SV25 "Achme" PSU - Deaded
  • SlightlyMiffed
    • Mar 2006
    • 7
    Shuttle SV25 ACHME PSU - 150w
    Greetings
    I have two SV25's returned to me with dead PSU's. (No power at all)...
    Opening them up I could see the green "Teapo" caps (1000uf 10v) are all leaking/bulging so I've replaced these with brand new caps of exactly the same rating.
    Unfortunately, the units still don't power up...
    All the other caps in the PSU look ok so I wondered if anyone has any experience with these PSUs and any suggestions what to do with them next!
    (or they are heading for the bin)..
    Thanks in advance
  • AK0R
    • Mar 2005
    • 204
    Re: SV25 "Achme" PSU - Deaded
    What did you use for replacement capacitors? They need to be high-quality, low-ESR capacitors (as described in numerous places elsewhere on the site); parts typically found at Radio Shack or the like are not adequate for the job.
    Unusual to hear about Teapos failing with evidence of bulging and leaking; they usually fail without any outward indication.
    • SlightlyMiffed
      • Mar 2006
      • 7
      Thanks for the reply.
      I replaced the 1000uf 10v's with these:
      http://uk.farnell.com/jsp/endecaSear...SKU=768406&N=0
      which I had lying around from a previous project. Not sure now if these are suitable or not...
      The Teapos I've removed are definately bulging.
      • Chris1992
        • Apr 2005
        • 561
        They're rubycon ZL, good caps and long life.
        The great capacitor showdown!
        • SlightlyMiffed
          • Mar 2006
          • 7
          Thanks Chris, at least I haven't completely messed it up!
          There are a couple of other caps in the PSU I haven't replaced as they look ok.
          1 x "Vent" 680uf 16v
          1 x "Vent" 470uf 16v
          There are also 2 x "Teapo" 1000uf 10v (I think - pretty hard to see) which are smaller than the other green "Teapo" ones I've replaced.
          These look fine and don't have the bulging tops like the green Teapol ones I've removed... but I may try replacing these to see if it makes any difference...
          • Rainbow
            • Aug 2005
            • 1375
            Something else probably went bad when the caps failed. Check transistors and diodes for shorts and also check the fuse.
            • PeteS in CA
              • Aug 2005
              • 3583
              • USA, Unsure of Planet
              This is probably a stupid post, but did you try to power up the P/Ss stand-alone? Or with the P/Ss plugged into the MB? Modern PC P/Ss turn on using logic on the MB and won't turn on unless plugged in (or you ground a certain pin on the ATX connector). A decent test to see if the P/S is dead is to check the +5V Standby O/P. If it's gone, you probably have a blown fuse (and fuses blow for "good" reasons).
              PeteS in CA
              • tiresias
                • Feb 2006
                • 489
                Hi SlightlyMiffed,
                What exactly do you mean by "not powering up"?
                If you have time, perhaps you could take a few really simply "preliminary checks" to try to establish if there's a relatively easily fixable fault at one of the "early stages" in the PSU, or such things as loose PSON wires:
                1. Is AC power even reaching the PSU's PCB contacts? (Initial wiring)
                2. If so, is the fuse OK?
                3. Do the input capacitors charge? (Check this with your multimeter set to 500VDC or so)
                If you can answer "yes" to all these, then at the other end...
                1. Is there a 5Vsb?
                2. What about a 5-volt-like difference between PSON and ground?
                Yes to both? Short PSON to ground. Then:
                1. Do we still have a 5Vsb or has the unit now shut down?
                2. Are there any DC outputs (3.3, 5, 12, -12)?
                3. Are the output capacitors charging at all?
                Let us know.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  seems these have a 330k or so resistor that opens and renders them dead.
                  comes off the main filters and goes to a 15v zener to make b+ for the pwm chip.at least thats what is coming to mind at the moment.
                  dont toss these units if you give up.
                  i like those shoebox pc's.send em my way!
                  • PeteS in CA
                    • Aug 2005
                    • 3583
                    Good point, kc. That resistor, a small 'lytic (probably 47uF or 68uF), and the zener provide start-up bias to the PWM. After start-up, there usually is a winding from the main transformer that "takes over" and provides bias for the PWM. If that resistor or the cap opens up the P/S main inverter won't turn on.
                    PeteS in CA
                    • arneson
                      • Sep 2005
                      • 1267
                      Thanks to you both, I deal with some Shuttles that are very hot and this is good info.
                      Jim
                      • SlightlyMiffed
                        • Mar 2006
                        • 7
                        Yes, thanks guys!
                        Plenty for me to be looking into here.
                        Power supplies aren't really my thing, but the info here will help greatly!
                        Cheers
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          The bulging green caps probably weren't Teapo. They don't seem to ever fail. Or at least visibly!
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • SlightlyMiffed
                            • Mar 2006
                            • 7
                            PeteS:
                            No, not a stupid post, but I was aware the ATX powersupply won't power up on their own. I test them using an old motherboard all wired up. A good power supply powers on the little green led on the motherboard, and fires up when I power on.
                            These Achme units do nothing...
                            tiresias:
                            1. Yes. AC power if going in.
                            2. Fuse in the plug...? then yes.
                            Is there another fuse on the board or something ? (I've come across amplifiers with onboard fuses, but can't see anything that looks like a fuse inside the power-supply).
                            3. Nope.. none of the caps charge.
                            kc8adu:
                            I would be happy to send you the units, but I think the postage to the US might be a bit much. (I'm in the UK)...
