New PSU Killing RAM
  • grss1982
    • Mar 2007
    • 225
    • Philippines
    New PSU Killing RAM
    My rig below was running fine with 2 stick of RAM. A power surge occurred and one of my modules died.
    I assumed the PSU must have died as well and thus replaced it with a silverstone 600w psu while running only with 1 ram module. Two days ago the other module just dies.
    So I was wondering, what killed it the first power supply or the new one?
    The new is 3 month old and I'm really starting to have doubts with it.
    Also could the first psu have done something to both ram modules and it just took time for the last one to die out on me?
    Thanks in advance.
    CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
    GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
    Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: New PSU Killing RAM
    The RAM modules themselves may not be dead.
    Sounds like the RAM voltage regulator on the mobo ate it.
    Try the RAM in a different board.
    Mann-Made Global Warming.
    - Dr Seuss
    • grss1982
      • Mar 2007
      • 225
      • Philippines
      Thanks. Will do.
      But your\'re not suspecting the PSU?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        The Ram voltage regulator is between the PSU and the RAM.
        I suspect the PSU ate it from the power surge and took the Ram VR with it...
        ... but the RAM VR didn't fail completely at first...
        ... so you saw what appeared to be a sequential failure of RAM as the VR was fizzling out.
        - Dr Seuss
        • grss1982
          • Mar 2007
          • 225
          • Philippines
          Good Point. Thanks.
          So that means my shiny PSU (600w)is not causing it and it was in fact the first one (400w) that was the suspect in all of this.
          Just for clarification 2nd module dies after new psu. while first module dies when I was still using 400w psu.
            master hoarder
            • May 2008
            • 12175
            Also check your BIOS settings - more particularly, see if there are any settings to change the RAM votage. Make sure the RAM is running at 1.8V and not something higher.
            • 999999999
              • Sep 2006
              • 774
              *Anything* is possible, but what seems most likely to me is that the initial surge immediately killed one of the memory modules, but also simultaneously damaged the other memory module.
              Not all surge damage causes immediate failure, it could just degrade the memory so it fails sooner.
              However, you wrote that you assumed the first PSU was dead. It might be, but I would test it outside of the PC. It is possible it survived, while the memory fried, and it wouldn't turn on the system because of damaged components like memory.
              Now comes the tricky part. Swapping suspect components into known good systems and vice-versa is sometimes the only reasonable way to test some things, BUT it can cause more damage. If the surge or subsequent failure of a memory module left the motherboard damaged, plugging new memory in may risk the new memory. If the 2nd memory module is damaged, plugging it into a different system/motherboard could damaged that motherboard.
              Since you only had 2 x 1GB memory which is the less costly component per module, I think I would start out by buying 2 x 1GB memory and putting it in a 2nd known good system to rule out DOA product, then put it in the suspect system that encountered the surge.
              If that works ok I would not test the old memory at all, throwing it away instead. If that does not work ok, (after any associated bios memory setting if needed) suspect the motherboard is damaged and test the old, 2nd module.
              • FALKLAN
                Running Line Voltage and Integrating LED Pods - Automotive
                by FALKLAN
                Howdy everyone! I hope all is well where ever you are!
                I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                02-05-2025, 12:30 AM
              • ongobongo
                Ram Modules with undderfill - tricks for desoldering
                by ongobongo
                I'm working on another Lenovo E14 gen 2 AMD here which has a ton of errors with the factory soldered DDR4 ram chips. I do have a donor board here from which I'd like to use the modules and swap them. Unfortunately, the modules are glued down with underfill, which i have never worked with before.
                I tried with a lot of heat on the donor board but the modules won't come loose.
                Are there any hint or tricks when it comes to dealing with underfilled chips/ic that could help here
                Ongo
                06-02-2024, 02:18 AM
              • gabrielA7
                Zotac GTX 1080 8GB / No video / Error reported on all memory modules!
                by gabrielA7
                Hi guys!!
                I have this video card on my bench, it turns on and the screen goes black!
                I used MATS but it showed an error in all memory modules, when writing!
                I once got a 1060 with the same symptom, all modules were defective, I rebaled the GPU and it stayed the same.
                Remember that I have all the debts ok, 1.35 Vram and such!
                Could the problem really be in the GPU?
                Could it be the BIOS?
                Thank you in advance!​
                06-05-2025, 09:04 AM
              • grss1982
                PSU killing components?
                by grss1982
                Hi everyone! Been a while!
                So I have a CM MWE 750 Bronze - V2 PSU powering the following:
                Ryzen 5 3400G
                Gigabyte B450 Auorus Motherboard
                32GB DDR4-3600 (2x16)
                ASUS TUF 1660 TI 6GB DDR6
                1TB NVME
                This was purchased by a friend about 3 years ago for her kid and now it showing signs of instability. The PC had this problem of the screen becoming garbled after it was booted up and idling in Windows. It also sometimes gets a BSOD. So I did some stress test by starting with Prime 95 and noticed that the torture test just fails and stops immediately....
                01-17-2025, 04:12 AM
              • rumpumpel1
                ThinkPad X1 Carbon 4th Gen running only at 400 MHz
                by rumpumpel1
                Oberservation:
                X1 Carbon 4th Gen runs very slowly. Task manager shows the CPU running at 400 MHz.
                In rare cases (1 out of 20) it runs at normal speed.
                It does so when running on battery or only with the charger.
                When both are connected - charger and battery (50% charged) - the system switches between charger and battery once per second.
                The laptop does exactly the same thing when running Windows or Linux, so OS level problems can be ruled out.
                Flashing CleanME and a different BIOS made no difference.
                Intel's XTU utility...
                09-18-2023, 06:13 AM
