Recycling capacitors, where do you draw the line?
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    Ok it seems as of late I have a pretty decent supply of junker computers. K7's and various P4's. Needless to say, just about all of them have bad caps.
    Anyhoos, today I finally got my Blue ESR meter built, calibrated, and all that good stuff. And lemme tell ya, that thing is better than sliced bread for snffing out bad capacitors! I honestly don't see how anyone can even begin to repair modern electronics without one.
    Back to my question... I see on some junker PSUs that the average
    low ESR caps they are using for output filtering typically reads anywhere from 02-.04 which in most cases is above the manufacturers specs. Obviously I'm assuming that anything reading more than .05 is probably on the way to the graveyard if it isn't already there.
    But, alas the meter does not have sufficient resolution to really measure that
    low, and I'm also guessing that once you get down into that range there is some error on the part of the meter that can't be helped.
    Since these systems and PSUs are free, and the PSUs are old revision ATX styles typically biased towards the 5v rail with low 12v amperage ratings, I don't want to sink any money into them if possible. Now if I run up on a more modern PSU with a couple 12V rails, thats diferent, I would probably do a full recap of it. Basically all I want with the typical trash picked junkers I find is to get them to work and run stable, at least for a while.
    Thoughts?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Recycling capacitors, where do you draw the line?
    If it looks good on the scope then it is good. If you don't have a scope... well, save some more money and get one.
    A working TV? How boring!
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      I just set my meter to ohms and if it has a good resistance curve I'll use it...ONLY as long as its good and ONLY as long as its: Rubycon, some Nichicon, Panasonic, Sanyo, Polymer
      • Evil Lurker
        Warranty Voider
        • Feb 2011
        • 454
        A scope is definatly on my list but its probably going to be several months off in the future before I can afford one. Then I'd have to figure out how to use the darn thing.
        Heck, as far as I know for all intents and purposes I got about as much expertise in and funding to devote to studying electronics as Mexico's space agency has towards putting a man in orbit.
        In the meantime what I'm attempting to do is to try and locate as many duplicate components as possible, test them out the best that I can, look for patterns in the results to compare against known good components, compare datasheets to find suitable cross references, and finally light the fuse in my decomissioned grain silo filled with sugar and potassium nitrate and hope it makes it off the launch pad without blowing up.
        • 999999999
          • Sep 2006
          • 774
          You are going to too much trouble. If a cap has failed, replace all of same type in that subcircuit. If others haven't, leave them, no need to test their ESR because as you wrote, you don't want to sink money into them as they are aged low value systems. Yes some capacitors will have drifted higher in ESR than spec'd. Some might have started out higher, and some will still be low enough to filter sufficiently in the circuit. When they are a problem on low value systems is when the ESR decays enough to cause a burst failure, before then it is very rare to find instability from an intact capacitor because other components downstream also have capacitors relative to their current needs and noise immunity per part.
          If you factor that the whole system might be worth $100, then divide that by the relative value per part, you'd be spending significant time and expense to re-cap a PSU that isn't failing yet with it being worth very little to someone who isn't relying on it as their primary use system(s).
          An exception would be if you are setting one up for something more important such as a 24/7 home NAS, then I'd replace all the output PSU caps knowing that the system would be in service long enough (enough hours total) that they'd all likely fail before that period elapsed unless they are unusually high quality caps (on average, you won't find most random systems have enthusiast level PSU in them so they'll tend to have budget grade capacitors).
          • Longbow
            • Jun 2011
            • 623
            Yes, I wish I had one back in the day! I love mine!
            I wouldn't be so quick to toss them. All caps will slowly degrade over time, but that doesn't mean they aren't useful parts. Consider also that many of them are costly and have a unique form factor. Its a judgement call based on the manufacturer of the cap and known track record, if any. That's why keeping a 'boneyard' is so handy.
            Is it plugged in?
            • cubytus
              Samsung UN50TU8000FXZC shows thin horizontal green line when warm
              by cubytus
              Hi to all,
              I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
              I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
              Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
              01-10-2024, 01:26 AM
            • TrueSword88
              Kogan - KALED65XU9220STB - Blue Vertical Line
              by TrueSword88
              Hi all.
              I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
              The line just happens to coincide with the end of COF and start of the next COF (attached).
              The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
              Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
              Hoping to fix...
              05-05-2023, 04:28 PM
            • FALKLAN
              Running Line Voltage and Integrating LED Pods - Automotive
              by FALKLAN
              Howdy everyone! I hope all is well where ever you are!
              I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
              I am uncertain how to convert this line into a switched 12v output line for the LED pods....
              02-05-2025, 12:30 AM
            • mindoverflow
              ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
              by mindoverflow
              hello,
              there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
              I changed pads and thermal paste.
              I run mats test but it is reporting 0 errors.
              I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
              After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
              02-09-2022, 03:22 PM
            • Technomancer
              Nintendo 2DS SD Card Reader issue. Problem on the clock line?
              by Technomancer
              I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
              Here is what I have done so far:
              -Tried SD card in another 2DS and on PC, works great.
              -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
              -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
              06-07-2022, 09:01 PM
