I need help in a replacement diode for the one shown in the attached photo. It has the numbers 676 printed on it as well as arrows. The first number six could actually be a nine as it's laying on its side. Any help would be appreciated...thanks.
Diode Replacement
Re: Diode Replacement
Mr Beer Tap
Greetings on the day.
Item one, great board name.
Item two
Ran into these things in two way radio.
It's a kind of varistor / zener combination.
If the voltage goes too high across the terminals, it starts to conduct.
Some things for you to try.
Will the PSU power up on it's own now?
What is the voltage across the point where the device was removed.
These parts die for only one reason.
They can't over dissipate for long.
In Yeasu radios the part was rated for 16 volts.
Seems transiant voltages in cars will spike the line over 16, the thing conducts, and after a while, pow, short city. The client is stuck with a radio that blows fuses. And I get to track down a mystery.
If you can. Catch me off list, thinking of moving to Reno and fixing PSU's in games is a line of side work Im thinking about.
Thanks in advance
Jack Crow"You are, what you do, when it counts"
The Masso
"Gravity, the quickest way down"
Mayor John Almafi
"You ever drop an egg, and on the floor you see it break?
You go and get a mop so you can clean up your mistake.
But did you ever stop to ponder why we know it's true?
If you drop a broken egg you will not get an egg that's new?"
MC HawkingComment
With the part in question removed, it will power up with no problems. Also, the reading I get across the point of where the device was is 38.7Vdc.
This unit died because of a person plugging in 110vac into the back of the supply not realizing it works on 24vac. Also, when they plugged it in, they pushed the connector in so hard that it bent the case thus shorting it out against an internal heat sink.Comment
Mr Tap,
Yupp, that is a standard symptom.
Pull the offending part and the voltage comes up.
Everything seems to work fine. (Assuming that 37.5 volts is what you expect.)
What I do when a weird part comes across my desk.
I look at it under a microscope, get all the numbers off it, then do a google search with the numbers I find. Most times that is enough to find the part I want.
If that won't do the trick, find a Zener about five volts over your target voltage and call it a day.
Much luck.
The Masso
Mayor John Almafi
MC HawkingComment
BT,
Found the parts I was telling you about.
This one is used on a 12 volt ham radio.
From the spec sheet on Mouser.com
http://www.mouser.com/ProductDetail/...AkAmo4UA%3d%3d
Manufacturer: Vishay
Product Category: TVS Diodes - Transient Voltage Suppressors
RoHS: No
RoHS Version Available
Polarity: Unidirectional
Clamping Voltage: 16.7 V
Operating Voltage: 10.2 V
Package / Case: DO-204AC
Breakdown Voltage: 11.4 V
Peak Surge Current: 75 A
Peak Pulse Power Dissipation: 600 W
Maximum Operating Temperature: + 185 C
Minimum Operating Temperature: - 65 C
Packaging: Reel
Dimensions: 3.6 (Max) mm W x 7.6 (Max) mm L
Factory Pack Quantity: 4000
Went back to the web site and looked up a similar part for above 37.5, and found this.
http://www.mouser.com/ProductDetail/...kCPHn4jNdW8%3d
See an Error?
[Vishay Semiconductors 1.5KE47C-E3/54]
Mouser Part #: 625-1.5KE47C-E3
Manufacturer Part #:
1.5KE47C-E3/54
Manufacturer:
Description: TVS Diodes - Transient Voltage Suppressors 1500W 47V Bidirect
PDF Data Sheet
Order quantities greater than 1,390 may be subject to a minimum order quantity. If a minimum applies, Mouser will contact you.
Images are for reference only
See Product Specifications
Customers Also Bought...
Specifications
Documents
My Notes
RoHS: RoHS Compliant By Exemption Details
Clamping Voltage: 67.8 V
Operating Voltage: 38.1 V
Package / Case: Case 1.5KE
Breakdown Voltage: 42.3 V
Peak Surge Current: 22.1 A
Peak Pulse Power Dissipation: 1500 W
Maximum Operating Temperature: + 175 C
Minimum Operating Temperature: - 55 C
Packaging: Reel
Dimensions: 5.3 (Max) mm W x 9.5 (Max) mm L
Hope this helps.
Jack Crow
Herndon VA"You are, what you do, when it counts"
The Masso
Mayor John Almafi
MC HawkingComment
BT,
This is how we operate here. May not be the fastest but eventually we get around to it.
Much luck on the project.
Jack Crow in the less than free world."You are, what you do, when it counts"
The Masso
Mayor John Almafi
MC HawkingComment
BT,
A moment of truth here.
Have not had much time to play with them.
Suppose the OEM might have data sheets and test circuits that will explain how they work and are to be used.
I found one bad in a two way ham radio.
Seems start up surge in the vehicle wiped the part out.
It's been happening across the country.
You know how it works, fine one bad one, and then hear about four more.
Keep us in the loop. This is good education.
The Masso
Mayor John Almafi
MC HawkingComment
by chth96is there any replacement for MPG06J diode?
https://www.vishay.com/docs/88682/mpg06.pdf
It is very hard to find this MPG06J diode in my place.
I think that replacement should have the same ratings with MPG06J, But it is impossible for me to hunt down replacement for MPG06J diode.
Any reply would be appreciated. -
by badcappoHi there, looking for a compatible replacement for a diode type labelled "V6 18" from a dead Panasonic plasma TV power source. Possibly a V6 600 volts diode as seen here: https://electronics.stackexchange.co...nt-diode-v6-88 ?
Thank you...
by asrHello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks.... -
by jezzaaaaI'm trying to find a replacement diode for one that has gone short.
I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
I can't find the exact part number for sale. Similar... -
I am ordering parts from Mouser electronics and need help finding a replacement diode.
Attached are pics of the good diode with readings.
Thanks in advance... - Loading...
