Antec SP-400 + Teapo = Junk
  • Welch
    • Dec 2011
    • 9
    Well, first I have to say that this is the first time I have ever posted in these forums. I've been referring to badcaps for some time now and have even ordered a decent number of caps (which so far I've been very happy with).
    I guess im like Hugo Stiglitz... My status as a CAP killer is still amateur... I came here to find out if I could go pro!
    So far under my belt I've recapped well over 20 Dell SX280's and a few 270's. Also recapped a horrible All-In-One brand's motherboards called Cybernet. I've recently jumped into new space like 2 Dell 172FPb monitors and now, I'm thinking that the fun does not need to stop there.
    So I've got this Antex SP-400 PSU and its a 100% no boot scenario. I was given this system when building a new computer for a customer of mine (I run a computer shop) and I thought it would be a horrible thing to waste. I replaced 9 x 6.3v 1000uf Teapo caps with some caps I scrapped off another motherboard that simply overheated a bit (I know... reusing caps, shame shame). I'm unclear what brand they were, they had a small "M" on them as a brand label. I want to say I read somewhere that these are possibly Panasonic?
    The motherboard recap went great, I plugged in the old power supply assuming it was just the mobo that had cap issues. Low and behold it wouldn't start, so I tried another PSU and sure enough everything works great. So upon further investigation I notice that this Antec PSU ALSO uses these completely crap Teapo caps, all of which are blown.
    So my question (finally) is... I've never recapped a power supply, and I'd like to be cautious. Is there anything specific I should know to avoid killing myself. I am aware that I am supposed to drain the larger caps off before working on the psu, but I'm not clear on how to make/buy that device and how to use it properly. Any insight one of you guys could provide would be excellent. Of course for this re-cap (since its a PSU) I plan on using new caps to avoid a
    Thanks guys, looking forward to learning and contributing to these forums
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Antec SP-400 + Teapo = Junk
    M = Matsushita = Panasonic.
    Additionally, most people see bloated Fuhjyuu caps in Antec Smart and TruePower supplies.
    --- begin sig file ---
    --- end sig file ---
    • Toasty
      • Jul 2007
      • 4171
      See this thread for info: https://www.badcaps.net/forum/showthread.php?t=8403
      veritas odium parit
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        The heatsinks can be hot [have power] so if it's powered up with the cover off beware.
        Mann-Made Global Warming.
        - Dr Seuss
        • cheapie
          null
          • Jul 2010
          • 849
          Yeah... I learned that the hard way a few months ago. It's not something that you want to mess with...
          • iMic
            IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
            by iMic
            Hi folks,
            I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
            The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
            11-29-2023, 06:44 AM
            by momaka
            03-15-2023, 10:17 PM
          • sirpsychol
            Antec Earthwatts EA-380 smd element type/value
            by sirpsychol
            While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
            09-03-2023, 07:58 PM
          • ajdrenter
            Picking caps for Antec SU-380
            by ajdrenter
            In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
            https://www.badcaps.net/forum/showthread.php?t=14159
            It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
            05-13-2023, 10:40 AM
          • CWEastwood
            Antec Smart Power SL300S capacitor replacement.
            by CWEastwood
            I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
            The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
            I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
            Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
            03-25-2023, 12:18 PM
