Amazing! 100 Hz ripple and it still works!
    Back Again?
    • 32762
    So I got this PC from someone, found it in the back of an office.
    Plug it in, boots up fine and starts XP. A little slow, but running. Oddly, the display has this kind of ripple look to it, like the sync signals are noisy.
    I'm also hearing this rather loud buzzing from the PSU (fan okay), so I check the output voltages. WTH? 5V measured 4.4V, and 12V measured just 10V. Amazingly, it still ran fine, with no noticeable problems. Except that it didn't work with the first keyboard I tried (erratic key presses and flickering LEDs.)
    So out of curiosity I scoped the rails and what did I find? A lot of ripple. Okay, I expected that, but the ripple frequency is what baffled me... it wasn't several kilohertz, it was about 100 Hz. (Twice mains frequency in the UK.) And it's still running fine... amazing.
    Another strange thing I noticed was that the optical drive didn't work (the power LED flickered occasionally) but the HDD seemed fine.
    I expect the two primary caps are gone (or going) and that it will quickly kill the motherboard caps.
    The motherboard is reasonably old - just a 1.6 GHz Athlon with 1GB of ram.
    And the PSU looks like another gutless wonder, no EMI filter of course so we can expect a lot of other components to be missing.
    For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
    Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • electronics and DJing/producing music
    Re: Amazing! 100 Hz ripple and it still works!
    That's not really a surprise, motherboard VRMs are quite good at eating low frequency ripple. Remember that the CPU load is continuously varying and the VRM has to keep core voltage constant in those conditions. A volt or so at 100Hz is nothing to the VRM... the caps won't be too happy tho.
    Yes it does sound like bad primary caps in the PSU.
    A working TV? How boring!
      Back Again?
      • 32762
      I went into the system health menu in the CMOS setup and the voltages were all over the place. The core voltage normally ran at 1.63V but occasionally spiked to 1.8V, but I'd expect the CPU to crash with that so more likely I think the voltage reference is unstable for the ADC... but still I don't want to run it like that for a long time. About the only thing that was okay was the 5Vsb at 5.1V.
      One thing I forgot to mention was the ripple amplitude. It wasn't just 10mV, or 100mV. It was nearly 1Vp-p for 12V and 600mVp-p for 5V! 3.3V was relatively stable, that seemed odd but maybe it's because of the magamp circuit?
      • b700029
        Banned
        • Sep 2010
        • 640
        This sounds like the very old Deer design that uses a completely unregulated self-oscillator and 7805 for the 5Vsb, and another linear regulator to take the 5V down to 3.3V.
          Back Again?
          • 32762
          No, I had a look it's got a regulated two-transistor 5Vsb. One bad cap on the 5Vsb and one on the 3.3V. No sign of bulging primaries, but maybe they've just dried out.
          • Newbie2
            • Sep 2005
            • 885
            You should post pictures of the internals of this unstable power supply.
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
              Back Again?
              • 32762
              I think it's just a standard L&C (350 marketing watts). Gutless with diodes on a bracket and four diodes instead of bridge, no EMI filter and only 330u 200V primaries. Barely anything inside it, loads of spaces for inductors and extra caps left shorted/open respectively. Will probably go to the trash soon as it's not really worth repairing. I will post a picture tomorrow.
              • randtek
                • Oct 2011
                • 280
                • US
                • Astronomy, Computers
                The 100 HZ ripple is due to the fact that a Full Wave Rectifier puts out a ripple frequency twice that of the A/C input frequency.
                Full Wave Rectifier Tutorial
                  Back Again?
                  • 32762
                  Yes, I realised this when I saw the trace, I thought I was reading the time base wrong but it was definitely 100 Hz.
                  • CapLeaker
                    Dell ATX PSU won’t start, but forcing it works fine?
                    by CapLeaker
                    Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                    Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                    10-28-2024, 06:59 PM
                  • karlox
                    Dell OptiPlex Micro 7010 - No DisplayPort Output, HDMI Works Fine
                    by karlox
                    I have a Dell OptiPlex Micro 7010 in the shop with a rather unusual issue. The integrated DisplayPort (DP) has no video output, while the HDMI output works perfectly.
                    So far, I have performed the following troubleshooting:
                    Disassembled the unit and inspected the motherboard and all internal connections. Everything appears to be in good condition with no visible damage.
                    Installed the latest official Dell graphics drivers.
                    Tested with two different DisplayPort monitors (one newer and one older), both known to work properly. The result...
                    07-29-2026, 07:34 PM
                  • kamiewtype
                    MPG Z590 No display output with known working GTX 1060/RTX 3070, works fine with GTX 1030
                    by kamiewtype
                    I have a customer machine on my bench right now that's stumped all the techs, so I decided to come here for help.
                    The specs are:
                    MPG Z590 Gaming Carbon Wi-Fi (MS-7D06)
                    Intel core i9-10900kf
                    2x16gb Corsair Vengeance kit
                    BIOS ver is E7D06IMS.1B0, from 6/12/2023
                    The machine was brought in because it would not POST after a GPU upgrade from a GTX 1030 to an RTX 3070. The customer also brought in the original GTX 1030, as well as a GTX 1060 that the machine also wouldn't POST with.
                    I tested the 1060 and 3070 on my bench (ASRock X570 Phantom Gaming...
                    11-01-2024, 10:52 AM
                  • larrysito111
                    ASUS ZenBook UX363E - board UX363EA REV3.0 motherboard not charging but from battery works all fine
                    by larrysito111
                    the laptop had a shot on the pQh9801 the fet for the 19v in for charger was short
                    so replaced that and the isl65994 AD
                    the laptop works perfect from the battery but not charging
                    as i plug in the usbc i get 5v and 20ma and after while just no current
                    isl65994 is generating 3v3 LDOA and 1v5 LDOA
                    when i try without the battery the usbc acts as with the batt but when i press the power button the pda_vin_3v3 pops on for short moment (with batt all this voltages are there)
                    i am no6t getting anything...
                    07-27-2026, 04:10 PM
                  • forkus
                    MacBook Pro 16" A2485 M1 Max (2021): No internal display - external works fine
                    by forkus
                    I'm troubleshooting a MacBook Pro 16" A2485 M1 Max (Late 2021, board 820-02382) with a completely dead internal display. No image, no backlight. External monitor works perfectly via USB-C or HDMI.
                    Symptoms:
                    • Internal display detected in System Information (shows as "Built-in Liquid Retina XDR Display")
                    • No image (no 100% sure), no backlight (100%)
                    Apple Diagnostics codes: VFD001
                    Measurements taken:
                    • PPBUS_AON_LUXE: 12V (schematic shows 13.1V — running without battery on charger only)
                    • PPVOUT_LUXE (CP834): 0V
                    • No short to ground
                    03-27-2026, 03:40 AM
