Re: Where are all the parts?
I've used 45v ones with no issues, and i've seen a couple designs where they had 45v ones from the start. It isn't going to hit breakdown unless your mains voltage is *very* high, and even so it would only do it at low load, because as load increases the voltage on the primary caps decreases when the PSU does not have PFC. At worst it'll create a little extra heat.
I wouldn't put a 40V rectifier on the +12V in a half-bridge design. 60V minimum, 100V better. And why a 30A rectifier on the +12V in an old AT unit??? The original wires would not be aluminium, but tinned copper. Remember the dangers of aluminium wiring in homes???
I also have a 200W AT Hipro that looked decent, except that there was NO INPUT FILTERING when I got it.I eventually added filtering components I salvaged from other PSUs. The X capacitors are 2 x 0.33uF from L&Cs, the Y capacitors (2 x 2.2nF) and ferrite coil from a different Hipro.
The Hipro I got the Y caps and coil from is worthy of mention here. One of those special Compaq ones, +3.3V 15A, +5V 11A, +12V 5A, +12.8V7.5A, 220W total. GBU6K bridge, 560uF Panasonic UP primary caps, STPS30L40CW for +3.3V, STPS1545CT for +5V, BYW99-W200 for +12.8V, P40NF0s for +5V and +12V. Nichicon, Chemi-con, Panasonic, Taicon secondary caps. Some small Teapo SEK scattered around the unit.
Anyway, back to the other Hipro. PBL405 bridge, 330uF Rubycon USP primary caps, 2SC4242 switchers. ESAC65-004 for +5V (couldn't find a datasheet), "C25M" for +12V. Secondary CapXon GL, 2200uF and 1000uF for +5V, 2200uF for +12V. None of them are bulging. The small caps are Teapo SK 85°C.
Remember Newbie2's L&C rebuild??? I might try rebuilding an L&C myself one day. Just out of curiosity. Any questions???Leave a comment:
guys- could you move the skype discussion to here:
https://www.badcaps.net/forum/showthread.php?t=14560
its off topic and my announcement thread has seen no views.Leave a comment:
Skype even did microsux a favor. With skpye 5 and newer, 'skype' is just another skin for internet exploder.
After executing, it fills "tempor~1" with a bunch of crap. Have any of you tried 5.3 and then had trouble downgrading back to 3.8 or 4? I ask this because of what I've seen on 'puters I've worked on.
WLG, that was my reaction after 'exploring' around on a neighbor's computer, looking at the 'mess' left behind.
-PaulLeave a comment:
Nice! Loving the Windows 3.1 styled clock too...Leave a comment:
i've been using 7.5 ever since MS "disabled" that version with the forced upgrade years and years ago.
either win2k comp. mode or hex-edit the msnmsgr.exe file-version to the most recent one. (yes.. that's usually all that MS checks for the forced upgrade apart from the OS version)
alternative / multimessengers are a nogo for me as i actually use stuff like webcam chat or audio conversations.
on my netbook, i use Miranda IM though (with the normal MSN messenger installed side by side just in case)
edit: http://bambooz.pytalhost.net/badcaps/msn75-win7.jpgLast edited by Scenic; 05-11-2011, 07:12 AM.Leave a comment:
I'm surprised that would actually work... but surely you run a higher security risk with such out of date software... unless it's old enough that nobody cares to attack it anymore.
Anyway I would certainly recommend you give Pidgin a try... of course it does have its drawbacks such as webcam support only on Jabber\Gmail and only in Linux, but it also gets rid of all the rubbish that MSN comes with as well, not to mention it's always being updated for better security.Leave a comment:
Windows Live Messenger is also an extremely bloated piece of shit. Is it .net based? I cringe whenever someone asks me to install it for them on an older computer, it always runs like a horses ass on anything less than a Core-based processor or one of the faster P4s. Luckily, it seems to be dying out and Skype seems to be taking its place. Good riddance.
set it to run in win2k compatibility mode and you're done.
(7.5 is the last version that runs on win2k, so it's not affected by the forced upgrade crap (yet...))
that's actually what i'm doing on Win7 64bit on a quadcore lol
i just can't stand the bloated and overly complicated (compared to the oldschool versions) windows live messenger crap..Last edited by Scenic; 05-11-2011, 06:24 AM.Leave a comment:
Yeah I gave up on that thing a long time ago, and now I use Pidgin - been using it even back when it was still called Gaim.
But Skype has just been bought by Microsoft, if I heard right, so expect them to turn that into a piece of crap too, probably - Edit: Looks like Ami beat me to it!
