help, PSU without PG SIGNAL
  • ipo3nk
    • Mar 2011
    • 16
    i have a few fsp based power supply, 60GLN series
    the internal is identical to this thread:
    https://www.badcaps.net/forum/showthread.php?t=11662
    1. the problem is the PG signal is missing if i load the 12v rail over 20A (combined) this is not the OCP limit.
    i have active load to test it
    2. another psu have normal PG signal at first, but if i restart the psu / computer, the PG signal were lost. if i turn off (then turn ON) the psu via switch (disconnect the AC outlet) then turn on via PS-on, i have the PG signal again. but it lost again if the psu restart.
    all the voltage looks OK, even when the PG signal were lost. this make the computer refuse to boot.
    no bulging caps found, the protection circuit is PS223.
    (another psu with bulging caps already repaired)
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: help, PSU without PG SIGNAL
    I am sure there are other users here that are more familiar with this kind of problems...
    Sometimes capacitors fail without bulging. I always check caps with my esr micro tool that tests their esr and capacity. If your psu has Capxon as the one in the photos, then there are chances some of them have dried.
    • ipo3nk
      • Mar 2011
      • 16
      tried to change ALL of caps. but still the same.
      the caps only teapo, capxon, ost.
      still have about 10 psu with this kind of problem.
      • Evil Lurker
        Warranty Voider
        • Feb 2011
        • 454
        Sounds like maybe the PSU power good circuit and/or controller may have issues... read this:
        http://en.wikipedia.org/wiki/Power_Good_Signal
        If your confident that all your voltages check out and the PSU is putting out good power, you might try and desolder the sensing wire and put it on your regular 5 volt rail to see if that has any effect.
        • ipo3nk
          • Mar 2011
          • 16
          even change the chip (ps223) does not fix the problem.
          what do you mean by put the sense wire to 5v?
          give fake PG signal from regular 5volt rail (desolder the grey cable and put it to 5v rail?)?
          already did it by connecting PG signal wire via 1N4148 to 5volt, giving PG signal delay to 0ms.
          ATX spec have delay on this signal about 100 - 500ms.
          with this 'temporary fix' the psu can turn on 90% mainboard.
          some main board cannot boot with PG signal 0ms.
          • everell
            • Jan 2009
            • 1514
            I have a Fortron FSP400-60GLC which is similiar. The PGO (Power Good Output) should go from 0 to 5 volts when power is good. Have you looked at the PGI (Power Good Input) signal on pin 1? The source of this signal is from the main +12 volt rail. This signal goes to three places:
            IS12A (current sense 12 volt line A)
            IS12B (current sense 12 volt line B)
            PGI (Power Good In)
            Between the +12 volts and PGI is a diode and resistor/capacitor network. If the diode is leaky or bad, or if one of the resistors or capacitor is bad from aging, the signal will be wrong to PGI. If the +12 is dropping due to circuit loading, or a bad filter capacitor on the +12 volt line, PGI will not be high enough and PGO will drop out. So carefully monitor the voltage on the +12 volt line and let us know what is happening there. Try using a hard disk drive or a CD ROM drive as a load and see if your PGO signal reappears.
            Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
            • ipo3nk
              • Mar 2011
              • 16
              the PGO only 25-100mv
              the diode d90 (1n4148) and r92 (100ohm or 51ohm) replaced and still have the problem.
              in the PGI signal source network, only a zener diode and a smd caps i haven't checked. i dont know the value of this parts.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Are you testing all of these with the same mobo?
                Mann-Made Global Warming.
                - Dr Seuss
                • ipo3nk
                  • Mar 2011
                  • 16
                  @pc bonez: i'm testing with active load, monitoring all voltage output with DMM.
                  then tested the PSU with various mainboard. msi 740, intel g41, albatron nforce4, gigabyte 890FX ud7, intel S3420GPLC. the intel s3420gplc wont turn on if PG signal out of spec.
