Canon i850 PSU Trouble
  • Mad Capper
    • Feb 2012
    • 113
    I have ruined an otherwise good, I believe, PSU as my hand eye coordination isn't what it used to be.
    The story so far ...
    What we have here is a PSU from a Canon i850 Printer. The printer did not turn on and so I went to check the power supply output voltages thinking it could be there rather than the logic board, which I really wish I knew how and could fix, but everything checked out with the proper voltages. I looked at the logic board and have no clue if it could be fixed or how. (As an aside is there any place out there that assists with fixing those sorts of boards? )
    Anyway I thought I would double check the PSU and while doing so the probes slipped and I guess I shorted something as now there is no 5V output but I do get 24v and 27v.
    Contacts from output connector from top to bottom are as labeled on case +5V GND +24V GND +27V GND CONT.
    I don't know what CONT is or if it matters. Thinking back to what happened I can only think that I connected the 5V and GND but cannot be certain except that there is no 5V out anymore.
    So if there is any tests or info that could lead me hopefully to a bad component that could be replaced to resurrect the PSU I would appreciate it, you all are so helpful. If I can give any info on the board that can't be seen in the photo please let me know.
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Canon i850 PSU Trouble
    Check F201 and the big diode on the secondary right next to the secondary capacitors (cant see the diodes #)
    Muh-soggy-knee
    • Mad Capper
      • Feb 2012
      • 113
      Thanks ben7
      Please bear with me. So I tested the fuse F201 and there is continuity, so that means it is still intact, correct? I don't need to remove a fuse to test it do I?
      I believe you are referring to the diode to the left of the empty capacitor spots labeled C303 and C302, correct? The D101 label is directly underneath.
      I lifted one leg of the diode. With my meter on the diode setting and the black lead of meter to cathode (striped end) and red lead on anode, shows around 240. Leads reversed shows nothing. Am I correct that the means the diode is good?
      Any suggestions as to where to from here?
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Originally posted by Mad Capper
        Thanks ben7
        Yes, both the diode and the fuse are good.
        Try checking D201, and read the part number off the transistor-like thing circled in red (not D201).
        Muh-soggy-knee
        • Mad Capper
          • Feb 2012
          • 113
          D201 performs just like the other one so it is good too. The part in question is labeled on the board IC201 and on it is says TA76 431AS 2 F.
          Seems to google as an Adjustable precision shunt regulator. I think this is the datasheet: . Do I need to take this out to test and how would I test it?
          Thanks again
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Thanks again
            I am thinking that the 5v is derived from either the 24v or the 27v rail, using a buck converter.
            Check Q201, it probably will be some type of mosfet.
            The adjustable regulator should be fine, its likely used as a reference.
            Muh-soggy-knee
            • Mad Capper
              • Feb 2012
              • 113
              Q201 is a J378 2 E
              I can't seem to find what it is exactly, perhaps a zener diode?
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Q201 is a J378 2 E
                It is a 2SJ378 P-channel MOSFET.
                Muh-soggy-knee
                • Mad Capper
                  • Feb 2012
                  • 113
                  Is there anyway I can test this? If this is the component that is responsible for the 5v is there a way I can see whether it is outputting the 5v and depending, if the problem is that component or elsewhere in the circuit
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    This is the easiest test I can describe...
                    Basically connecting the mosfet up in a circuit to see if it will light an LED when the button is pressed. The 100K resistor proves that all the current wont flow through the gate (and through the switch) if the mosfet is shorted gate-to-source. If the mosfet is open circuit, it wont do anything; if the mosfet is shorted source-to-drain the LED will light even when the button isn't pressed.
                    Muh-soggy-knee
                    • b700029
                      Banned
                      • Sep 2010
                      • 640
                      And be careful with MOSFETs, they're quite static-sensitive.
                      • Mad Capper
                        • Feb 2012
                        • 113
                        Well after looking through the parts box I found the requisite materials and built the circuit in the schematic and the mosfet checks out as good. I.e. when connect to 9v LED is off. When the switch is pressed the LED is on.
                        b700029
                        thanks for heads up
                        I hope there is more that I can try, as everything so far has tested as good.
                        I really appreciate the help.
                          Check and see if you do have 27V feeding the MOSFET, otherwise check those components in red circles.
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            The 27v rectifier does measure ok, so the 27v rail must be working properly, must be something in the bucking circuit that is broken.
                            Muh-soggy-knee
                            • Mad Capper
                              • Feb 2012
                              • 113
                              Here goes.
                              For the Rectifier
                              24v on the side to the top of the photo
                              27v on the side to the bottom
                              27v shows on the right side of R207, I think that is where I am supposed to check
                              Cap for 27v
                              27v on left
                              0 on right
                              The cap you have circled below it
                              24v on left
                              0 on right
                              For the inductor
                              From GND on output connector to either leg is 0
                              It has continuity between both legs, not sure if it supposed to.
                              For the MOSFET
                              G and S show 27v
                              D 0
                              For the two diodes, lifted one leg and they check out ok.
