Antec EA-430 Recap
  • dmill89
    • Dec 2011
    • 2534
    Antec EA-430 Recap
    I Recently recapped an Antec EA-430 (SeaSonic built) and figured I'd post some pics and a description of what I did.
    Caps Replaced:
    3X OST RLP 1000uf 16v > 3X Samxon RS 3300uf 16v (I know 3300uf caps are excessive but they were the only 10mm 16v caps I had that were 1000uf or greater)
    OST RLX 3300uf 16v > UCC KZE 2200uf 16v (I know this is a reduction in capacitance but the 3 1000uf caps I replaced with 3300uf more than made up for this since all these caps are on the 12v rail, one is directly before this cap)
    2X OST RLX 2200uf 10v > 2X Rubycon MBZ 2200uf 10v
    2X OST RLS 1000uf 10v > 2X UCC KZE 1000uf 10v
    OST RLS 3300uf 10v > UCC KZE 3300uf 16v
    OST RLS 220uf 16v > Rubycon ZLH 220uf 16v
    OST RLS 220uf 16v > UCC KZE 680uf 16v
    OST RLS 47uf 50v > UCC KZE 56uf 50v
    OST RLS 22uf 50v > UCC KZE 56uf 50v
    The only cap not replaced was the 330uf 400V Hitachi on the primary
    None of the OSTs were visibly bad but this unit ran for 5 years 24/7 in a server so I figured it would be a good idea to recap it before it put it in my HTPC.
    Pics Below:
  • pavithra_uk
    recap help AcBel PSU
    by pavithra_uk
    I found used PSU AcBel PC6001 ~250W from IBM thinkcenter Core2Duo system. Almost every output rail caps were bulged except 12V rail single cap. caps were Ltec
    12V - 1200uF 16V
    5V - 1000uF 10V before coil 1000uF 10V after coil
    3.3V - 1000uF 10V before coil 1000uF 10V after coil
    5Vsb - 1000uF 10V before coil, 470uF 16V after coil
    Since I have no access to buying new branded caps, I'm going to replace caps with used caps I pulled from dead PSUs and Motherboards.
    I need cap experts ideas about it.
    This PSU will...
    06-27-2021, 02:02 AM
  • ajdrenter
    Picking caps for Antec SU-380
    by ajdrenter
    In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
    https://www.badcaps.net/forum/showthread.php?t=14159
    It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
    05-13-2023, 10:40 AM
    ASUS P5GC-MX motherboard recap
    by momaka
    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
    So here is what the motherboard looked like with its original caps:
    CPU VRM area up close…...
    01-27-2021, 11:59 PM
  • Oldschool297
    RELAND SUN 6.3v 3300uf Low or High ESR?
    by Oldschool297
    I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
    https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
    08-14-2023, 04:32 AM
  • Junkrepair
    Calculating ESR from tan delta -- tan delta's dependence on capacitance
    by Junkrepair
    I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
    I found this nice little description of the conversion:
    Calculating capacitor ESR from Tan(delta)
    https://forum.digikey.com/t/calculat...-from-tan/2633
    It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
    06-12-2023, 02:45 PM
