Select-able wall wart power supply - dead
  • ajsemtb
    • Jul 2010
    • 79
    Re: Select-able wall wart power supply - dead
    So for anyone rise in the future reading this thread, is there a faster way that I could have found this out sooner? I don't mind, I was taking it apart for fun. but for a problem like this, What is the process of diagnosing the failed parts on one of these?
      Check the primary winding for open circuits, and if it has primary fuse, check that too.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Originally posted by budm
        Better off getting new PS, and unplug it when not in used.
        Yes, and also overloading can cause it to burn out. Also, poorly designed transformers might burn out earlier too.
        Muh-soggy-knee
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • Andreas_de
          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
          by Andreas_de
          Hello!
          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
          04-12-2025, 10:38 AM
          03-31-2024, 02:12 PM
        • kevin_allein
          Samsung QE 75 Q 7 FGMTZG Power Supply dead
          by kevin_allein
          Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
          In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
          Does anyone have schematics for that board ?
          Any good tip, what could be the issue ?
          02-27-2025, 12:15 PM
        • khalillll
          maxipower 400W Dead power supply repair
          by khalillll
          The power supply was completely dead. Voltage reached the main capacitors, but nothing after that.
          After checking, I replaced the UTC7606D IC to restore the 5VSB.
          I using SDC606U as a replacement, but it didn’t work — possibly the IC itself was faulty.
          Replaced it again with another UTC7606D.
          Result: 5VSB came back, but still nothing — no 12V, 5V, or 3.3V.
          After checking again, I think the issue was with the UTC7520D IC.
          Replaced it with a WT7520.
          Result: PSU fully working again
          09-27-2025, 05:06 AM
