I have said myself that building a PSU from scratch is better than modding an AT/ATX supply. Well, inspired by kaboom's work, i'm ready to prove myself wrong.
I have a JNC "200W" AT supply. If you think you've seen gutless, you ain't seen this. There is zero input filtering - not even the room for it. The primary diodes are 2A. The heatsinks are ridiculously tiny, they don't even have fins. The caps are Capxon, SD and E.V.A.Top. No PI filters (but at least the board is silkscreened for them). It does have TO-220 output rectifiers tho...
Funny thing, the board is printed for both AT AND ATX versions! Talk about low budget. I've been using it as an adjustable power supply for powering the control circuit of the power supply i am building from scratch. I wired a pot from ground to + input of error amp and that was it. Btw i managed to blow all Capxons on the output when i turned the PSU up to 28v - if there is an overvoltage protection circuit, i don't see it working.
The SD cap on -12v escaped because it's rated for 50v.
Well, i've been getting accustomed to compensating the TL494 (which btw is a lot easier than the textbook examples, because it uses a non-inverting error amp which gives you an extra 180 deg of phase headroom, and it seems not being able to have negative gain doesn't give trouble at all). The typical compensation for the TL494 is type 2, but the 2nd capacitor, that is to be put over the R-C network is usually missing. Either way, the 494 is easy to work with.
The current state of mods: I have removed the 5v rail from the feedback loop. Next up are the -5 and -12v rails. I have temporarily installed 470uF 25v Rubycon caps for both 5v and 12v. The fan is now running from what used to be the 5v rail, this will be changed. It will be running from a temperature controlled circuit.
Goal: Transformation to +/-45v with both rails regulated. Step by step, and with lots of pics.
The SD cap on -12v escaped because it's rated for 50v.Well, i've been getting accustomed to compensating the TL494 (which btw is a lot easier than the textbook examples, because it uses a non-inverting error amp which gives you an extra 180 deg of phase headroom, and it seems not being able to have negative gain doesn't give trouble at all). The typical compensation for the TL494 is type 2, but the 2nd capacitor, that is to be put over the R-C network is usually missing. Either way, the 494 is easy to work with.
Probably dissipated as much heat as all the standby ckts on the old mobos put together. Did the 'JNC' label have red stylized letters on a white background?
Just sayin'...
