EC 350X fried Power Supply (Probably a Codegen)
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    That psu was taken off a PC that I got as a gift from a friend 2 weeks ago.
    The label layout is similar to Codegen. Same with the model name.
    There is a big fan that is dead.
    The fuse is blown.
    Nearly complete input filter, only MOVs are missing.
    Look at the 4 tiny diodes in place of a bridge rectifier...
    The primary caps are HEC 470uF but their real capacitance is 321uF.....
    Switching transistors: 2x 13007...
    The transformer is 33 size..
    The heatsinks are tiny and lame.
    There is S20C.. for 5V, S20C... for 3.3V and F16C... for 12V..
    There are burn marks on the switching transistors and secondary diodes areas.
    I found a short on the primary section but I didn't look if it's in the switching transistors, the 4 diodes or somewhere else.
    The output toroid inductors look (and smell) burnt too.
    Output Caps:
    2x470uF @ 5Vsb
    2x1000uF @ 3.3V
    2x1000uF @ 5V
    1x1000uF @12V
    All caps are HEC, none is bulging.
    The soldering job is not so good.
    Funny thing 1: The label says thermal control, but judging from those heatsinks this was not a good idea.
    Funny thing 2: Even though the fan wasn't working at full speed, that didn't keep it from dying
    Funny thing 3: That psu was powering the following computer:
    Pentium 4 3GHZ (Prescott) Hyper Threading
    1.5GB DDR 400
    Nvidia 7600 GT
    120GB IDE 7200 HDD
    DVD Rom
    DVD Rw
    TV Card
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: EC 350X fried Power Supply (Probably a Codegen)
    Classic failure mode from overload. Check 12v rectifiers and primary transistors.
    A working TV? How boring!
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      Also, do something about the sloppy construction. As in, heat up/resolder/remove&replace components with excess lead length. You don't want things on the primary side anywhere near those of the secondary.
      "HEC," the input caps are of dubious quality. No surprise there.
      Also check the resistors and the two 4148 diodes for the bases of the two switching transistors. The two 2.2-4.7u caps in the base circuits should be replaced with units of better quality- as should all the caps.
      What's with the fuse? Looks like a normal 5x20mm with 'pigtails' soldered on...
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • c_hegge
        • Sep 2009
        • 5219
        Here's what I would do:
        1. replace the secondary rectifiers with parts scavenged from other PSUs. The PSU should now start and the secondaries won't fail again
        2. Pour petrol over the PSU
        3. Load it to around 300W, stand back and watch the humungus fireball as it blows itself up
        OK, don't try it, but it would be fun.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Probably been replaced only to blow up again. At least this one HAS a fuse. One of the PSUs i got once had its fuse jumpered with heavy gauge wire and the voltage selector switch set to 115v. One of the primary caps blew open when i plugged it in - you could imagine the noise it made.
          • c_hegge
            • Sep 2009
            • 5219
            I'v never actually seen a fuseless PSU before (although I have seen primary caps explode before).
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              This belongs to the "for parts" pile.. Not worth repairing!
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                This is indeed a codegen, as the fan is a "tricod science" which is a member of the codegen group.
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  And it failed! They can't do right even a fan...
                  • lti
                    • May 2011
                    • 2551
                    It is probably a sleeve bearing fan. Nobody can make a sleeve bearing fan last very long.
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Papst can. They use teflon-lined sleeve bearings AFIK.
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        I agree.
                        When a cheap PSU like this has multiple failures, it's just not worthwhile to fix it when another cheap working PSU can be found easily.
                        I think part of the problem is that many of the cheap fans don't get proper lubrication (if any at all) from the factory. I've never had cheap sleeve bearing fans seize on me again after disassembling completely, cleaning, and then lubing.
                        From all of the cheap sleeve bearing fans I've seen, only Power Logic (usually found in Deer/Allied/L&C/Solytech PSUs) has proper lubrication. I had a L&C PSU with one of those - it held fine for 7 years of regular use at full blast (12v). Still had lots of oil when I opened it for cleaning.
                        • lti
                          • May 2011
                          • 2551
                          There are many adaptations of the sleeve bearing that have a long lifetime, but a standard sleeve bearing doesn't last very long. However, I found an eight-year-old Adda fan that still had plenty of oil inside it and still ran like new.
                          I wonder how long a Sunon DR-Maglev fan will last. They are completely sealed with no way to disassemble them. They are quiet and don't vibrate, unlike Sunon's older fans. I have one in a PSU.
                          What fan controller circuit is used in this PSU? I have heard of cheap PSUs just placing a thermistor in series with the fan.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            Linkworld does that. The fan works nearly full speed all the time but this is right if you see the heatsinks those psus have.
                            That power supply also did that and the thermistor was hotter than the heatsink it was mounted on
                            Codegen have some sort of fan controller that makes them run hot enough to die soon.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              Most of the cheapies (codegens included) I've seen have no fan controller at all.
                              The inly exception is https://www.badcaps.net/forum/showthread.php?t=12323 (the only good codegen I've seen. I still have it, although I replaced the fan with an Arctic cooling temperature controlled one and wired it straight to 12V. I think it should speed up a bit more as it warms up. I have also recapped it.
                              • lti
                                • May 2011
                                • 2551
                                He said it has a fan controller.
                                Many PSU manufacturers use a fan controller that makes the PSU overheat. Also, I have seen two Hipro PSUs where the thermistor was not touching the heatsink, even though it should have been. One got so hot that the caps near the heatsink failed. The other one made the case feel warm near the PSU, but the fan was so weak that it would have run hot anyway. That is the PSU I put the Sunon fan in. It runs cooler and the new fan is also quieter than the original.
                                • karatzdi
                                  Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                  by karatzdi
                                  I know some might say... just buy another one. Sell it as parts..!
                                  So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                  Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                  Spent some time downloading the Service...
                                  06-11-2024, 08:38 AM
                                • tamerelapute
                                  [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                  by tamerelapute
                                  I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                  Except the cpu, I cant feel anything getting warmer.
                                  I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                  I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                  I believe that if the cpu was fried,...
                                  07-08-2024, 03:28 PM
                                • Francesc V.
                                  Onkyo A8200 - Not the right voltages in some transistors
                                  by Francesc V.
                                  Hi:
                                  I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
                                  With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
                                  Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
                                  Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
                                  I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
                                  04-19-2025, 07:17 AM
                                • redbaron1007
                                  Sundown SFB-8000D What are these transistors?
                                  by redbaron1007
                                  I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
                                  My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...
                                  11-12-2023, 07:30 PM
                                • Bob Wong
                                  MSI Crosshair 15 A11UEK. Need help with Transistors!!!
                                  by Bob Wong
                                  Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
                                  In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
                                  P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
                                  03-15-2025, 02:02 PM
