Recapping my PSU (non PFC) & a little modification
  • yanz
    • Nov 2004
    • 910
    Well I want to practice first before make any attempt to recap pricier PSU (Tt, Fortron, hec, etc...).
    So I pick the cheap one, ATK (AIBO) 380W ATX PSU. I got it with the $40 case, the psu itself maybe cost $20. It has been powering my duron1300 rigs since a year ago, running folding@home 24/7.
    The original look before modification, this unit is very silent when operate even outside the case:
    Spec:
    The original bulk caps (hey can somebody tell me what brand is it? Looks like planet Saturn's.. :P) :
    The PCB trace (back). Notice the green wires, I made a switch (green wires <--> ground) so no mobo required to power on the psu:
    I was searching for snap in type (bulk) caps from the shop/distributor for value => 470uF 200V. I have no clue what should i get. They give me the KMM chemicon caps. I don't know if it is suitable for my needs (high ripple, low ESR, long life). But the shop tells me that they are good for audio power supply. So, I take it. When in doubt, buy it! That's my motto... The price is almost $2 a piece. Wow!
    Fortunately, after i check the data from chemicon website, these caps are the good ones.
    From the data above I draw conclusion that what I should get are (in order): KMH, KMM, LXQ, LXM
    I make a quick comparison between them:
    KMM is really good compared to the higher spec LXQ. The endurance is 3000hrs though (@105C). That's should be enough.
    The recapping isn't really difficult.
    Notice the EMI filter. I don't know if installing an EMI filter will make any good for the non pfc psu. But I did it anyway, because I can... lol I have some PSU w/APFC that already have it.
    Btw the original caps in secondary side are some Su'scon and Koshin.
    Caps that I use for this project:
    Code:
    Brand & Series		Capacitance	Volt	Dimension	Pieces	Ripple Impedance/ESR
    Panasonic FC		680uF		16V	8x20mm		2	995 	65
    Rubycon ZL		1500uF		16V	12.5x20mm	6	2360	21
    Panasonic HFQ		2700uF		16V	16x25		1	2070	28
    Chemicon KMM		680uF		200V	25.4x40		1	780		366
    Some original caps under 100uF were replaced with some Panasonic KG, TE, MH.
    The hard part is that I have to desoldered the wires (ground, 12V, 5V) first. That makes recapping a lot easier. In the end, all caps seat nicely, no need to bend the legs or any tricks...
  • yanz
    • Nov 2004
    • 910
    Re: Recapping my PSU (non PFC) & a little modification
    more pics uploaded...
    • linuxguru
      • Apr 2005
      • 1564
      You don't really need to change the primary side caps - they rarely fail, except for one small cap, 22 uF or 47 uF near the auxiliary flyback transformer. Also, you've probably used a bunch of 16v caps where 6.3v or 10v would do, on +5vsb, +5v, -5v. You only need 6.3v caps on +3.3v. You can use either 16v or 25v caps on +12v and -12v. 1000uF/25v is sometimes very inexpensive and available easily, and usually has a higher ripple current rating than 1000uF/16v of the same series.
      Other than that, the specs are fine - overkill, actually.
      • linuxguru
        • Apr 2005
        • 1564
        BTW, the original PSU was probably no more than 200W, notwithstanding the 380W spec.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          looks like an allied.
          they are often packed with ost and swcon/rulycon(rubycon fakes)
          • Newbie2
            • Sep 2005
            • 885
            I have seen those same Saturn main caps in an L&C LC-B450 E 450W power supply before.
            Is the exterior of the cheap 380W 120MM fan power supply still the same?
            Post an after photo of the exterior of the power supply if you can.
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
            • Reina
              • Feb 2006
              i modified the same model too, it is very nice build but has poor output capacitors and week shottky diodes. i changed that and build a better thermal-control for the fan too.
              i got a nice silent low power supply (with maybe 250W)
              greetings.
              • linuxguru
                • Apr 2005
                • 1564
                Cool - it looks like the topology for the auxiliary (+5Vsb) flyback converter includes an optoisolator and does not have the Achilles heel (a small primary-side cap) typically found on these supplies. Does it have a Topswitch TOP221 or similar TO220 device as the primary switch on the auxiliary supply? The TOP22x provides excellent regulation and a simple topology, but less protection against mains spikes. An MOV on the input is highly recommended to protect the FET.
                • linuxguru
                  • Apr 2005
                  • 1564
                  BTW, if it's a TOPswitch, you need to stick with the recommended values of the capacitors on the secondary-side pi-filter for +5Vsb. IIRC, it's ~330uF or so - if you go much higher, it will alter the transient response and stability. Anything over 1000uF is probably too high.
                  • PeteS in CA
                    • Aug 2005
                    • 3586
                    • USA, Unsure of Planet
                    One curiosity to look for with TOPswitch has to do with the start-up function. If you turn off AC power to a P/S, there may be enough energy in the I/P lytics that the TOPswitch will try to start. It immediately shuts down again, but if you have a 'scope on the +5V Stby, set for 1 second/division, you'll see several pulses from start-up attempts.
                    PeteS in CA
                    • japlytic
                      • Oct 2005
                      • 2086
                      The PCB has a lot of space on top, because there are a lot of SMD components underneath. Why didn't the manufacturers put provisions for extra electrolytics in large areas of unused circuit board space on the top?
                      • yanz
                        • Nov 2004
                        • 910
                        actually i wrote a long post but lost it because power outage..
                        @japlytic
                        maybe because it's cheap (~$17).. i found a bunch of LC PSUs in the same shop.
