MS Skype
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    MS Skype
    http://about.skype.com/press/2011/05...kype.html#more
    microshaft is buying skype...
    supposedly they will "continue to support and invest in non-microsoft platforms"
    i guess skype for linux may never leave beta stage... I guess skype is being "shafted"
    sigpic
    (Insert witty quote here)
  • Rulycat
    • Apr 2010
    • 724
    • United Kingdom
    Re: MS Skype
    So... what are our alternatives?
    • SluggerB
      Garage light only lights up when you hit it. Make your guess as to the cause!
      by SluggerB
      The flood light over my garage was hanging out of the house due to the previous moron not knowing how to anchor it correctly. So I fixed that today
      I then go to turn the light on tonight, and it doesn't stay on. If I tap it with a piece of wood, the lights come on for a sec them dim. Repeated tapping will cause it to eventually start working, until the switch is flipped, then it's a 50/50 shot it will work again or need to be tapped to start
      So tomm begins the diagnosis. What do you think it is? Vote now!
      A: A loose connection in a wire nut. I tugged...
      10-15-2022, 10:53 PM
    • ferah831208
      help with AMD Ryzen 5 7535hs power rails
      by ferah831208
      Hello there, does anyone have info about AMD Ryzen 5 7535hs power rails or an schematics from a compatible CPU?. I have a quanta G3PR from a HP victus laptop, I suspect cpu is damaged but I would like to know what power rail is the one I guess is damaged. There are 4 coils aprox 4.2 ohm to gnd in parallel next to CPU (I guess vcore) ,one coil same size next to those 4 around 0.7ohms to gnd (damaged rail I guess), and other two smaller I guess associated to less current power rails for CPU logic purposes. Anyone have more specific info? I attached picture.
      03-09-2025, 01:59 AM
    • howardc64
      QN75QN85BAFXZA no backlight
      by howardc64
      2+ year old TV with many (720? 65" version has 720) mini LED dimming zones. TV boots, has sound, panel picture can be seen with flashlight. No backlight. No TV model sticker on rear panel (Maybe Samsung service removed it, read below). Found the model # through the PSU and zoned LED driver board numbers.
      PSU has a click near LED output circuit at 1 second interval, sounded like the 4x barrier rectifier area. Protective pastic liner under PSU shows heat signature on the Schottky Barrier Rectifier in this circuit. Found a shorted diode (2 diode per rectifier, failed rectifier labled...
      07-03-2025, 05:08 PM
    • Logistics
      Parasound Zamp v1 - Guess who's coming to dinner
      by Logistics
      Just picked up this original Zamp. Only hooked it up in place of my Schiit Magni 3 momentarily to see if it functioned. Owner warned me the auto-on-off does not function and the unit must be unplugged to shut off. Has massive hum in both channels. The owner swears it must be a ground loop issue, which I've read they are sensitive to, but after opening the chassis up, I was met by a very uninvited ensemble of guests.
      Needless to say I started writing down values and taking measurements and then fired up Digi-Key....
      03-18-2021, 03:06 PM
    • karoliens
      AMD 7900 XTX VDD_MEM short
      by karoliens
      I am working on AMD 7900 XTX board that initially had faulty E, F, G, H memory channels (near PCIE). Board is also bent.
      I have reused G and H modules and put new E and F modules. Now no failed channels are detected, but I measure VDD_MEM - 0.4 Ohm to GND.
      Other measurements are as follow:
      VDD_SOC - 0.7 Ohm VDDCR_GFX - 0.3 Ohm VDDCR_USR - 4.4 Ohm VDD_MEM - 0.4 Ohm VDDCI_MEM - 11.3 Ohm 1.8V_S5 - 379 kOhm 0.75V - 48 Ohm 12V_BUS - 4.4 kOhm 3.3V_BUS - 1.3 kOhm
      I guess it is either dead core or something else is shorted on the VDD_MEM line.
      09-17-2025, 03:25 AM
