High Power HPC-420-102 DF
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    My friends Computer while checking all the voltages I found the 5 Standby to be at 5.64v loaded when I unplugged it from the main board it reads just over six volts
    My question is should I recap it.
    I'm guessing bad caps is what is wrong with it.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • retiredcaps
    • Apr 2010
    • 9271
    Re: High Power HPC-420-102 DF
    If you mean recap the power supply, yes recap the caps on the 5V standby rail at minimum. It might be a 1000uF 10V cap that is bloated.
    Also stop using the computer immediately otherwise you may fry the motherboard.
    --- begin sig file ---
    --- end sig file ---
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      yes the power supply.
      Not been in use since I confirmed voltage been to be high.
      Checked for bloated cap none found, I don't own a esr meter.
      Anyway he has purchased a new power supply.
      My pc
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        Replaced the 3 of the caps in the 5vstb.
        Voltage is normal (5.1v) now but the power supply won't run it just gives one pulse.
        My pc
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • SkishyIshy
          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
          by SkishyIshy
          Hey All,
          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
          03-17-2021, 11:44 AM
        • AleMonti
          LG 55EG910V - no power and no standby light
          by AleMonti
          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
          After checking the basics I did the following:
          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
          11-04-2024, 05:02 PM
        • redbaron1007
          Yamaha HTR-3065 No power/No Standby
          by redbaron1007
          I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
          S9 13.7V
          Pwr Ry 0V
          AC Det 9.1V
          Mgnd 0V GND
          The two pins on the transformer for the operation...
          09-12-2024, 03:04 PM