                        @Reina
                        Thanks! That's the same board as mine Can you describe more about the mod you did with your PSU? I want to see if I can do the same...
                        @linuxguru
                        Yup, overkill.. that's what I want it to be Imagine a bunch of those here (~20 of them) expected to be lasting for 5 years (no kidding), how can i rely that mission to the crappy taiwan caps?
                        Actually, at first attemp to recap months ago, I use some rubycom mbz 10v. But then I changed my mind & replace them with pannys hfq & fj 16v. The fj seems to be getting too hot while touching the toroid. So, while thinking that i should bend (desolder) the torroid a little bit to the heatsink direction (done), i said why don't I change all the caps to rubycon zl 16v? It clearly has higher ripple and lower esr than any of the hfq and fj (and elna rjj and rubies yxf) while has the same price. So be it Now the jungle of caps looks more homogen..
                        I have a bunch of those 1500uF 16V ZL. I run out of stock for the 1000uF RJJ, YXF, and 1500uF HFQ. No more supply of them from the distributor. All of them have 12.5mm diameter. he price for the ZL is ~20 cent($) per piece. However i'll try to be wiser for the next mod..
                        Btw sorry for my noob, can you explain where and what is the auxiliary?
                        How to know if that replacement for the caps need not to be over 330uF? is 680uF 16v okay? What is the "TOPswitch"?
                        @Newbie2
                        I dug some pics, and can only find this.. it's really just a simple box..
                        • Rainbow
                          • Aug 2005
                          • 1375
                          I had a fan like that (the same "brand" but 8cm) and it died after a couple of months. So prepare to replace that too.
                          • Newbie2
                            • Sep 2005
                            • 885
                            That's what happened to me too in a cheap L&C LC-B450 E 450W power supply after a few months. The 8MM (or 8CM) version is very silent but also very weak. Instead of the white sticker it had a blue sticker. The sleeve bearing doesn't last as long as a ball bearing, so the best replacement is a good 120MM (or 12CM) ball bearing fan that has good airflow.
                            The "saturn" brand is no good. I believe they also make the main caps for current L&C power supplies.
                            My gaming PC:
                            • linuxguru
                              • Apr 2005
                              • 1564
                              The section of the PSU that supplies both +5Vsb as well as the Vcc for the controller IC. In this case, it is the circuitry around the small yellow transformer furthest away from the main (larger) transformer. It is usually 'on' all the time that the PSU is plugged in.
                              Check the original values and try to stay within about +100% of the original capacitance. 680 should be OK.
                              It's a 3-terminal Power IC that includes a High-voltage Power FET as well as an SMPS controller circuit on the same die. It's usually in a TO-220 3-pin package, or an 8-pin DIP. It allows building a low-power (upto ~20W) flyback SMPS with very few components, and is commonly used as the switching device in the auxiliary power supply of ATX PSUs.
                              • PeteS in CA
                                • Aug 2005
                                • 3586
                                With ATX forward, there is a section of the P/S that is always on (if AC is applied). This is called the "standby" or "auxilliary". It supplies power to the MB logic that enables or shuts down the main P/S converter.
                                TOPSwitch is a trademarked name for Power Integrations' IC, described above by linuxguru. STMicro was working on a functionally similar product back in 2000, but I don't know whether they ever marketed it.
                                PeteS in CA
                                • yanz
                                  • Nov 2004
                                  • 910
                                  Thanks, that's the explanation I need.
                                  I'll search for 12mm panaflo fan.. they are reliable and quiet.. (@7V). Thanks for the info..
                                  • Newbie2
                                    • Sep 2005
                                    • 885
                                    DEER makes a power supply that looks to me identical. L&C, a DEER company, uses those blue "saturn" main caps, and also uses the generic "saturn" fans. DEER doesn't have them in 380W, but the closest they make are 350W and 400W. In one of those photos yanz posted, I saw half of the "P4 Support" warranty sticker, and it is commonly on DEER and L&C power supplies. I included yanz's picture with a red oval on the half of the warranty sticker. Have a look for yourself.
                                    http://www.deer-group.com/switch-12cm.htm
                                    My gaming PC:
                                    • Newbie2
                                      • Sep 2005
                                      • 885
                                      Here's for comparison:
                                      My gaming PC:
                                      • gonzo0815
                                        • Feb 2006
                                        • 1600
                                        @linuxguru
                                        I have a few Seasonic SS400FS here, if an topswitch is an 3 pin to 220 switching ic including the fet, than i have some questions. As far as i see, all 4 SS400fs i own, have an bulging 470uF / 10V Fuhjyyu capacitor close to the auxiliary transformer on the secondary side. Now, as i didn`t found any datasheet for those 3 pin switcher, i used an 1500uF MCZ Rubycon. At the moment the PSU are running well on the test rig (K7s5A Pro, Duron 700@933@1.87Vcore) runing Prime95.
                                        But you stated, above 1000uF ther could be problems. What kind of problems will ocure and are they critical? I messured the Vsb with a DVM and it is about 4.95V as usual.
                                        Should i replace that 1500Uf MCZ? And if yes, should this be an low esr type again?
                                        Is the input capacitor (i mean that low voltage capacitor on primary side, not the high volt bulk ones, probably the power supply for the switcher itself)) critical for the PSU, i.e would do the psu cause catastrophic failure if that cap will gone?
                                        if you coild link an datasheet this would be very helpful to me.
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • captain150
                                          by captain150
                                          03-16-2025, 07:34 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
                                        • madscientist750
                                          Replacing electrolytic caps by solid caps on old motherboards
                                          by madscientist750
                                          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                                          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                                          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                                          10-19-2025, 06:10 AM