                              D104
                              27v on cathode
                              0 on anode
                              D204
                              27v on both sides
                              for Q202, says C1741A on it, not sure how to test this independently,but
                              27v on all legs
                              Fuse has continuity
                              C201
                              show 0 on both legs
                              D201
                              shows 0 on both legs but as stated in post 5 it checks ok too
                              Hope I got all that right
                                The MOSFET is getting the 27V OK but it is not switching on and off like it should, since you had already checked the MOSFET and it is tested OK, so there may be bad transistor that driving the Gate circuits is bad. I cannot trace it that well from the pictures.
                                It looks like the Gate is connected to the transistor to the right of the MOSFET, cannot see the designator on the picture, IC201?, which you had indicated earlier as 431? Which is the ref diode.
                                You can try replacing that, it is commonly used for regulating the switching power supply circuits.
                                • Mad Capper
                                  • Feb 2012
                                  • 113
                                  I tried to get a better photo to be able to trace the runs and put a few labels on. Let me know if that helps or if I should put some more labels on.
                                  On the IC201, TA76 431AS 2 F
                                  I get
                                  0.8v on cathode
                                  0 on anode and Ref
                                  Is there a way to test it?
                                  Is the Fairchild TL431A the same or an acceptable sub for the TA76 431AS 2 F datasheet I referenced in post 5.
                                  IF this is the faulty component, I happen to have two other 431's
                                  a WS TL431AA 336D from a DVD player power supply. I think this is the datasheet. http://www.alldatasheet.com/datashee...S/TL431AA.html
                                  Also have an AZ431 AZ-AE1 735D78 from a Digital Converter Box power board. Datasheet here I think
                                  http://html.alldatasheet.com/html-pd...4/5/AZ431.html
                                  Would either of these work or are they not to the correct specs?
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    No, the gate is driven by Q202 and Q203
                                    Muh-soggy-knee
                                      OK, I seee them now in the new picture, I thought that Q202 was the IC201 (had to flip picture in my head). So he needs to chek those driver transistors then.
                                      • Mad Capper
                                        • Feb 2012
                                        • 113
                                        Test transistors, Ok.
                                        the best data sheet i could find for the Q202, C1741A S QF is
                                        http://www.alldatasheet.com/datashee...1741AS_11.html
                                        according to that datasheet, if I got the correct one, it is ECB orientation starting with pin 1 as designated by circle on board. (I think that is what the circle would mean)
                                        I think this is the correct testing methodology for a transistor
                                        Meter set to diode
                                        Red on - Black on
                                        E - B nothing
                                        B - E 747
                                        C - B nothing
                                        B - C 743
                                        E - C nothing
                                        C - E nothing
                                        That means it is good, correct? Am I doing this right?
                                        As for the surface mount one, Q203, I hesitate taking it off to test it as I am afraid my desoldering skills, or lack thereof, would put too much heat to it and destroy it. Also, as it has no marking I do not know how to identify which is B, C or E. Can it be tested while on the board?
                                        As you can tell I don't know anything so I really appreciate everyone's help.
                                        • Catisfaction
                                          Canon TS8350a waste inc container reset
                                          by Catisfaction
                                          since my second device of this model number now died due to Canon being service unfriendly, I'd like to reset the counter myself.
                                          This model of printer seems to be on non of the eBay sellers and other suppliers support lists for the Canon Service Tool. Other forums suggested the v5103 version of the tool, which did not work unfortunately.
                                          Has anyone maybe experience with this exact model?
                                          Thank you!
                                          07-02-2025, 07:46 AM
                                        • joaquinmjuan
                                          Canon TS8350 Screen Freezes on Power On
                                          by joaquinmjuan
                                          Hello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...
                                          05-07-2025, 12:26 AM
                                        • bamdad61
                                          Canon DR-1210C flash dump request
                                          by bamdad61
                                          Dear folks, recently got a canon dr-1210c and it worked perfectly just for one day. Right now it shows all possible errors on the screen and do nothing. I tear down the device and found a 32 pin plcc flash chip. I thought reprogramming firmware might be helpful. The firmware update file from canon support include a dll file which doesn't help. So if anyone has the dump it would such a great favor to share.
                                          04-15-2025, 02:43 PM
                                        • shybear
                                          Canon Pixma MG2550S dump BIOS
                                          by shybear
                                          hi,
                                          I've here this printer that is "locked" because Ink Absorber waste ink Counter is full so when I power on it give a sequence of 7 blinking orange LED in sequence with green power ON led.
                                          Reading a lot over Internet it seem that is an "use&trash" model so there isn't a way to reset manually this counter and also seems that it is not possible to enter in Service Mode status to reset with Canon Service Tool utility.
                                          This is really suck because I cleaned already the printer and bought both new cartridges!!!
                                          Working around for a while I finally...
                                          01-20-2021, 05:28 AM
                                        • zoltor
                                          Canon G3430 has a lightning flash after the firmware
                                          by zoltor
                                          Good afternoon. The Canon G3430 is lit by lightning after the firmware, it does not respond to the buttons. I did not flash it, they brought it with traces of soldering, and all three chips. SPI - IC401 25Q128, IC402 25Q32, IC403 M24128. The SPI flash drives may have been confused in places. The QM8-0985 formatter. I've tried all the firmware available on the Internet, and the result is the same. I ask you to send dumps of chips, if someone has the same revision of the board, also tell me if the location of the SPI flash corresponds to the position numbers. Thank you very much in advance.
                                          09-17-2025, 12:40 AM
