burnt 20+4 pin and +4 pin connectors??
  • aidynphoenix
    • Jan 2012
    • 34
    what causes this in power supplies?
    is a power supply that has a browning or charred connector dead?
    will a recap fix this or is a different component the culprit?
    I have a Antec "true550" power supply here. (i think that's the model)
    looks like a decent power supply.
    but the 20pin motherboard connector has 4 connections that are burnt.
    each one is connected to a red wire wire. connector's 4,6,19,20
    any chance to save this powersupply?
  • dmill89
    • Dec 2011
    • 2534
    Re: burnt 20+4 pin and +4 pin connectors??
    Does the PSU power on (with a jumper wire between the green sensor wire and a ground{black wire})?
    If so what are the voltages on each rail? (red wires should be 5V, Yellow 12V, and orange 3.3V)
    Given that all the connections that are burnt are on the 5V rail chances are that rail was either horribly overloaded (not likely in any modern system) or there is something wrong with that rail. Opening it up and looking inside / posting pics of what is found will be beneficial.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      I bet you will open the casing to see a bunch of bulging/leaking Fuhjyyu capacitors on the secondary side of the PSU.
      That's why the connector is burnt
      • c_hegge
        • Sep 2009
        • 5219
        Bad caps won't burn a connector - it will just increase the ripple until it fries the chipset. Burned connectors are a result of either drawing more than 6A/pin or poor contact.
        • dmill89
          • Dec 2011
          • 2534
          With a CWT built True Power that is fairly likely. If the only problem is bad caps it is probably worth recapping (these are decent units aside from the lousy caps), it just depends if other damage was done and how bad it is.
          • aidynphoenix
            • Jan 2012
            • 34
            12v rail. 11.91v
            5v rail.. 5.00v
            3.3 rail... 3.33v
            going to open it now, and grab a camera. i'l get some photo's here in a few minutes.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              OK.
              Yeah it's quite a shame they used crap caps; great power supplies otherwise!
              • aidynphoenix
                • Jan 2012
                • 34
                opening it now.. here is a pic of the burnt 20pin connections..
                http://img99.*************/img99/9892/sany2151.jpg
                • aidynphoenix
                  • Jan 2012
                  • 34
                  opened it and remember now after seeing the inside that i tried to recap this powersupply awhile ago.. this was after the burnt connectors though.. after i replaced the two bulding caps it didnt really get use, i just tested to see if it would power up a computer, which it did.
                  but im now needing a psu for spare computer and i want to be sure this one is ok.
                  I guess i only replaced the two that were buldging. and what i had didnt fit.
                  i was not aware at the time that caps could be bad and not look that way.
                  so i fit two nichicon PM(m) series 2200uf 16v 105c caps where the 12v rail filters sat.
                  didnt fit on the board so with one of them i had to run wires and sit the cap elsewhere.
                  http://img401.*************/img401/2818/sany2153u.jpg
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    Problem is with all that extra wire the ESR gets way too high, in effect making those caps entirely useless.
                    • aidynphoenix
                      • Jan 2012
                      • 34
                      well i can completely recap the psu.. was going to do that if i find out the psu is safe to use.. il probably order some neat looking connector kit for the psu so it doesent look all burnt up. il do the wire sleeving so it looks good..
                      and il try and spend alittle extra for 105c caps so it lasts me awhile.
                      but other than checking the voltages, any way for me to be sure this psu is safe?
                      or should i start with the recap?
                      • dmill89
                        • Dec 2011
                        • 2534
                        Most of the CWT Antecs I have recapped had Fhujyyu TM series caps which are (at least according to the data sheet) LOW ESR caps. I would probably use either Nichicon PW (roughly equivalent to the TMs) or UCC KY (one grade better than the TMs). I would also do a full recap if you intend to use it for an extended period of time since Fuhjyyus can't be trusted. The nichicon PMs you used would be ok if you could get them to fit but nichicon PW and UCC KY are easier to find in the correct sizes for those Antec PSUs.
                        • aidynphoenix
                          • Jan 2012
                          • 34
                          well went to digikey and added all the caps i would need to my shopping cart.. total was about $20..
                          if i added alittle more money, i could get a whole new psu..
                          i think im just going to do that instead of fiddling with this one.
                          was pondering this one.
                          http://www.newegg.com/Product/Produc...82E16817139027
                          computer wont be too demanding, 90w CPU, Nvidia 7800GT. 4x1GB DDR2-800. 1.6v. single hardrive, dvd rom..
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            I'd just get the new PSU if I were you
                            • c_hegge
                              • Sep 2009
                              • 5219
                              What are the specs on the system that TP-550 is powering?
