Hi guys. This is my first post on this wonderful forum, so I'll give you a little background.
I've been building and fixing up PCs for a long time (over 7 years now), so I'm not completely new to troubleshooting various problems. I'm more of a hardware guy than a software guy, but I feel I'm pretty good at getting to the bottom of most software issues.
That said, I'm no electrician so there's always more for me to learn.
I started having an issue with my current setup around 8 months ago. I've since upgraded a few items, so I'll list my current specs.
Motherboard: EVGA E758 A1 X58
CPU: Core i7 920@4Ghz
DRAM: 6 GB of OCZ Platinum DDR3 1600
GPU's: Two reference EVGA GTX 670's in SLI
Audio: Creative SB X-Fi Titanium
PSU: Thermaltake Toughpower 1KW (W0155)
Storage: Seagate 1.5 TB, 640GB RAID 0, WD Black 1TB
Case: Corsair 800D
Displays: Two Dell Ultrasharp U2410 H-IPS LCD's
The issue I'm having is that my PC won't actually start up normally after it's been powered off for over three hours. When I press the power button, the PLED will come on and the fans will spin for a split second, but then the system will shut down immediately (the PLED will stay lit though, as will the MOBO's power LED). When the PC is in this state, pressing the button again does nothing. The only way I can get it to turn on is to kill the power, either by holding in the button for five seconds or switching off the PSU in the back. After doing this the system will start normally.
Note that once my system is up and running, it's stable as a rock. Also, I don't experience this problem unless my system has been down for a while.
As I said, I had this same issue months ago when I was using a single GTX 580 GPU. The problem seemed to go away after a while. However, I recently had my system completely torn apart (I performed a few case mods) and this issue reared it's ugly head again.
I suspect that a bad cap is causing this problem (likely in the PSU). However, the motherboard could also be the culprit. I'm having a hard time narrowing down the cause. My MOBO uses solid state caps and they show no signs of damage. I've actually never had a solid state cap go bad. I opened up my PSU to inspect it as well, but the electrolytic caps it uses look fine (no bulging of any kind). Sadly, the extra PSU's I have laying around are not sufficient for my primary rig. Therefore, I cannot just throw one in to see if the problem goes away.
What do you guys think? Do you also suspect the PSU? If so, do you think it's the caps in the PSU? Any suggestions at all are appreciated.
Case: Corsair 800D
