Aspire 5742G - erratic behaviour, dunno what to try anymore
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    As the title states:
    I have here an Acer 5742G, mainboard model NEW70 LA-5891P rev 1.0. CPU is an Core i5 430M, GPU is Radeon HD6370M (aka Mobility HD5470). Other specs include 4GB of DDR3 and a 320GB WD Black.
    Issues:
    - powers and runs from anywhere ranging to 10 seconds up to 3-5 minutes or so
    - fan runs at full speed
    What I have tried:
    - reflashed both main BIOS and EC at least 10 times, same behaviour across at least three diferent BIOS versions - 1.07, 1.23 and 1.30 (since the BIOS flasher reports PEW71)
    - repasted both CPU and GPU, but temps were good beforehand as well - 39*C is literally where it sits at because of the fan running at full speed.
    Is there anything I can do, or is it safe to say the board is trash?
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Aspire 5742G - erratic behaviour, dunno what to try anymore
    Hi
    Did you flash the bios with a programmer?
    Did you see screen when the laptop is on?
    Did you do clean me region before you flash bios.
    What are the voltages on evey coil and the resistances to ground?
    Regards
    • Dan81
      SNES-powered
      • Oct 2013
      • 1866
      It's kinda late but I can answer some of those questions:
      Yes, I did flash the BIOS (and EC chip as well!) with a CH341A programmer and Colibri programming software (specifically because it has the compare feature.).
      As for the screen, yes, it always comes up.
      The Clean ME region thing... I used already cleaned ME BIOS files for that matter - specifically searched them on here and managed to get it working. The only non clean dump I used was BIOS 1.23.
      As for the voltages and resistances, I haven't gotten to check them, but I'll be sure to post them up tomorrow.
      Main rig:
      Gigabyte B75M-D3H
      16GB DDR3-1600
      Delux MG760 case
        • 22264
        Theres a similar thread from a member who had the same issue https://www.badcaps.net/forum/showth...ighlight=NEW70
        • reformatt
          • Feb 2020
          • 1549
          Generally fast fan with low CPU temps is a sensor problem, like missing fan tach. Fan speed is driven by U35/EN_DFAN1 from the EC. Sensor feedback is via FAN_SPEED1 to the EC. So check this area first.
          If that checks ok, go over the other thermal sensors on the board. PU30/PH1/PH2 would be a good starting point. Issue here could shut the system off by pulling mainpwon low.
          If you can get into Windows, the Intel Extreme Tuning Utility can at least tell you what is going on with throttling etc, however I don't know if it supports such an old CPU.
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            That was one of the threads I've been looking at for almost the whole day. Flashing the files in there gave me a black screen though the machine DOES boot into Windows.
            The thing is, HWMonitor does report the speed of the fan, so the tach sensor does indeed work - sometimes it does switch fan speeds but in a totally chaotic way, like it's pulsating for 2 or so seconds.
            Main rig:
            Gigabyte B75M-D3H
            16GB DDR3-1600
            Delux MG760 case
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Could be failing GPU itself.
              • Dan81
                SNES-powered
                • Oct 2013
                • 1866
                Are you sure? I don't see any artefacting when inside Windows.
                If so, do you think a reflow would bring up the GPU as the cause of the erratic fan behaviour? One thing I noticed is the GPU doesn't have any protection foil over it, but the HM55 chipset does.
                Main rig:
                Gigabyte B75M-D3H
                16GB DDR3-1600
                Delux MG760 case
                • reformatt
                  • Feb 2020
                  • 1549
                  If you can get into Windows, check Task Manager for CPU speed and see if it's being throttled - this could account for the erratic fan speed. Throttlestop is an app you can use to check. Also Intel Extreme Tuning Utility does have some indications as to why it's being throttled if that is the case.
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1866
                    No throttling as much as I could see. CPU temps aren't anywhere close near throttling - 36-55*C is the maximum I've recorded through HWMonitor. I'd reckon it would have to get in the high 70s to 80s to be even throttling.
                    At this point, I feel like I'd have better luck buying another board with a GT540M (the LA-5893P) that might just have a corrupted EC (seller reports it sat 1 year doing nothing, then suddenly didn't want to power on. I just have an myriad of BIOS for that one too, as I happen to have a beaten up and soldered to kingdom come 5893P that won't power on at all.) and beat that horse.
                    Main rig:
                    Gigabyte B75M-D3H
                    16GB DDR3-1600
                    Delux MG760 case
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1866
                      And this one doesn't turn on anymore either. Great.
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                      • reformatt
                        • Feb 2020
                        • 1549
                        Throttling doesn’t occur just because of temperature. Can be many reasons, like missing sensor data or non-genuine charger for example (like on Dells). It can be asserted by the CPU or the system itself.
                        • Dan81
                          SNES-powered
                          • Oct 2013
                          • 1866
                          HWMonitor detected all thermal sensors though - CPU, MB temp (which I assume is the PCH temp), and ultimately, GPU temp.
