                          • 279
                          • Hungary
                          Also it gave me an idea to check all the tl431 in that Chieftec 750 unit which I'm still supposed to fix.
                          • Nagy Daniel
                            Lowest possible resistance on laptop motherboard rail - Guide Table request
                            by Nagy Daniel
                            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                            So, I generated a table with AI so I can...
                            03-04-2025, 08:24 AM
                          • Victor Moreira Silva
                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                            by Victor Moreira Silva
                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                            Well, my decice specs are the following:
                            Model: Acer Nitro 5 AN517-54-55T5
                            CPU: Intel Core i5-11400H
                            GPU: NVIDIA GeForce GTX 1650
                            Motherboard: GH51G LA-L181P Rev:1c
                            The symptom:
                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                            05-26-2025, 10:49 AM
                          • lefetylorant
                            Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                            by lefetylorant
                            Hello Everyone,
                            Long story short, I got this unit for very cheap.
                            I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                            I've performed some measurements:
                            - 20V rail perfectly...
                            09-14-2023, 05:05 AM
                          • bimole
                            Weird behavior on 3.3V rail of a CORSAIR CX600
                            by bimole
                            A colleague gave me an apparently ill CORSAIR CX600.
                            He told me that he heard a banging noise, and smelt the magic smoke.
                            After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                            I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                            It's another story on the 3.3V rail...
                            I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                            02-13-2025, 04:49 AM
                          • joshAU
                            Acer AN515-55-528T FH52M LA-J891P - Short ciruit after PQW1 MOSFET on +1.35VSDGPU rail.
                            by joshAU
                            Hi all.
                            This notebook was showing no signs of life.
                            I removed the FH52M LA-J891P mainboard and found that there was 19V at the DC jack.
                            However there was zero volts on the two PRB2 and PRB46 resistors immediately after the two polarity protection MOSFETs (PQB11 & PQB12).
                            If I remove the PQW1 MOSFET, the 19V rail starts working, and I can turn on the unit - at least I get the fans, and the power light comes on, when I simulate the power button being pressed. No display.
                            I tried replacing the MOSFET with a new one, but again no voltage on the...
                            05-29-2024, 12:33 AM