I think I'll stick with Pidgin and maybe Ekiga if I need it.Leave a comment:
Windows Live Messenger is also an extremely bloated piece of shit. Is it .net based? I cringe whenever someone asks me to install it for them on an older computer, it always runs like a horses ass on anything less than a Core-based processor or one of the faster P4s. Luckily, it seems to be dying out and Skype seems to be taking its place. Good riddance.Leave a comment:
I have this old game, Need For Speed Porsche Unleashed - it runs on just about anything - even ran it on max settings (800x600) on an old 400 MHz PII with 128 MB of RAM, a 16 MB video card, and XP installed. Memory usage never went above 200 MB (roughly 100 MB for XP and 100 for the game). Now I tried installing that game on one of my other computers - a 750 MHz socket A system with 384 MB of RAM and a 64 MB Radeon 7200. After installing the stupid Control Center, my RAM usage would peak at 700 MB, even though I had the same graphics settings in the game! And you know why? - because of that stupid ATI Control Center. Apparently, whenever I ran an application that requires 3D capabilities, the Control Center would start multiple instances of a process called CLI.EXE, each taking about 20 MB or more. Solution: uninstall the Control Center but not the drivers, and now that computer happily runs the same game without peaking over 250 MB. ThanksATI
/rantLast edited by momaka; 05-10-2011, 11:18 PM.Leave a comment:
I never played MDK but I have MDK2 which is great, if you haven't tried it I recommend it.Leave a comment:
Nice job! Now this machine will probably outlast almost everything built this year - even with crap components these older ones just keep going and going.... A friend of mine had a 133Mhz Pentium with some ancient and really bad PSU (the fan sounded like a race car revving) .. I had it over at my place to fix the hard drive, and that evening the PSU made a huge blue flash of light, the light in my room went so dim it was almost out... but the thing was STILL RUNNING. How the hell that was the case I will never know, I think I threw the old PSU away
I upgraded it to a Celeron 566 on a slotket (highest CPU it'll take) and 256MB RAM. It makes a great router and print server. It's also a really quiet machine - when it is not needed, the CPU fan STOPS entirely. Never seen that before on a desktop.
Not exactly bloated but it uses .Net!! WHY? It's just a glorified calculator with some very basic graphics - I could make a clone of that in Visual Basic 6 which wouldn't require a bloated .Net runtime - OK it might require VB6 Runtimes but that's less than 5MB and installs in about 10 seconds - unlike .Net which is over 50MB and on an older PC installs in over 15 minutes.
I was checking some C64 demos today - man, the things skilled coders can do in 64KB RAM. It's insane. I didn't catch the C64 times - but i did have a brief encounter with an Amiga. I've always wanted one. I still do. No luck yet.
But hey, i had a computer in the Win98 heyday - and there were so many cool games on it. Take MDK (1997). I played that a lot. And if you look at it even now, apart from the 640x480 resolution, the graphics are impressive. Overuse of transparency and sick level design. And the most hilarious weapons. World's Most Interesting Bomb anyone?Leave a comment:
Needless to say I replaced the PSU as well after that!!
Things like .Net don't help, it makes it easier for idiots to write rubbish, and then of course YOU have to install the bloated .Net runtime as well.
Take the ATi video card 'Catalyst Control Center' - I hate that thing. It's far too big and bloated for it's own good, uses .Net for no good reason (it didn't use to use it, and nobody else's video card software does)
Then take this: http://www.electronics2000.co.uk/download.php
Not exactly bloated but it uses .Net!! WHY? It's just a glorified calculator with some very basic graphics - I could make a clone of that in Visual Basic 6 which wouldn't require a bloated .Net runtime - OK it might require VB6 Runtimes but that's less than 5MB and installs in about 10 seconds - unlike .Net which is over 50MB and on an older PC installs in over 15 minutes.Last edited by Agent24; 05-10-2011, 07:12 AM.Leave a comment:
The Daewoo IC is simply a TL494. I have a few myself, you can see them in really old Deers.Leave a comment:
Aww man before I even saw the pics but read your description of this piece of crap I was going to say.
Did this PSU have one of those hacky rectifier jobs with the two discretes tied together by solder and cobbled onto the heatsink?
Then I saw the pic. Nailed it!
I recognize the logo on that PWM IC it's made by Daewoo many of these generic gutless Chinese crappers use proprietary ICs like the 20xx (year) ICs. At least with datasheet accessible ICs you can determine which types of protection they have if any.Last edited by Krankshaft; 05-09-2011, 10:00 PM.Leave a comment:
Always gives me a laugh to see nice caps in places you'd least expect it.Leave a comment:
Thanks.
This thing wasn't complicated enough, if ya know what I mean, to have 'cared' where the feedback point was. I wasn't too keen on having it before the choke, 'sampling' whatever the choke was rejecting. I used an HN cap before the choke and a PW after, and it's quite happy!Step loads did not upset it- no 'hunting' or chirping/squealing.
While it's less than desirable, sometimes dangerous, to add that extra phase shift, this is either uncompensated or 'improperly' compensated. Similar to the one you wanted to rebuild and blow up that had no AC feedback/comp cap and a stupidly low duty cycle. You know, the one you 'turned up' and discovered had no OVP.
As I recall, you 'rested well' and 'prepared yourself' only to have the AUX section eat itself for breakfast.
by momakaFor today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
http://www.rmac.kingwin.com/products.../abt_650MM.asp
I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
What mostly drew me into buying it is its 2x PCI-E power connectors... -
by Mark DThe TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
by momakaThis one should make @Pentium4 smile
(if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
Macron Power Technology Co. LTD.
Let’s look at the PSU itself.
The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of... -
by Steph.henHi all, a newby question about a bridge rectifier I'm trying to identify.
I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?... -
by unimatrix93Hello everyone,
I'm trying to fix up my battery charger. Where I found a dead schottky rectifier.
This is the dead component PTR30L120CTF:
PTR30L120CTF datasheet(1/7 Pages) PFC | 30A 120V HPTR Schottky Rectifier (alldatasheet.com)
And I have a spare 30CPQ150:
30CPQ150 datasheet(1/5 Pages) IRF | SCHOTTKY RECTIFIER (alldatasheet.com)
Can I use this diode as a replacement or if not, can you recommend me a proper replacement?
I cannot find the exact unit anywhere besides aliexpress and such.
Thank you guys!
- Loading...
