VP6 Power Supply Issues
  • waynewrk
    • Mar 2006
    • 11
    So I bought another vp6 off of Ebay. I get it installed and windows loaded up, and I keep getting "Machine Check Exception" blue screens. I did a lot of troubleshooting that finally lead me to the PS. I used this PS for my old vp6 for years without problems. However, I noticed that it was a single rail 12v. I loaded up motherboard monitor and all 3 voltages were running too low. The 12v was running around 11.89 consistantly. I put my multimeter on it, and got the same results as motherboard monitor.
    So new Antec SP400 dual rail installed. The 12v for peripherals is now good, registering around 12.40v-12.50v on my multimeter. However, the 12v on the board is registering at 11.94v, and the 3.3v is registering at 3.27v, the 5v is registering exactly 5.00v. I'm still getting the same blue screens when it boots into windows or shortly thereafter. This board is using the stock caps from what I can tell, but none of them are bulged at all.
    What do you guys think?
  • arneson
    • Sep 2005
    • 1267
    Re: VP6 Power Supply Issues
    True how multiple problems are soo much more difficult to figure.
    You think you've got the answer and wham, no joy.
    The other board you got from Ebay was, old new used, guarenteed?
    clean, dirty, smelled bad?
    Jim
    • Shroomie
      • Apr 2006
      • 356
      The stock caps are probably Teapo...and those tend to go bad without any external signs. They could be the problem.
      You know there's something wrong when you open up a PSU and are glad to find Teapos.
      Why I don't buy cheap cases!
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        at this age do not expect any vp6 to perform well without recapping.recap and try it again.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
        • diamon
          Issues with new Surface Pro 5 screens
          by diamon
          I have three Microsoft Surface Pro 5 model 1796, with all cracked screens.
          Have bought from Aliexpress three new screens, the part numbers from my and the seller are the same:
          Bad working China screen part number:
          Good working own screen part number
          Error I get with the bad working China screen:
          No error with the good working own screen:
          All the three China screens (all the same exact part numbers) produce the same error in Device manager. Have also performed a clean installation...
          06-25-2023, 01:41 PM
        • shamsudeen
          Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
          by shamsudeen
          Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
          I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
          i know that in linear power supply the noise will be very low comparing to SMPS supply....
          07-19-2025, 07:14 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
