NEWTON POWER NPS-180 Can't Start
  • SpyCaps
    • Mar 2011
    • 28
    #41
    Re: NEWTON POWER NPS-180 Can't Start
    Originally posted by PCBONEZ
    That PSU is in a case. - It has drives connected.
    Some modern PSU's will start without load, but not very many.
    The people in -THIS- forum know what they are doing and make few mistakes.
    If you don't want to follow our advice then stay in one of those other forums you are asking the same questions in and don't waste our time.
    Sorry I miss understand in it. I never know before and I will follow your instruction.
    Fine. I need to put HDD drive, isn't it?
    And I will report you back if it works.
    • SpyCaps
      • Mar 2011
      • 28
      #42
      Originally posted by c_hegge
      Most standard PSUs I've seen will start with no load since the minimum load resistors inside are enough to get them to start. However, this is a non-standard PSU, so it wouldn't surprise me at all if it at least needs a few disk drives connected.
      OK. I don't know it before. I will try again tonight.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        anything that will put some load on the PSU should do. even a 12V halogen light bulb or something like that.
        i usually use a couple old 2GB HDDs. If something goes wrong, nothing of value is lost..
        • SpyCaps
          • Mar 2011
          • 28
          #44
          Ahh...I don't have old HDD. I will use 12V halogen instead.
          Thank for suggestion.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            #45
            Remember you need to put the bulb on the 5v rail not on the 12v.
            A working TV? How boring!
            • SpyCaps
              • Mar 2011
              • 28
              #46
              OK.............................. But from now after short green and black nothing happens. Fan doesn't twist any more. T_T
              May me a controller is bad now.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Not my experience but I don't dink with gutless wonders very often, they go straight to scrap.
                OP also posted +12v was at 10v and at least some of that may be that there is not enough amps on +5v to regulate properly.
                Need to see what +12v does when +5v has a real load.
                Mann-Made Global Warming.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Are you leaving the jumper in place or removing it after you make contact?
                  - Dr Seuss
                  • SpyCaps
                    • Mar 2011
                    • 28
                    #49
                    I do both but nothing happen.
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      09-06-2024, 05:59 AM
