Replacing primary capacitors in P5-545K8
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    Got another guinea pig. Seems something liquid was dropped over this computer, motherboard was toast and with a sticky goo over it. ( no caps vented ) .
    The power supply was also dead, and after opening it, I saw why. I´m curious about what could make they blow like that.
    Also, if I decided to fix this for testing other things, or even to partially fix it just to see which parts are good to keep before I scrap the rest, could I just substitute those caps ( provided nothing more in the primary section is shorted ) with different, lower capacity ones ? Those are 820uF, and I just found 330uF or some suspicious 560uF in my junkbox. As it is just for learning, and testing the parts, I don´t mind if it will have a lower efficiency ...
    Thanks for your ideas.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Replacing primary capacitors in P5-545K8
    These are rebranded solytech power supplies. They are not that bad at all, just don't push it much past ~350W. Give it a recap and it will be fine. Though it looks like something got those primary caps very, very hot. I would try replacing them with just some cheap junk 330uf 200v caps or so to see if it will still power up.
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      Wrong voltage setting?
      • b700029
        Banned
        • Sep 2010
        • 640
        Since the sleeve of the left one is still intact and so is the plastic separator near the PCB edge I'm guessing the cap internally shorted and dissipated heat like a resistor, which then caused the other one to vent too.
        • rogfanther
          • Jul 2006
          • 458
          • Brazil
          Don´t know about the wrong voltage. The machine was in a basement, and its owner was traveling. I suppose that the cleaning lady drop something over the desk or the machine, and later, when the guy tried to start the computer, things blew.
          If people thinks some other values will work, just for testing, I will try them and turn on the psu from a good distance.
          • Toasty
            • Jul 2007
            • 4171
            Agree.
            Although I would find it odd for the US, in Brazil they have 115v, 127v, and 220v for mains. One thing that would make them blow (and overheat like that) would be the PSU's switch set to 115v and the unit plugged into 220v.
            http://en.wikipedia.org/wiki/Mains_e...ity_by_country
            http://www.controlledpwr.com/help-in...l-voltages.php
            Did the fuse blow in the PSU?
            The ICL thermistor doesn't look blown from what I can see either.
            veritas odium parit
            • rogfanther
              • Jul 2006
              • 458
              • Brazil
              Mostly 127V ( live + neutral ) and 220V ( live_1 + live_2 ) nowadays, although it is a problem when people who live in the 220V areas ( just a bunch of cities ) do not have the habit of double checking the voltage settings of electronics , more so when they buy it from the ´net.
              I was told that it worked, and was turned off and left for a few months while the owner was traveling, then when they tried to turn it on it didn´t function. I opened the machine, and it was in this state.
              Will check the fuse / thermistor in the afternoon.
              Thanks.
              • rogfanther
                • Jul 2006
                • 458
                • Brazil
                Well, fuse open. The termistor near the fuse has a "bubble" in the heatshrink sleeve. Measures about 20 ohms.
                Will change the caps and the fuse, and test for some more shorts around.
                • Toasty
                  • Jul 2007
                  • 4171
                  Check the main switcher(s). With a mains cap failure, you'll find that it blows at least one of them many times.
                  veritas odium parit
                  • Tyran
                    Replacing capacitors on a 12v 5000w Pure Sine Inverter .
                    by Tyran
                    Greetings folks. I darn near blew the heck out of my 12V inverter the other day by connecting it to a 24V battery source. :poof . Well lesson learned...... or maybe not . But in the meantime I have 4 Capacitors that need immediate replacing each rated at 16V 3300uf and 105deg. I saw a break down review You Tube video where the host suggested that the 35V Capacitors were a better choice for manufacturers to use. Another video suggested that replacing capacitors of higher Voltage is fine but that the 3300uf rating should be kept the same. Can someone please clarify what the functional benefits...
                    04-22-2022, 08:26 AM
                  • yuzupatogik
                    Help with replacing Capacitors on Altec Lansing ATP 3
                    by yuzupatogik
                    I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
                    I can't find datasheets for the Samxon in any of the following variants:
                    10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
                    02-14-2025, 04:11 PM
                  • frannyjunk
                    Vizio M60-C3 Replacing 1000uF 16V with 1000uF 35V capacitors?
                    by frannyjunk
                    Hi, my Vizio M60-C3 does not power on. No lights whatsoever. Upon opening up the TV, the power supply board has 4 bulging capacitors. Each is 1000uF 16V. I have read that one can use capacitors of the same uF and higher voltage rating, but is 1000uF 35V capacitor too high of a voltage rating? My local shop only has these higher voltage capacitors so would rather just buy the 35V variety if it is OK to use them.
                    Any thoughts if OK to use these higher voltage capacitors?
                    11-04-2021, 05:59 PM
                  • dragon3x
                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                    by dragon3x
                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                    power on.
                    Here are some examples :
                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                    switching supply area).
                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                    than 6.3 V.)
                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                    I replaced capacitors with aluminum-polymer.
                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                    03-21-2025, 02:46 PM
                  • Perry Babin
                    Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
                    by Perry Babin
                    I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
                    This is for the primary side of a switching power supply in a car audio amplifier.
                    Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
                    10-16-2025, 05:20 AM
