iMAC G5 ALS PowerSupply API4PC46-290 REV.A R37 near 3845B
  • torgeson5kqs
    • Mar 2011
    • 116
    #41
    Re: iMAC G5 ALS PowerSupply API4PC46-290 REV.A R37 near 3845B
    Can you give me a corresponding printed number on the circuit board that I can reference that would go with that PFC.
    Toasty did you find anything on your end?
    • Toasty
      • Jul 2007
      • 4171
      #42
      No progress. Busy week and the bench is jammed right now.
      veritas odium parit
      • torgeson5kqs
        • Mar 2011
        • 116
        #43
        Any chance you were able to find anything else I could check on that PSU?
        • timehobby
          • Nov 2011
          #44
          Originally posted by Santaken
          I have iMAC G5 ALS 20' PowerSupply is API4PC26-290 REV.A
          When I try to change all CAPs,I lost R37 with some pattern(pic 1)
          Please show me pattern and register-R37.
          hi,
          I'm a new member , I read some news with the power supply imac G5 20"
          ref 614-0366 on my power supply it misses the 3,3v and 12v , could you give me advice and help me ? I have changed some caps on this board .
          regards
          • timehobby
            • Nov 2011
            #45
            hi,
            Where do you find the shematic from the power supply imac G5 20" ?
            it is possible to download ?
            regards
            • Toasty
              • Jul 2007
              • 4171
              #46
              Welcome!
              Please fill in your location in your profile.
              What is the API number of the power supply?
              If it is not the same as this thread, search in the forums. There are over 50 threads on iMac power supplies. Chances are your answer(s) are there. If you can not find a match, start a new thread please.
              Do you have 5v standby and 20-24v standby voltages?
              There are no schematics.
              Toast
              veritas odium parit
              • jtrujillo
                • May 2011
                #47
                I have a 614-0326 imac 20" power supply and the Q1 blown, I replaced and worked but after two days this blown again but now ZD6 is damaged too, somebody know what is the value for this?
                • Toasty
                  • Jul 2007
                  • 4171
                  #48
                  16v
                  What is the API # on the board ?
                  veritas odium parit
                  • ryogadan78
                    iMac A1418 - No LED, no power after overvoltage on Ethernet port
                    by ryogadan78
                    Hi guys, I need your help again.
                    I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                    When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                    06-10-2025, 03:49 AM
                  • Stephen
                    iMac M1 DFU restore issue
                    by Stephen
                    iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                    this is the message it gives me with the error
                    Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                    Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                    03-07-2025, 12:19 PM
                  • Stephen
                    iMac 27” 2020 Boot issue
                    by Stephen
                    Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                    08-16-2024, 09:32 AM
                  • tommy97
                    iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                    by tommy97
                    we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                    Any ideas what might've...
                    04-20-2024, 04:48 AM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