                              • Scenic
                                o.O
                                • Sep 2007
                                • 2642
                                For a system like that, a 350W would be enough. Only trouble would be that most of the good ones in that range (300-350W) don't have a PCIe power plug, and those that do cost about the same as a decent 400+W.
                                Something like a Antec EA-380D or a Corsair CX430 V2 would be plenty, if not already overkill.
                                I'm personally running an overclocked quadcore (intel Q6600) + a HD6870 off of a 430W Seasonic S12 II.. just to give you a rough idea of the actual power usage of a system like that.
                                Most people ridiculously oversize the PSU. I've seen people put ridiculously overpriced 600W PSUs (PSU brand fanboys..) into Pentium Dualcore or Athlon II X2 computers with a mid-range graphics card (one 6pin PCIe, if it even needs one) and boast about it. Facepalm moment..
                                I understand the "I'm gonna upgrade the hardware later" argument to some dregree, but putting a PSU in a little dualcore box which could power an 8 core system with a 200bucks graphics card is just stupid.
                                edit: the above statement wasn't directed at aidynphoenix.. I meant in general. Just for the records :p
                                • aidynphoenix
                                  • Jan 2012
                                  • 34
                                  i just upgraded my main computer, got a new processor, motherboard, and ram.
                                  and put my old motherboard cpu, ram into a new case.
                                  old stuff isn't terrible. just not good enough for the new games i want to play.
                                  AMD X2 5000+, AsusM2N sli deluxe mobo, 4GB DDR2-800 ram. 7800gt.
                                  so my 2nd tower will be mainly for data storage.
                                  i will add drives later when i have the money.
                                  this computer i want to feel comfortable leaving on overnight for downloads
                                  so it has to run cool, silent, and be stable.
                                  so i like the corsair powersupplies. i hear seasonic is just as good.
                                  I heard a little rumor somewhere that corsair and seasonic the only two brands that design all their powersupplies from the ground up?
                                  and most of the other brands use the same board as them, but put cheaper parts on them to beat prices? such as coolermaster, rosewell, thermaltake, xion etc. is that so?
                                  • dmill89
                                    • Dec 2011
                                    • 2534
                                    If noise is a major concern you may want to avoid any of the Corsair Builder series. They are decent PSUs but are known to have issues with coil wine.
                                    The Antec EA-380D Scenic mentioned is not a bad option. It is Delta built, although it will have some mediocre caps(Probably Ltec) in it since it is a budget model, but those generally last for several years in a PSU. The Antec High Current Gamer Series HCG-400 400W is SeaSonic built and has all Japanese caps if that is a concern for you. The PC Power and Cooling Silencer MK III PPCMK3S400 400W is also a good option right now since thy have a rebate on them, this is also a SeaSonic built PSU with Japanese caps, Both of these are based off of the S12II platform.
                                    • PeteS in CA
                                      • Aug 2005
                                      • 3586
                                      • USA, Unsure of Planet
                                      The Nichicon PM series - originally the PL series - is rather old. It came out around 1987 or so. The PW is at least 2 generations newer and 2 generations lower impedance. And the PW series is getting "mature".
                                      PeteS in CA
                                      • playit
                                        450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                                        by playit
                                        hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                                        09-02-2023, 02:43 AM
                                      • Nagy Daniel
                                        Lowest possible resistance on laptop motherboard rail - Guide Table request
                                        by Nagy Daniel
                                        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                        So, I generated a table with AI so I can...
                                        03-04-2025, 08:24 AM
                                      • mferna14
                                        Apple MacBook Pro A2338 820-02773-A AON Rail burnt
                                        by mferna14
                                        Hi Dear Friend., I am working on a Apple MacBook Pro A2338 820-02773-A. The history was that the AON Rail on the Trackpad connector JT400 was burnt. After I removed the burnt connector, I tested with the meter & no shorts. Connected the USB C power & all booted fine, no problems at all. I soldered a New TP connector put in the old trackpad with a brand new Flex cable. The laptop beeped in the start but no display. I removed the connector & the display was fine again. USED a known good Trackpad & a Flex cable, even with this still the same problem. I checked the connector whether...
                                        06-25-2025, 11:26 AM
                                      • electomech-fixer
                                        First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                                        by electomech-fixer
                                        I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                                        I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                                        09-15-2025, 01:42 AM
                                      • Victor Moreira Silva
                                        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                        by Victor Moreira Silva
                                        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                        Well, my decice specs are the following:
                                        Model: Acer Nitro 5 AN517-54-55T5
                                        CPU: Intel Core i5-11400H
                                        GPU: NVIDIA GeForce GTX 1650
                                        Motherboard: GH51G LA-L181P Rev:1c
                                        The symptom:
                                        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                        05-26-2025, 10:49 AM