                  @everell: how much voltage at PGI if normal?
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Yes I know how it works.
                    I asked because a bad test mobo could have a shorted PG signal line.
                    - Dr Seuss
                    • everell
                      • Jan 2009
                      • 1514
                      Here are two drawings of my psu that might help you.
                      • venksp
                        • Feb 2016
                        • 12
                        • India
                        I have a Cooler Master 460Watt PSU. I dont get a PG signal to boot my Desktop. Whent I Opened up the PSU, the PG circuit was outputting 0.7Volts The IC is WT7527 which gets only 0.15Volts in the PGI. WHen i checked the PIN 1 (PGI) the first Resistor was a 87K and the other side of it was getting a 15.5Volts. All other voltages 12,5,3 are fine. Please help fix this PG output problem. this is the PSU model RS460PCAR-A3.
                          So the resistor is 87K Ohms as marked on the resistor? Beside the resistor, what else is connected to that PGI pin?
                          What resistance do you get between PGI pin 1 and GND pin 2?
                          • venksp
                            • Feb 2016
                            • 12
                            • India
                            The Resistor is connected to a zener diode on the back side of the PCB. This resistor is too small to verify (I check this 87K using MM) it has got 5 lines brown,red,orange ,yellow,brown on it.
                            • venksp
                              • Feb 2016
                              • 12
                              • India
                              http://www.realhardtechx.com/index_a.../Page24794.htm
                              This is the same board on my PSU but in a different name.
                                'it has got 5 lines brown,red,orange ,yellow,brown on it.' If that is the case it will not be 87K resistor.
                                How about GOOD CLEAR pictures of both sides of YOUR board if you want the helps in troubleshooting the problems.
                                Check the resistance between PGI and GND.
                                • venksp
                                  • Feb 2016
                                  • 12
                                  • India
                                  The resistance between PGI and GND is 2K. I dont have access to a camera now ,so uanble to take photos now, the board is the same as the one i had mentioned earlier
                                  http://www.realhardtechx.com/index_a.../Page24794.htm.
                                    Basically 15.5VDC feeding the 87K and 2K Voltage divider, you are not going to get much voltage on the PGI pin.
                                    Take the resistor and the Zener Diode off the the board and check the resistance again, it can also be bad input pin PGI. I also expect a cap or two on that PGI pin also.
                                    I also do not believe the resistor is 87K Ohms, more likely 12K Ohms.
                                    That picture on the link does not do us any good.
                                    • venksp
                                      • Feb 2016
                                      • 12
                                      • India
                                      After removing the resistor (87K?) the connectection between the Zener and PGI is removed. There is only a resistance marked 338 which mesausres ~2.2K between PGI and GND.The zener is not shorted. The zener side of the 87K shows the 15Volts. the PGI end shows 0.15 etc. I have marked the Components.
                                        • 31015
                                        anything printed on the zener?
                                        • AstutePauciloquent
                                          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                          by AstutePauciloquent
                                          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                          11-23-2023, 11:02 PM
                                        • fredyjbi
                                          please help friends fix this bios dell 5490 la-F401p, lost LVDS signal DISP_ON MISSIN
                                          by fredyjbi
                                          please help friends fix this bios dell 5490 la-F401p, lost LVDS signal DISP_ON MISSING I have several units with the same case external hdmi works fine, with internal screen no display, thank you...
                                          05-23-2023, 05:39 AM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • shouri
                                          Dell latitude e5490 auto restart
                                          by shouri
                                          Hi guys, can someone help me?
                                          I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                                          Board model is dm70 la-f401p rev:1.0 2017-09-20.
                                          At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                                          After a few days test, is seems ok.
                                          Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                                          12-10-2024, 09:27 PM
                                        • JayPoorJay
                                          Converting +/- 5v to a Usable Hz Signal
                                          by JayPoorJay
                                          Good morning.
                                          I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                                          This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                                          The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                                          08-07-2022, 08:35 AM
