IDing transient voltage supressor
  • bbjunkie
    • Dec 2011
    • 301
    Hi Folks.
    Have a dehumidifier here that packed in a few years ago.. decided to see if I can get it going again. (totally dead)
    Tracing through the power supply from the input I found a halfwave rectifier built with two diodes and another item which, after googling I believe to be a transient voltage supression diode. The symbol on the PCB below the device is that for a diode, but unlike the other diodes on the board it doesn't have a circuit reference like the others, i.e. D1 and D2
    The markings on the strange device are:
    EIC 5L
    P18CA
    My question is, how do I test this device? Should it test like a regular diode? (It is reading open circuit both ways on resistance and on diode test mode is also showing open circuit)
    If it's faulty, then I will need to source a replacement so any suggestions there would be appreciated too.
    Cheers for now & thanks again for a great forum
    Jim
  • caryg
    • Aug 2009
    • 36
    Re: IDing transient voltage supressor
    It should test like a regular diode. These sit backwards in the circuit and most of the time do nothing, bar absorbing any minor voltage spikes. But if a too high voltage comes through they commit suicide and die as a short circuit. Current then passes straight through that rather than the more sensitive circuitry it is preventing. It's a bit like a reverse fuse in that it conducts when it has blown, so if it's showing open circuit then it needs replacing.
    Well actually, if you are feeling brave and you trust your power supply then you don't need to replace it. Just lift one end, you break the short that it creates, and your dehumidifier should work again. Though I've never dared to myself.
    If you're in the UK then RSS is the best place I've found to get them. Their minimum order (sometimes 25 or 50) is usually cheaper than one or two via ebay, and they are more likely to be genuine too. http://uk.rs-online.com/web/c/semico...archTerm=diode
    • bbjunkie
      • Dec 2011
      • 301
      Now im confused, this statement doesn't make sense.
      • Krankshaft
        • Jan 2007
        • 2328
        I'm sure the poster meant if it reads as a short circuit.
        A working diode reverse biased won't conduct. But if a large enough spike hits it the PN junction can be destroyed allowing current to flow through it in the reverse direction. In other words the diode becomes a jumper wire.
        • Toasty
          • Jul 2007
          • 4171
          A transient suppressor diode will read open. You can't generate a high enough voltage with a DMM to cause it to conduct.
          Usually placed after a fuse, they may not "die" as a short, but a high enough voltage surge and power (in joules) may cause them to pop the fuse. They "reset" after the surge goes away. Much faster reaction time than an MOV.
          Functionality is similar to an avalanche diode.
          If it reads open, it's not the reason the dehumidifier is not working.
          Toast
          PS: Although the board may indicate a diode symbol, that's usually a factory thing so the placement matches the packaging. The actual electronic symbol for these looks like 2 diodes with a single cathode plate between them: ->|<-
          veritas odium parit
          • bbjunkie
            • Dec 2011
            • 301
            Ok, all clear now, thanks.
            Discovered a short circuit zener diode, think that's whats causing the problem
            • bbjunkie
              • Dec 2011
              • 301
              Replaced the 3.9v zener and all is well.
              Thanks guys for the education.
              Jim
              • pcardoso73
                iMac power supply short-circuit diode to ground
                by pcardoso73
                I have an iMac with the power supply reference: ADP-200DFB.
                This power supply is not working and when trying to debug the problem with a multimeter, I found what I thought to be a short circuited diode (the short-circuit is to ground).
                With the continuity test it beeps both ways, so doesn't block current flow at all then reverse biased. But after removing the diode the beep continues and the diode seems healthy. It seems to exist a real short-circuit.
                As I have another ADP-200DFB power supply (faulty one as well), I have checked the same...
                06-09-2020, 08:47 AM
              • Astonished
                Fixing the Charge Circuit of the Batteries of the DC Motor
                by Astonished
                Hi friends of electronics
                What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                Please help me fix this circuit.
                (the datasheet of the IC: https://pdf.datasheet.live/28...
                01-28-2025, 06:24 AM
              • Askic
                Testing for short circuit in diode mode
                by Askic
                Hello electronics experts,
                On a few occasions I notice experienced technicians inspect for short circuit in diode mode on multimeter. This is OK and in some way equivalent to resistance mode, but more specifically I noticed that they put red probe on ground and black probe (connected to COM input on multimeter) is placed on the rail or pin.
                I wonder why is that. Why not place black probe of multimeter on the ground and red probe on the rail which is tested for short?
                Can you clarify this? When I test if something is short I use diode mode First and then double check...
                02-21-2021, 12:05 PM
              • asr
                Finding replacement diode iPad Pro 3rd gen A1701
                by asr
                Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                07-09-2024, 06:24 PM
              • unimatrix93
                TV backlight zener diode
                by unimatrix93
                Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                The led strips has 9 6V leds.
                02-10-2025, 12:13 PM