                          As for non-genuine charger - ASUS, Acer, and some HPs use an totally bog-standard plug. Acer and ASUS are literally 4 wires, out of which 2 are positive and 2 are negative. Same goes for ASUS mostly, and HPs usually depends, but they're mostly + and - with some resistor that acts as the 3rd wire.
                          Anyways, thanks for all your help everyone. I've decided to give up on both mobos I have (LA-5891P and 5893P) and use a LA-5911P (Phenom II N620 + HD5650 1GB) in its place, out of a pretty mangled 5552G. Both are my units by the way.
                          As for the 5742G, I just ordered a new one w/ GT540M and a i3-370M, and will upgrade it once it gets here (and possibly spraypaint its case white, to make it look custom)
                          Main rig:
                          Gigabyte B75M-D3H
                          16GB DDR3-1600
                          Delux MG760 case
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            The LA-5911P is the worst out of the 3 unfortunately. AMD from 2010 so lots of wasted power, worse performance than Intel and very high failure rate of RS880M northbridge.
                            • Dan81
                              SNES-powered
                              • Oct 2013
                              • 1866
                              Mine did have a failed RS880M, but considering the thermal pad literally crumbled, I don't blame it. I slapped a Phenom (it came with the lowest Athlon II P320, that thing ran slow like hell. Even a low end Pentium T4xxx was better than it.) and a copper shim over the RS880M. Temps are at bay now, surprisingly, and it does run 1080p decently.
                              Not the best choice (I'm not a big fan of AMDs either) but it runs way too well to fiddle with it any further.
                              I've only had two units that are running EXCEPTIONALLY well and are tough as absolute nails - this 5552G mobo (NEW75 LA-5911P) and a whole Packard Bell LJ71 that's running a DDR2 based Athlon II M300 and a MXM 3.0b HD4570.
                              As for the 5742G, it's probably better that I went and looked for a variant that has the GT540M. Same performance as the HD5650 that the 5552G uses apparently. Now just to check what would the ideal CPU be that would go just right with the GT540M.
                              Main rig:
                              Gigabyte B75M-D3H
                              16GB DDR3-1600
                              Delux MG760 case
                              • Federause
                                HP 250 G7 - Battery Issue (Lid behaviour)
                                by Federause
                                I have an HP 250 G7 for assistance. I've changed the battery (the old was dead) with a not-original.
                                It has a particular behaviour that I've never seen:
                                With the lid open, the voltage is present on the relative pins. Upon a time I close the lid, after 5-10 sec. the voltage drops down to 0. If I re-open the lid, the battery keeps stuck in this situation. I have to connect the power supply to "resurrect" the battery. In this way, I can power on the laptop without any problem and also use it without the power cord. If i shutdown the laptop, keeps it with the...
                                09-08-2024, 03:34 AM
                              • modtool
                                HP x360 Chromebook 14A-CA, DA00GIMB6H0 REV:H, flooded, restored, slow and stuck in tablet mode
                                by modtool
                                Dear colleagues,
                                I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
                                The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
                                Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...
                                05-07-2025, 06:10 AM
                              • av4x
                                Fujitsu U7511 liquid damage, wont turn on anymore, does not respond to charger in any way.
                                by av4x
                                Good morning, everyone!
                                I've gotten my hands on a few laptops with various defects because I want to get more involved in repairing electronics.
                                First up is a Fujitsu Lifebook U7511.
                                It won't turn on anymore and doesn't respond in any way when you plug in a power adapter.
                                Model: Fujitsu Lifebook U7511
                                CPU: Intel Core i5-1135G7
                                GPU: Intel Iris Xe Graphics
                                RAM: 16GB DDR4 - 3,200 MHz
                                PCB manufacturer: ASKPCB?
                                PCB serial numbers: CP801602, CP7984241-Z4, E239218, CP809978-01
                                Damage: Liquid damage
                                The liquid probably...
                                11-01-2025, 03:09 AM
                              • estabilito
                                Acer Nitro AN515-55 weird behaviour on startup
                                by estabilito
                                Hi, I've just repaired acer nitro an515-55 with specs:
                                i7-10750h, rtx2060.
                                Laptop had damaged cpu and after replacement came back to life but i have weird problem with this machine.
                                After night or 2-3hours on first startup laptop shows acer logo, windows circle for second and then screen goes blank - machin stays on but i need to turn it off by holding power, on next startup laptop working just fine.
                                i've tried different bios, different vbios and same behaviour - clean windows install too.
                                Do you have any idea?
                                08-13-2025, 02:52 PM
                              • arashmoayyedizadeh
                                A1990 2019 touchbar weird behaviour
                                by arashmoayyedizadeh
                                Hello to all of you engineers
                                i have a macbook pro a1990 in no power condition
                                another shop had done some works on it with no success (pm ic was reflowed, a little bit of flux around one of the type c rom ic, changing the charging ic)
                                initial state: 5v 0amps on all 4 type c sockets
                                after some inspections i realized the charging ic that another shop installed is isl9239
                                I changed it with right one (isl9240) and the machine turned on and booted into macos
                                weird behaviour:
                                Lcd works ok until it boots to os and as soon as you see login page it goes black...
                                03-26-2025, 12:02 PM
