FSP300-60PLN rev 1 300w active psu. this one was a hd killer. i recapped it without checking it out first and now it increases voltage slowly bringing the 12v rail for instance up to 12.80, the 5v does it also (i am using 22w antec psu tester to start and load the psu and checking the voltage with dmm on a molex. i did not let it increase past that anyway. difficult to troubleshoot without the prior status info i guess. is there anything that comes to mind that might save it or is it for the trash?
FSP300-60PLN rev 1
Tags: None
Re: FSP300-60PLN rev 1
Does it have adjustment pots, as other Fortrons do? Do pots ever go out of adjustment even when their shafts are sealed in place, perhaps because of oxidation?
A PSU I recently bought puts out slightly out of spec high voltages when loaded with 5.6 ohms each on the +5V and +12V rails, but they drop to within 2% of specs with a mobo attached and the +12V still loaded with 6 ohms. -
yes it has a pot on secondary side daughter board.
i am curious that the voltage is not jumping to that point but very slowly rising. say if i shut it off at 12.60 and then open it up it is at 12.60 again....
might damage a board if i connect though?Comment
That's very importantOriginally posted by RainbowUse dummy load to test PSUs. I use 12V/21W and 6V/15W car bulbs.
Even some of the best PSUs will show less-than-glorious regulation on any major output lines when load on these rails is very low (or zero).
Car bulbs are a nice idea, since, of course, they're cheaply available and, well, they light up
For 'testing under load' of PSUs I keep a number of those porky green-lacquered wirewound fan-cooled resistors, fan-cooled (to avoid stinking up the room and enraging the wife). Typically:
1R ones for the 12Vdc rail - so they're about 140-150W each.
R47 ones for the 5 and 3.3V - about 50 and 25W respectively.
And, of course, the Fluke 337 to see what the PSU's actually up to.Comment
in the end it was multimeter needed new batteryComment
It happened to me too - multimeter displayed "low battery" icon, but I continued to use it. After some more usage, the voltage readings were too high. I thought that one PSU was bad, but more testing revealed that either all my PSUs suddenly gone bad or the multimeter is wrong
I just acquired this portable aircon, history unknown. Its behaviour is quite strange:
- When turned on and placed into cooling mode, the upper fan (cold air out) just spins slowly. The compressor and lower fan do not run.
- If the device is then placed into heating mode and then back into cooling mode, the lower fan and compressor kick in and start cooling, but the upper fan still only spins slowly.
- If the device is placed into fan-only mode, the upper fan does not respond to low/medium/high speed toggles - just keeps running slowly.
- Display and buttons all behave normally aside from the
by EthanMaiMODEL :RZ09-0330QEM3
MBNB : CH551_MB MP V4.0 20200303
SSN : BY2025M02304135
PN : BLADE 15 STUDIO EDITION -EARLY 2020-RZ09-033
Thank you for your help. It needs cleaning; it's starting very slowly.
Thank you
Sincerely,...-
Channel: BIOS Requests ONLY!
by p2computingHello everyone,
I have a Samsung UN55KS800DF
When I turn the TV on the picture initially looks great
After 10 seconds or so, the bottom of the screen starts to show issues and it slowly creeps upward
Eventually the entire display is ghosting and distorted. If I power the TV off for a few minutes and power it back on, the cycle repeats with a good display that slowly degrades.
I have attached an image of the display after about 3 minutes of being powered on
Thanks in advance for all you do for us!... -
by BenassHello,
I am currently working on the Dual CV-1260 amplifier. Unfortunately, one channel has stopped working. After conducting some troubleshooting, I discovered that D34 is exhibiting an incorrect voltage drop, as opposed to D31, D32, and D33, which have a 1.2V drop. D34, on the other hand, has a 0.6V drop. This leads me to believe that one diode may be open.
F1 (the fuse) is showing 0.1V, and the channel is working fine. However, F2 (the fuse) is blown and reads -48V.
In summary, Line 39 has nearly zero voltage and is working normally, while Line 40...-
by tony359Hi all,
I have an old Apple II monitor to restore and I do have a big variac. I've always wondered whether a variac is a good idea to power on equipment which has been unpowered for (likely) decades?
When it comes to analogue stuff, I suppose it's ok and I'm probably going to see the device slowly coming back to life with a lower voltage applied.
But I suppose this won't work for devices with digital components in it as they won't work unless the proper voltages are applied?
In case of an old monitor, it is safe/good for the monitor to...10-13-2023, 02:47 AM - Loading...
