Got another guinea pig. Seems something liquid was dropped over this computer, motherboard was toast and with a sticky goo over it. ( no caps vented ) .
The power supply was also dead, and after opening it, I saw why. I´m curious about what could make they blow like that.
Also, if I decided to fix this for testing other things, or even to partially fix it just to see which parts are good to keep before I scrap the rest, could I just substitute those caps ( provided nothing more in the primary section is shorted ) with different, lower capacity ones ? Those are 820uF, and I just found 330uF or some suspicious 560uF in my junkbox. As it is just for learning, and testing the parts, I don´t mind if it will have a lower efficiency ...
Thanks for your ideas.
. But in the meantime I have 4 Capacitors that need immediate replacing each rated at 16V 3300uf and 105deg. I saw a break down review You Tube video where the host suggested that the 35V Capacitors were a better choice for manufacturers to use. Another video suggested that replacing capacitors of higher Voltage is fine but that the 3300uf rating should be kept the same. Can someone please clarify what the functional benefits...
