Looks like megapax/hairong PSUs do explode
  • c_hegge
    • Sep 2009
    • 5219
    I've seen a few members saying that megapax/hairong Power supplies won't blow up when overloaded, but just go out without a bang - a lot like Oklahoma Wolf's unit did in the JG bargain basement round up. However, I just stuck a Hairong ATX-430WA unit on the load tester and at just over 300W - Ka-BOOM. I think they must have used hairong switching transistorsfor a 430 Watter
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Looks like megapax/hairong PSUs do explode
    Nah, they must've used hairong secondary diodes which made for very lousy effiency, and hairong heatsinks which failed to move away the heat that the switchers produced as a result.
    Also they were probably tightened by a hairong Asian kid. Seen it before in power supplies using TO-220 switching transistors, they're not tight enough against the heatsink which makes them run very hot, the heat melts the plastic insulating washer which makes them separate further from the heatsink, and they go boom.
    A working TV? How boring!
    • c_hegge
      • Sep 2009
      • 5219
      Or maybe it was really a 200W unit and they used hairong label
      In any case, though, methinks it was a combination of tiny heatsinks, inadequate silicon (on both the primary and secondary), and the plastic washers (yes, they had melted when I pulled the cover off).
      • everell
        • Jan 2009
        • 1514
        What??...............no pictures????
        Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
        • c_hegge
          • Sep 2009
          • 5219
          Here ya go.
          You can see the burn marks near the middle switching transistor
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            What do we have there, Canicon and JEE? And look, a fuhkyuu too. Looks like the same old platform, just with all the filtering components in place in place of lonely wire links. There's even MOVs in there, nice touch. At least it isn't going to take your computer away with it when it blows.
            • Rulycat
              • Apr 2010
              • 724
              • United Kingdom
              Canicon: "We can, and we'll get away with it!"
              • dumpystig
                • Jul 2011
                • 485
                Haha - brilliant!
                System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Looks like Canicon and maybe Capxon.
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • c_hegge
                    • Sep 2009
                    • 5219
                    The primary caps are canicon. the rest are all Seacon and CEC-Ecap, with a few small canicons.
                    • Rulycat
                      • Apr 2010
                      • 724
                      • United Kingdom
                      Looks like it has hairong heatsinks as well.
                      • dumpystig
                        • Jul 2011
                        • 485
                        [QUOTE=c_hegge;193392]Or maybe it was really a 200W unit and they used hairong label QUOTE]
                        That's still funny
                        • AJ847.63e
                          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                          by AJ847.63e
                          Hi Folks,
                          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                          05-06-2025, 10:37 PM
                        • vanminhscdt@gmail.com
                          Lenovo Legion Y7000P IRX9 LA-N211P REV: 1A, IC Explode
                          by vanminhscdt@gmail.com
                          Hey guys
                          I got a Lenovo Legion Y7000P IRX9 with no fan power.
                          Found a shorted line, IC explode.
                          No boardview or schematics available, but i'm unable to identify it to be able to replace.
                          ​Can someone assist ? ...
                          12-25-2024, 11:21 PM
                        • RukyCon
                          Modding Two PSUs to Output 12V
                          by RukyCon
                          Hello again, this might be a bit of a far-fetched question, but is it possible to modify a 36v and a 48v power supplies to output 12v? Both power supplies appear to use the same topology, they both also have a dedicated 12v winding wired to the control chips, meaning that as soon as i change it so the main output is 12v, then the dedicated windings will not be able to output 12v, meaning it will not start up. However, if i were to then take the main output and tie it to where the dedicated 12v output would go, then it should be able to run fine?
                          Anyway here is a quick overview of...
                          02-22-2021, 01:33 AM
                        • Xebozone
                          Troubleshooting 2xFailed Cooler Master v650 PSUs
                          by Xebozone
                          I have a couple of these PSUs that have the exact same issue on both of them. I find it odd that they both exhibit the same Symptoms.
                          When plugged into the PC, the PSUs are able to power the LEDs inside the motherboard (the standby 5v circuit I suppose?) But as soon as the power button is hit, the PSU powers on for a split second, then there is a (relay?) click and the PSU shuts off. Hitting power does nothing after unless the power is removed and then turned on again.
                          I have a PSU tester which has the same results. As soon as the tester plugs in, it powers on for...
                          02-19-2020, 03:27 AM
                        • japlytic
                          What do you repurpose server PSUs for?
                          by japlytic
                          So far, I have repurposed server PSUs (all hot swap) for the following:
                          • Portable multi-purpose test set with dual channel variable PSU
                          • Variable frequency/voltage electrically isolated pure sinewave AC inverter
                          • Low noise quad channel 0-600V DC PSU using UPS transformers with an inverter based on a trailing edge dimmer
                          If you have repurposed at least one server PSU, please let me know what your application is.
                          11-02-2020, 11:23 PM
