too high voltage!
  • kids
    • Oct 2005
    • 13
    too high voltage!
    My PSU ATX 400W generated out voltage too high. It burned out my HDD with (nearly), 17V(for 12V line) and 7V (for 5V line). I checked all part inside and replaced all some bad caps 1000uF-10V,16V. But nothing change! Voltage 's still too high. Please tell me why (?)
    (Line 3.3V is nornal)
  • linuxguru
    • Apr 2005
    • 1564
    Re: too high voltage!
    Check the secondary rectifiers also.
    • kids
      • Oct 2005
      • 13
      You can show me whre? I checked parts from line 12V and 5 V only. I think some registers with wrong value make wrong out voltage but I dont find any bad parts.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        replace ALL sencondary caps.
        anything that overloads +5 or excessive ripple/noise affects all the other outputs.
        3.3 is regulated independent of the others.
        after replacing the caps if problem still persists look at the feedback.
        thats the opto between the pri/sec of the transformer.give the regulator chip a sample while isolating hot/cold sides.
        • FALKLAN
          Running Line Voltage and Integrating LED Pods - Automotive
          by FALKLAN
          Howdy everyone! I hope all is well where ever you are!
          I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
          I am uncertain how to convert this line into a switched 12v output line for the LED pods....
          02-05-2025, 12:30 AM
        • harp
          high voltage high resistance marking resistor
          by harp
          Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
          08-26-2024, 01:42 PM
        • conghuyms
          MSI RX580 Vcore voltage is too high, please help me !!!
          by conghuyms
          I have an MSI Armor RX580 8GB V1.3 graphics card. Currently, all power rails are present, but the voltage supplied to the GPU Vcore, which should normally be around 0.9–1V, is measuring at 1.4–1.5V. The GPU gets very hot, and the MOSFETs supplying the Vcore phases are also extremely hot, with a noticeable whistling noise.
          I’ve already replaced the UP9505P controller IC with a new one, but the issue remains the same.
          Since the UP9505P is a new IC, could it require firmware programming like some high-end graphics cards such as the RX5700XT?
          What should I do...
          08-02-2025, 11:38 PM
        • harp
          Low voltage very high current rails distribution
          by harp
          Low voltage very high current rail distribution
          I have some mains toroid transformer220v/12v, and thinking to add a few one-two turns fat coil in parallel, like in picture. Red are working windings, purple (top and bottom) is rails who connect all low voltage windings.
          Question is, how to connect that device to be as much more efficient in spot welder operation to distribute and pulls currents to all winding equaly, minimalize voltage drop?
          output on half E-F
          output on C-B
          connect A-B and C-D, output on A-F
          otherwise?...
          10-27-2023, 02:45 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
