Rasurbo RBP-450CL power supply's erratic behaviour
  • mariushm
    • May 2011
    • 3799
    Re: Rasurbo RBP-450CL power supply's erratic behaviour
    Originally posted by Rob Northen
    I've seen lots of people bitch about the 4 diode desigen. Could someone please tell what is wrong with the 4 diode design ??????
    As far as i know it does the same as a rectifier.
    In theory, when they're in the bridge rectifier package, the surface area of the whole package acts as a heatsink, so they don't heat as much.
    Maybe there's also something about not causing shorts between the leads but I doubt it.
    For example, here's standalone diode and a rectifier :
    1N5406 (600v 3a) : https://cdn.badcaps-static.com/pdfs/...bfe1b673eb.pdf
    GBU4J (600v 4a) :
    1n5406:
    PD Power Dissipation 6.25 W
    R. JA Thermal Resistance, Junction to Ambient 20 °C/W
    gbu4j:
    PD Power Dissipation 8 W
    RθJA Thermal Resistance, Junction to Ambient, * per leg 19 °C/W
    the bridge package heats less and can withstand more current
    Also, check the derating curves:
    If the fan dies and a user has a high load, the standalone diodes may melt or short closed, causing further damages. With the bridge rectifier, even a small plate of aluminum or copper is enough to act as heatsink.
    • PeteS in CA
      • Aug 2005
      • 3586
      • USA, Unsure of Planet
      The GBU4 is a lower dissipation part and can be mounted on a heatsink to improve its thermal performance. The 1N5406 has no way of heatsink mounting other than its leads, which gets kludgy.
      PeteS in CA
      • b700029
        Banned
        • Sep 2010
        • 640
        Originally posted by Newbie2
        I like the metallic purple "P4-450W" power supply they have in their picture with other power supply models.
        "it's not a wattage rating, it's just the model number for the different colors!"
        • Rob Northen
          • Jan 2010
          • 137
          • Denmark
          GBU4J (600v 4a) :
          1n5406:
          gbu4j:
          Thanks for the info mate!
          • Dan81
            Aspire 5742G - erratic behaviour, dunno what to try anymore
            by Dan81
            As the title states:
            I have here an Acer 5742G, mainboard model NEW70 LA-5891P rev 1.0. CPU is an Core i5 430M, GPU is Radeon HD6370M (aka Mobility HD5470). Other specs include 4GB of DDR3 and a 320GB WD Black.
            Issues:
            - powers and runs from anywhere ranging to 10 seconds up to 3-5 minutes or so
            - fan runs at full speed
            What I have tried:
            - reflashed both main BIOS and EC at least 10 times, same behaviour across at least three diferent BIOS versions - 1.07, 1.23 and 1.30 (since the BIOS flasher reports PEW71)...
            03-09-2022, 01:16 PM
          • iMic
            IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
            by iMic
            Hi folks,
            I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
            The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
            11-29-2023, 06:44 AM
          • Federause
            HP 250 G7 - Battery Issue (Lid behaviour)
            by Federause
            I have an HP 250 G7 for assistance. I've changed the battery (the old was dead) with a not-original.
            It has a particular behaviour that I've never seen:
            With the lid open, the voltage is present on the relative pins. Upon a time I close the lid, after 5-10 sec. the voltage drops down to 0. If I re-open the lid, the battery keeps stuck in this situation. I have to connect the power supply to "resurrect" the battery. In this way, I can power on the laptop without any problem and also use it without the power cord. If i shutdown the laptop, keeps it with the...
            09-08-2024, 03:34 AM
            by momaka
            03-15-2023, 10:17 PM
          • kalemaroni
            Dell DC Brown wire
            by kalemaroni
            There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
            08-26-2025, 10:10 AM
