What is not tested with power supplies...
  • japlytic
    • Oct 2005
    • 2086
    I found some tests that were not performed with power supplies on http://www.intel.com/cd/channel/rese...ists/35815.htm
    Most critical of the tests not performed were safety, catastrophic failure protection, overvoltage protection and proper labelling/marking.
  • Newbie2
    • Sep 2005
    • 885
    Re: What is not tested with power supplies...
    If they even put an L&C or Deer power supply to a catastrophic failure protection test, I guarantee it wouldn't pass.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      or a pow-max!
      • jonnyGURU
        • Feb 2006
        • 244
        Actually, a Powmax would likely pass.. unfortunately.
        What they should test for is a 500W power supply actually doing 500W.
        I've had 500W Powmax's fail at not even 300W. But typically when they fail the just go "pop" and everything just shuts down with no residual issues.
        The thing that needs to be tested that nobody tests is LONGEVITY.
        MTBF is bunk. It's a calculation based on mathematical equations, not real life testing. A PSU may work great now... or tomorrow... but what about two years from now after heat has deteriated most of the parts inside?
        Rest in peace BFG. You were... a job...
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          Intel is relying on system vendors - the HPs, Dells, etc. - to check a lot of that stuff in their system DVT. Which does nothing for DIYers, small integrators, and repair guys. Or worse than nothing, since their list can steer you wrong.
          PeteS in CA
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • iMic
            Vintage AT Power Supplies - Selecting Capacitors
            by iMic
            Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
            The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
            02-19-2023, 06:45 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
            09-06-2024, 05:59 AM
            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-12-2024, 02:15 PM