                            RJARRRPCGP:
                            The caps were clearly marked "Teapo".
                            The leaking I saw could well have been the glue stuff they seem to pour onto the components, but the top of each of the caps was not level - If I put them up-side-down on a flat surface they wouldn't sit level and wobble about. Unfortunately I've binned them now or I'd upload a piccy...
                            On one unit I have noticed a "blacken" resistor (I think its a resistor anyway) on the small daughtercard. Its labeled "ASD1"...
                            Not sure if this happened after re-capping or it was like it previously, but looks pretty tricky to replace.
                            I've probably wasted enough time on these now and am out of depth, but thanks for your help guys! Without this site the shuttles would have been dead a year ago (had to re-cap the motherboards when they died).
                            Cheers!
                            • tiresias
                              • Feb 2006
                              • 489
                              From which you can conclude that the the +5Vsb (along with the rest of the outputs, in view of the non-charging input caps) isn't there.
                              Those "good old" British plugs! (I'm from the UK myself, actually, albeit 'emigrated', due to wife & co. to this small, absurdly densely populated, country, situated well below sea level)
                              I was actually referring to the PSU's own fuse. Every PSU I've seen has one, usually wired just after (or almost just after) the AC inputs to the PCB. Admittedly, though, it's not always easy to find - I've seen them sometimes shrouded in black heatshrink for some less-than-obvious reason.
                              I've probably wasted enough time on these now...
                              I certainly can relate to that feeling...
                              But in any case, good luck with your other hardware endeavours.
                              • SlightlyMiffed
                                • Mar 2006
                                • 7
                                I forgot that the rest of the world doesn't go in for fuses in the plug!
                                Bingo! - There is indeed a fuse wrapped in black heatshrink (I was wondering what that was)... Quick test shows its dead so I'll replace it with ..um.. something more solid to see if that helps any!
                                • SlightlyMiffed
                                  • Mar 2006
                                  • 7
                                  I replaced the fuse with something similar I had, slightly higher rated. It blew straight away so did another even higher rated.. which kind of suggests bigger problems to me.
                                  Worth a punt though I thought!
                                  Thanks tiresias (and everybody else)... I'll now leave it at that and try to find some replacements.
                                  Cheers
                                  • Rainbow
                                    • Aug 2005
                                    • 1375
                                    Main switching transistor is probably shorted (or something in auxiliary supply).
                                    • linuxguru
                                      • Apr 2005
                                      • 1564
                                      Check the MOVs across the primary caps - these will usually fail shorted on a voltage surge. If these are OK, the next suspects are the primary bridge rectifier, and then the primary switching transistors.
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        its not good to overfuse.likely to cause even more damage.its self limiting though.foil will blow if fuse is too big...
                                        • AJ847.63e
                                          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                          by AJ847.63e
                                          Hi Folks,
                                          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                          05-06-2025, 10:37 PM
                                        • howardc64
                                          HP Inkjet printer main board bulging cap failure
                                          by howardc64
                                          Fixed a 10yo HP inkjet with a bulging cap on the digital computer power rails (1 to 5V). Unstable voltages causing these inkjets to not boot properly or crash quickly. Seems like more and more of these are showing up nearing the 10 year mark. Board design seem to look similar for many of these printers.
                                          https://h30434.www3.hp.com/t5/Printi...t/true#M997922
                                          02-03-2025, 09:50 PM
                                        • howardc64
                                          UN55NU7100F failed edge lit LED bar, poor quality replacement LED bar AND bulging cap on PSU
                                          by howardc64
                                          Just typical LED bar failure repair but discovered a couple of things worthy of posting
                                          PSU had a bulging cap (470uF 25V). Likely AC/DC bridge rectifier filter. Have seen a ton of 470uF bridge rectifier filter failures on a bunch of difference devices (not just TVs) Stock up on 470uF 25v 35v
                                          2nd thing worth of note is after all the work to replace edge lit LEDs. Discovered 2 LEDs with phosphor coating differnce produing slightly differnet color temp. Result on edge lit TV = dark veritical band Can't detect when testing the LED bar along...
                                          10-13-2025, 05:56 PM
                                        • Hitto
                                          Slightly Bulging Capacitors
                                          by Hitto
                                          Would you consider a slightly bulging capacitor defective if it measures perfectly and it is brand-new? To be honest, they are all equally like this: vent is not totally flat but they have very low E.S.R. and VLOSS is negligible.
                                          So, everything seems perfect apart from the vent looking a bit "strange". They are genuine capacitors, BTW.
                                          The bad thing is that they are 400V capacitors so testing them just to check how much they last would mean using them on the primary of a power supply, which means the risk of damaging the whole circuit.
                                          What do you...
                                          12-23-2024, 05:08 PM
                                        • re-atari
                                          Denon AVR-X2000 mainboard caps bulging
                                          by re-atari
                                          I have been using a Denon AVR-X2000 receiver in my living room for several years now, works perfectly, am very pleased with it. Recently I acquired another one, advertised as defective with flashing red led a few seconds after switching on. Picked it up to try repair and use in hobby room. After switching on, the on/off indicator led indeed initially flashes green for about 2 seconds, during which the display is visible, and then starts flashing red (at 2Hz) with a switched off display.
                                          I'm afraid the service manual is too large to upload here (55Mb), it can be found at https:/...
                                          09-23-2020, 10:37 AM
